Question about Plumbing
How to replace a C-L 533-50 Price pfister pull-out kitchen faucet
SOURCE: handle on faucet shuts off on its own
I had the same problem. The Price Pfister web site recommends removing the handle (unscrew the dome cap, then remove the phillips screw to get the handle off) then tightening the retaining ring (I used channel lock pliers on largest setting. It worked. However the retaining ring is plastic on some models, and they recommend replacing it with a brass one. I haven't taken that step yet, we'll see how it goes (mine is plastic).
Posted on Feb 20, 2009
smokenic
  • 49 Answers
SOURCE: Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Posted on Sep 20, 2009
SOURCE: I can't disconnect the quick connect sprayer hose Price Pfister
Squeeze the bottom half of the 2-piece black plastic cylinder that connects the sprayer to the faucet. Gently pull down on the hose. If the connector is not a 2-piece cylinder, you need to push the connector up, as if you were connecting it, and while it is pushed up tight, pry up on the small ring on the top and gently pull down on the hose. I know it sounds like you need 3 hands, but it works (even though it is a pain).
Posted on Apr 22, 2010
SOURCE: Replacement Price Pfister sprayer/hose
I called Price-Pfister and they sent out the parts free under their warranty, plus a few dollars for postage.
Posted on Apr 26, 2010
  • 67 Answers
SOURCE: dripping faucet
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
Posted on Jul 26, 2010
My kitchen Price Pfister faucet is starting to "squeak" when I turn it on or off. What's up?
dry rubber "O" ring/ threads on the shaft
call a plumber to pull it apart , replace the seal and lubricate it
Dec 04, 2016 | Price Pfister Plumbing
How to disconnect the quick connect spray hose in a Price Pfister Parisa
I also needed to remove the "hidden" flow restricters from my Price Pfister Parisa Kitchen Pull out faucet. The hot water side had never flowed the same as the cold side. Now both sides are flowing the same as should have been all along.
Nov 30, 2012 | Price Pfister Marielle Kitchen Faucet with...
How to replace a price pfister kitchen faucet sprayer
The sprayer should have a threaded fitting on the end of the hose. Unscrew old one from valve, pull hose out the top, feed new hose back down into cabinet and screw in to where old hose was attached.
Sep 23, 2012 | Price Pfister Pfister T26-4ypu Rustic...
The top fell off the faucet, doesn't this faucet have a life time warrenty
Price Pfister Marielle Kitchen Faucets Do come with a limited lifetime warranty from Price Pfister-to the original home owner. You can contact Price Pfister on line at www.pricepfister.com, call them toll free at 1-800-PFAUCET or Email. The faucets warranty can be downloaded at http://www.pricepfister.com/support/warranty.aspx.
Sep 28, 2010 | Price Pfister Marielle Kitchen Faucet with...
Dripping faucet price pfister kitchen
Jul 25, 2010 | Price Pfister Savannah Two-Handle Kitchen...
Apr 10, 2010 | Price Pfister Marielle Kitchen Faucet with...
I have a price Pfister Marielle kitchen faucet. The valve body leaks when handle is in off position.
There is an o-ring around the valve body inside the outer shell. This needs replacing -- sometimes you can match these at hardware stores.
Shut water off, remove handle, pull up outer shell, you'll see the o-ring.
More info, let me know.
Charlie
Aug 28, 2009 | Price Pfister Marielle Kitchen Faucet with...
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Handle on faucet shuts off on its own
Dec 01, 2008 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
845 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
