Question about iLuv Creative Technology iLuv iMM727 Speaker System - Black
Need downloadable instructions for iLuv iMM727 speaker dock. Any ideas?
Manual for ASU-T102H-DR-GR
https://www.asus.com/ca-en/2-in-1-PCs/ASUS_Transformer.../HelpDesk_Manual/
  1. Cached
  2. Similar
ASUS Transformer Book T100HA. Overview · Specifications · Gallery ... Description, User's Manual for Simplified Chinese Edition. File Size, 6.83 MBytesupdate ...
Manual & Document - Asus
https://www.asus.com/us/2-in-1-PCs/ASUS_Transformer.../HelpDesk_Manual/
  1. Cached
  2. Similar
There are 3 download servers available on ASUS Download Site - Global, China and P2P. Each server provides exact the same content no matter where you ...
ASUS Transformer Mini T102HA ' 2-in-1 PCs ' ASUS Global
https://www.asus.com/2-in-1-PCs/ASUS-Transformer-Mini-T102HA/
  1. Cached
The ultra-thin, feather-light, 10.1-inch ASUS Transformer Mini is two amazing devices in one! Built from magnesium-aluminum alloy, it's a less-than-800g ...
[PDF]Manuale utente (e-Manual) - Asus
dlcdnet.asus.com/.../ASUS/.../T102HA/0410_I11845_T102HA_V3... - Translate this page Jul 25, 2016 - ASUS Tablet e ASUS Mobile Dock e-Manual. INFORMAZIONI SUL ...... T102H Mobile Dock, H102H Mobile Dock,. R106H Mobile Dock.
asus transformer user manual - YouTube
https://www.youtube.com/watch?v=M33hXCvS4Vc&list=UUy74e...d4uTA...
  1. Cached
Dec 20, 2016 - asus transformer tf101 dock user manual ... asus transformer tf101 keyboard dock manual ... asus transformer pad tf300t owners manual.
Dec 30, 2016 | ASUS Tablets & eReaders
How do you connect ipad to computer
To help you connect your ipad to the computer, please follow the step-by-step instructions given below:
- Turn both the computer and iPad ON before connecting.
- Plug the iPad's docking port into the appropriate end of the dock connector-to-USB cable.
- Plug the USB end of the iPad's dock connector-to-USB cable into an open USB port on your desktop. If iTunes doesn't open automatically, open the program to sync files and apps between the devices.
- Do not disconnect while the iPad is syncing or the sync won't complete.
- Remove either end of the cable to disconnect your iPad from the PC.
- After the first connection, you may choose to connect the two via Wi-Fi so you don't need to use the cable.
- Using iTunes, you can sync your audio, video, photos, apps and documents. This lets you transfer important files and apps you use for your business between your iPad and computer.
GuruAid.com
May 15, 2016 | Tablets & eReaders
Lost charger to Asus transformer pad tf300t was wondering if I could charge it through the USB port located on the side of the docking station
No, that is not possible. That's because you need an ASUS-specific charging cable to charge either the tablet or the dock/keyboard (or the docked combination of the two). You can however use any charger with a USB-port that outputs at least 2 Amperes. So you need to buy a new ASUS charging cable (and a suitable charger, if you don't have one already)
Mar 06, 2015 | ASUS Tablets & eReaders
Bubble dock has installed itself on my computer. How do i remove it
It sounds like you have been infected by a adware virus.
Your machine needs cleaning. Try downloading Malwarebytes to detect and clean the virus.
If you dont know how to do this, I would suggest it seek the assistance of a tech that can do it for you.
Feb 12, 2014 | Polaroid Tablets & eReaders
Imm727 will not charge ipad, i phone.
I have the same problem and found no solution. I realized this issue after upgrading to iOS7 iPad. With iOS 6 functioned normally to load, then not.
Mar 09, 2013 | iLuv Creative Technology iLuv iMM727...
USB port on docking station does not work
Power. You may find that the ower managment settings need to be changed or an external supply is needed.
May 28, 2009 | Motion Computing LE1600 Tablet PC
How do i download stuff to my hp ipaq?
Most programs you download to your computer and then install them to your ipaq while docked. You can try a free trial to make sure it works
Mar 21, 2009 | Tablets & eReaders
Tablet won't recognize USB drive
The guy's that can fix this are in the uk Sumo Technologies they fix all DTR products (address on DTR's website)
Jan 22, 2009 | Tablets & eReaders
Power port on le1600 does not charge batteries.
In some Motion LE1600 tablet pcs, the AC adapter port becomes separated from the motherboard. It will charge in the convertible keyboard or docking station because the power comes from the USB connection (for the kb) or the dock connector (for the FlexDock). Motion used to fix this by repairing the solder joint but now they just replace the motherboard (very expensive). There are ways to solder this but the repair doesn't always last unless you have someone really good do it.
Oct 24, 2008 | Motion Computing LE1600 Tablet PC
iLuv Creative Technology iLuv iMM727 Speaker System - Black Logo
56 people viewed this question
Top iLuv Creative Technology Tablets & eReaders Experts
Are you an iLuv Creative Technology Tablet and eReader Expert? Answer questions, earn points and help others
