Question about Canon PIXMA iP4300 InkJet Photo Printer
Wont print i keep getting this error message when i try to print. the tray is open and ive checked the sensors on it, i even re-instaled the printer and it still gives me this error message... document printing can not be executed because the paper output tray is closed, open the paper output tray and printing will continue
  • joCute Dec 14, 2007
    my canon pixma ip4300 is retarted.....
    anyone can help me?
    everytime I print I keep getting the this message that printing cannot be executed because the paper output tray is closed..but obviously it's open.
    How can I fix this?
  • Anonymous Mar 12, 2014
    I have put paper in the lower tray as I want to print a document but is asking for the top tray to have paper also
The problem occurs when the paper tray is pushed down too far and 2 flimsy stop tangs on the backside of the tray hinge break off. The one on the left side contacts a microswitch, pushing it forward , signaling the printer tray is open. When the left tang breaks off, there is nothing to press the switch. You can try bending a paper clip in a fashion that hold the switch forward.
OR (the following will probably void your warranty)
Unplug the printer
Pull out the envelope tray on the bottom.
Set the printer on its back
Look just behind the bottom of the tray door from the underside
There are 2 wells on the underside. The front most wells are more square-shaped.
The 2 wells behind the are irregular-shaped. These 2 have the cover release tangs. Take a long, thin #1 flat blade screwdriver and push them outward toward the sides of the printer to release the 2 inside catches.
Next, push the screwdriver into the 2 rectangular release holes on the bottom sides of printer (beneath little arrows) to release the side tangs.
Next, release the rear tangs in similar slots in the back of the printer.
Gently lift up the cover. Lift up the electronic module on the left side.
The output tray wicroswitch is the black one on the bottom of the electronics module fix it in the upper position with either a small zip-tie or good electrical tape (the top one signals that the top cover is open to expose the ink cartridges, leave it alone).
Carefully reassemble the printer, hopefully it will work.
Remember to open the tray when you print as the preventing switch is no longer functional.
Good Luck.
Posted on Nov 05, 2007
    Problem Solver:
  • 5 Answers
I just wanted to add a little note to this issue. I had the same problem, except the tiny lever on the output tray microswitch was broken off, so there was no way for me to lock the switch in position with glue (or tape as suggested above). So instead, I bent the two leads for the switch as close together as possible using needlenose pliers and used a soldering pencil to melt the existing solder and fuse the leads together, effectively closing the circuit permanently. (I could also have just disconnected the two wires from the switch and soldered them together.) I now have a functioning printer.
Posted on Apr 06, 2008
  • michael_d793 Aug 06, 2011
    Thanks to both Mazezzj and Khumbu,I fixed the problem.Took the suggestion frm Mazezzj and soldered the switch wires together ( have to remember to open the door now!) and thanks to Khumbu,found those devilishly hidden front tangs.Funny thing: There was black ink on the right hinge,and spattered on the door micro-switch and nearby surfaces. One thing: the electronic module is on the right side as viewed from the front.
I have the same problem. What do you mean by open position? The switch goes all the way back. Should we fix it halfway through?
Posted on Aug 27, 2008
How do I fix a printing problem where the error message load tray 1 keeps appearing?
You Really need to have this Machine Cleaned. there is too Much Paper dust On the sensor
Jun 06, 2015 | Xerox 6505/dn Workcenter 6505dn Color...
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
Phaser 7750 Not Printing, No Error codes, Fuser Wont Warm Up, Wont Detect Open Trays or Doors
It sounds like one of the cover or tray sensors is not working correctly. Check the actuator on the fuser cover, sometimes these break off so the printer thinks the cover is still open. If that seems ok and you have a lower tray deck unplug it to eliminate them as the cause.
Apr 07, 2017 | Xerox Phaser 7750 Laser Printer
I have a lexmark x1240 and just installed a new cartridge. I keep getting an error message that says " print cartridge missing" install print cartridge even though both cartridges are in the printer.
If you insert the old cartridge, does it recognize it? If it does, then it's a problem with the new cartridge. Try to check if you already have taken out the protective tapes out of the cartridge.
If it still doesn't recognize the old cartridge, then it's a problem with the printer.
Nov 29, 2012 | Lexmark X1240 All-In-One InkJet Printer
I'm trying to install a new toner cartridge into my printer (yes, it's a Samsung cartridge, not an imitation) and the printer won't recognize the cartridge - it keeps giving me an error message saying,...
most toners have a wing or *** or? that contacts a sensor in some way when the lid closes to tell the machine a toner is present. ive had these pieces broken off on new toner or the toner sensor may be disloged from its seat. check around the perimiter of the lid to find the sensor then see if anything is present to trip the sensor. if its broken off stick a q-tip in the sensor that will get you printing til you can replace the part
Nov 04, 2009 | Samsung ML 2010 Laser Printer
Canon PIXMA IP3600 Service error 6C10, and doesnn't print at all
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Sep 27, 2009 | Canon PIXMA iP3600 Photo Printer
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
The epson printer driver dealing with cd printing is not installed
is there an ok button on that error message? if so just click on OK button and click on a button says manual.
It will let you check on the settings on the printer. paper size should be A4.
on print settings it should let you select on cd/dvd
Note: this only works if you have installed the epson easy print from the epson.com website of your printer model
Feb 07, 2009 | Epson Stylus Photo R200 InkJet Printer
Canon i320
Try unticking ENABLE BIDIRECTIONAL SUPPORT on the Ports Tab under Printer Properties accessed through control panel / Printers and Faxes. Try to print - get error message Enable Bidirectional Support. Reverse back into Ports Tab and re-enable Bidirectional Support and try printing again.
Jan 13, 2008 | Canon BubbleJet i320 Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
1,039 people viewed this question
old marine
old marine
