Question about Refrigerators
How to replace valve water lg refrig mod gr p257btba
5 Suggested Answers
yeroc
  • 397 Answers
SOURCE: lg fridge
heating element seems bad,,sometimes a easy fix
Posted on Jan 20, 2008
  • 1073 Answers
SOURCE: The water compartment of my
the line may be frozen inside the door of the freezer
Posted on Apr 17, 2008
MARCLAVORIS
  • 110 Answers
SOURCE: Kenmore refrig mod # 507920. Icemaker working
check to see if the hose going into icemaker is frozen. unclog it
Posted on Aug 24, 2009
  • 183 Answers
SOURCE: My KTRC22E kitchen aid refrig. stopped making ice. I replaced the valve that ties into ties into the cold water line. The drinking water in the refrig is working properly. I'm told it may be th
sounds like you have a problem with the fill tube at the Ice Maker. remove the IM and then the back wall ( evaporator cover ) , the fill tube is probably frozen. use a hair dyer to melt ice, be careful, the hair dyer can melt the fill tube and other plastic.
Posted on Jan 07, 2012
New LG LFXS30766S refrig. Water disp.not putting out full stream of water despite doing what the manual said to do. Old Maytag refrig. I had put full stream of water with no problem.Any suggestions?
LG refrigerators are notorious for junk water valves. IF you have replaced the filter, then your next item is to replaced the water valve. AJU72992603
Jun 22, 2016 | LG Refrigerators
Ice maker does not make ice.
The water tube to the icemaker inside the refrig may be frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | LG LMX25981ST Stainless Steel Bottom...
Refrigerator makes ice and dispenses ice, but does
could be valve, it is located underneath on back. it also could be the mother board. Check valve with ohms metter. Also make sure water resevior or water lines are not frozen inside refrig section. Also water feed line going up through door bottom hinge on freezer is not frozen. Disconnect at couplin at left bottom front and blow through line
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Why is water leaking out of my kitchen aid frigs water dispencer?
Bad water valve, not shutting off all the way, replace water valve located on rear of refrig. Just follow water line from wall to water valve(may be by way of filter), unplug refrig from wall, remove rear cardboard or steel cover and you will see valve.
Oct 17, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Why is the ice maker not droping ice / Mod. ET1FTTXKQ00 / Type C21TFA01 Whirlpool 08-01
Take a 4 inch piece of 14 gauge insulated wire and strip 1 inch of insulation off each end. Bend the wire into a U shape.Remove the plastic cover from the front of the icemaker. Insert the bare ends into the terminals marked T and H on the face of the icemaker. The wheel should move and dispense the ice into the bucket. If it does not move and drop the ice replace the icemaker.
Aug 30, 2009 | Whirlpool Refrigerators
Aug 24, 2009 | Refrigerators
Hi I have the lg gr-151ssf it has a strange tube hanging inside hanging hown from the back ice box dont know where its supposed to sit or be. in the drip tray of the ice box ?
Its actually supposed to be resting on the bottom and top taped to the back wall of refrig. This is there to store water before use to pre-cool it for the water dispenser. They do fall from time to time.
Jun 15, 2009 | LG Refrigerators
Lg gr l207tlq fridge does not stop running water
That means that either the inlet valve located at the back of the fridge is broken (most common) or there is a bad wiring to inlet valve, and valve does not close.
May 01, 2009 | LG Refrigerators
Water coming straight through LG SxS fridge freezer
Most likely the pipes were disturbed a bit while remodeling, causing a particle to flow to the inlet water valve and prevent it from closing completely. You will probably have to replace the water valve part number 6877JB3053D (note, if you would have run a gallon water out the water supply tube prior to hooking the water line back up to the refrig. you would not have had this problem)
Nov 21, 2008 | LG LSC26905TT Side by Side Refrigerator
Lg fridge
Jan 20, 2008 | Refrigerators
Refrigerators Logo
20 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
