Question about Cycling
Apache quadapache 450 rlx wont start?
Purchased an apache 450rlx other day, worked fine after the guy telling me it hadnt been run for 2 month... after about an hour onit, the bike would not start, theres no kickstart on these either, garage told me its a starter motor?? is this true coz i can fix it myself if its just that???
2 Suggested Answers
SOURCE: My apache rlx 450 sport Quad bike keeps cutting
i have the same quad with the same problem,its done every experts head in,take the seat off and look down the left hand side of the inlet manifold there should be a small peice of rubber hose about an inch or so,check to see if it has a screw in it or a plug if not put a screw in it,it will then rev higher just turn the rev screw on the right of the carb outwards untill tick over is about 1700rpm
Posted on Mar 06, 2011
Clutch is not working on my Apache 250s rlx 06 feels like clutch is there when pulling the lever but when you knock into gear just jumps and cuts out
adjust cable or bleed hydraulics
problem can also be caused from dirty oil or incorrect oil in the transmission/ clutch pack
Mar 17, 2018 | ATVs
Help apache rlx sx250 no spark
Voltage regulator
Mar 04, 2016 | ATVs
Ktm 450 2011 wont start up electrical problem?
Check the coils if it is fine change sparks plugs should solve the problem
Dec 17, 2017 | 2011 KTM 450 SXF
Sony bravia works on ups/battery not mains :(
Sure sounds like the power supply board received an insult that allowed a different voltage to work for a while . UPS will regulate top 120 volt whereas mains may be higher or lower . You may be able to change bad capacitors or just buy the power board between 80 to 200 dollars .
If it was connected to UPS during surge it should have been protected...make sure you are connected to 'battery' side as a lot of UPS have a 'surge only' side that will not stop a rapid on/off power insult .
Hugh
Mar 02, 2017 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Apache rlx 450 battery problems
Did u manage to solve the problem as im having the same
Apr 12, 2012 | kawasaki Quad Bikes
My apache rlx 450 sport Quad bike keeps cutting out when at stand still.
Jul 09, 2010 | Cycling
I have a Troy-Bilt 31cc 2-Cycle Gas Powered that doesn't start
Coil bad or wire to coil bad. I tell everyone what Ill tell you,when it comes to small engines,troy bilt,poulan,weedeater brand all JUNK,JUNK JUNK! Theyre made cheap,not built to last,theyre throwaways. Carbs are made in china. If youre ever in walmart next time go back to the garden section and pick up a weedeater or poulan brand chainsaw or trimmer. Look at the package good and look at the factory life expactancy. Its not in months,not even days,but in hours. If I was you I would tell myself NO MORE! I would buy a dolmar or stihl,pay the extray,cause you wont be aggrevated in the long run. P.S. Dolmar offers a 100% coverage for ONE YEAR on all equipement.
Aug 10, 2009 | Troy-Bilt Garden
Car died the other day, and now it wont start. Everything such as dash and radio seem to be working fine.
hi there the things to check are do you have a spark at the plugs?
do you have compression ?
are the cam shafts turning?
is the cam belt intact?
this are all needed to make the engine run it will turn over great but not start with this things not working infact if the last 3 are not there it will sound diffrent when you are turning it over with the key.
hope this helps Regards JR
May 30, 2009 | 1995 Oldsmobile Cutlass Supreme
Cycling Logo
56 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
