Question about Refrigerators
IsoTherm replacement I have a 10 year old Isotherm refrigerator, MOD 1012002, S/N 34071. It does not work. I want to get a replacement. Rather than remove the unit, I want to know what the cut-out dimensions are for it, at least at its minimum. Is it possible that you could send me the cut sheet for this unit? In addition, is there a current unit that you know would fit the same dimensions of this space? Looks like the Cruise 130 (12V D/C and 110V AC) is pretty close.
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
SOURCE: Specific dimensions of a side by side model 532
FINISHED ROUGH OPENING DIMENSIONS: WIDTH = 47 1/2" HEIGHT = 83 3/4"
DIMENSION OF 532: H=84" W=48" D=24" MINIMUM HEIGHT=82 7/8" DOOR SWING=29 1/4"
Posted on May 02, 2009
  • 864 Answers
SOURCE: Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
Posted on May 30, 2009
  • 101 Answers
SOURCE: Can we retrofit our 20 year old KitchenAid Superba Refrigerator
Refrigerator efficiency is dependant on multiple things...
compressor efficiency
Refrigerant used
Size/type of evaporator
Size/type of condensor
Ambient temperature
Insulation used and thickness of
There have been some advances in compressor efficiency in the last twenty years but if your unit is using R-12 it would most likely have to be upgraded to R134a due to environmental regulations. Therefore, without a major redesign of your unit to include resizing the system and somehow adding insulation, updating to the newest and greatest compressor will really not gain you much in efficiency and cost as much or more than an entire new unit.
There are still units made without stainless. Unless your unit is a power hungry monster (and yours is not) I doubt a new unit would save you more than a buck a month in power savings.
I wish I could make a recommendation for you but I do not know the market well enough. I know if I were in your place I would hang on to my unit for as long as it works well and continue to save up for a higher end model (with the best warranty/service plan) and look ofr the best replacement out there.
Note: Beware of high end units that are just high priced due to looks. Most units these days are made from the lowest bidder parts (world-wide) and even if they look awsome and have high quality standards during production are subject to the "roll of the dice" due to the cheap electronics used for controls.
Good-luck, Subdriver
Posted on Apr 04, 2010
Testimonial: "Thank you for your comments. However, your remarks did not suggest where we might find the replacement compressor - e.g. company name etc"
heatman101
  • 43501 Answers
SOURCE: Is a 10 year old GE Side by Side refrigerator
Yes and no... the problem may be simple...check out these tips before replacing it...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 17, 2010
I HAVE A 21 YEAR OLD GE FRIG SIDE BY SIDE MOD. # TFX27PFSA. HOW MUCH AIRFLOW SHOULD BE COMING INTO THE FRIDGE ? FREEZER IS 10 DEG. & FRIDGE IS 60 DEG. IM NOT GETTING ENOUGH COLD AIR TO FRIDGE & EVAP COILS...
You are correct -Temps not low enough and you have been thorough in checking things out. About the only thing I can think of now is to make sure that the condenser coils underneath are perfectly clean to promote max efficiency. If clean, and we know your compressor is running after all these years You may be, yipes, low on refrigerant. I am sure you have thought of that but did not really want to deal with it - don't blame you. If you want to pursue that venue it is a PIA but can be done, CAREFULLY because the freon level on refrigerators is a critical parameter, not like a room or car AC. If wanna try relist your question as DIY refrigerator charging.
Sep 02, 2017 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker stopped working on bottom freezer amana. Is there a reset button?
There is n such reset button,but first check and confirm that water line is running in to the ice maker drawer.Is the water getting into icemaker or not.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Amana ARB2214C Bottom Freezer Refrigerator
I need smaller ice cubes from my Maytag Mod. #PSD2450GRW
HI,.shot in the dark.lower your water pressure. a tiny winnie bit.might work.good luck.Ali
Jun 28, 2012 | Maytag Refrigerators
My 10 year old Kenmore "coldspot" has stopped cooling; the freezer is completely off. It was fine yesterday. Could it be the compressor?
the answer to your question is [yes]or the gas in the system is expelled and needs replaced if this machine is 10 years old take my advice and replace the refrigerator as it will cost more to replace plus an engineeers costs.[buy a new one].adrian
Mar 15, 2011 | Kenmore Refrigerators
We own an Amana bottom freezer; Mod.# BC120TW, Ser # 9708176268. It is approximately 10 - 11 years old. The freezer is not getting to a low enough temperature. We have soft ice cream etc. I have cleaned...
If it is constantly running, (compressor and the fan inside of freezer) then the thermostat is working, more than likely you have an inefficient compressor or a low charge in the sealed system due to a refrigerant leak. Touch the compressor, is it almost too hot to touch? Do you hear a buzzing and clicking noise every so often? If you can answer that for me, I could better diagnose it
Jun 15, 2009 | Refrigerators
10 year old refrig cools only if freezer temperature is on maxium
heatman101
Apr 18, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Stopped cooling
Hello cpuklutz
Welcome
You said, Kenmore; 21 cu ft; 10-years old; just stopped cooling; wondering if it even makes any financial sense to get estimate to repair, or is 10 years about it's trouble free length of service
Here is an article that you may find useful and interesting related to your situation.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thank You, HUUUM
Please remember to enter a rating before you sign off!
Sep 29, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer works but frige dosent get cold enough.
Welcome to fixya richarddl53,
You said, you have a side by side about fifteen years old need to know what type freon to charge it with.
The freon that's used in the old refrigerators is not legal now!
They started using a newer kind of freon years ago that does not deplete the ozone layer.
Yes you are low on freon, but that's because you have a leak somewhere.
And if by chance you could acquire the freon that you need to add into the older model fridge, it will just leak out again shortly!
My opinion is that you should not put good money into bad!
A new refrigerator uses less electricity than a fridge that is ten years old.
And yours uses 10% more than that!
you will see the differents in you utility bill as it will pay for it self in a few years!
I just read this report you may find interesting.
Repair or replace?
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 27, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Gas dryer
Hi Mette-q,
Welcome to fixya.com
I'm Huuum,
You said,you have a Kenmore gas dryer mod. 110.95087400 ser. ms0201135 it's a smartheat quiet pak9. Is there anyway I could convert this from natural gas to electric, is there a conversion kit available.
They do have conversion kits for gas to LP.
But I believe that there is no gas to electric.
You must find a gas line from some where in the home and run it to your location, or buy an electric dryer.
Remember that if you can run a gas dryer it will save you 30% on your energy bill over electric and in time pay for the cost of running the gas line to it.
I hope you are not in an electric only house!
How old is the dryer?? Waiting for your response!
Thank You, HUUUM
Here is a interesting report that I just read today
Repair or replace?
Sep 22, 2008 | Kenmore Elite HE4 Electric Dryer
Fridge compressor problem ?
Seems to me you have a faulty cold control. (behind the temp control).Not too expensive , about 40 bucks.
Feb 23, 2008 | Refrigerators
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
