Question about Boating
Outboard motor wont start
Bought brand new sat.and went right buy what the manual said run it yesterday just fine today cranked it up let it ideal and checked water flow was good and give it a little gas and it clanked and died and want even try to start has spark called coleman about it they want me to take it to get it looked at a shop they refer me to.depressing for sure
playon186
  • 45 Answers
SOURCE: engine overheated, now car won't start without giving it gas
Some cars cut off as a fail safe to overheating especially on newer cars. The computer controls the fans and if they are not working the computer is probably telling the car to shut off. Have you replaced the motors already, if not, this is what's happening. Once you replace the motors it should run fine. I wouldn't suggest driving it too much with this problem as it may affect the computer by giving it false info.
Posted on Nov 03, 2008
  • 376 Answers
SOURCE: mantis tiller sv-4 echo engine no spark from coil
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
Posted on May 31, 2009
DoubleClutch
  • 376 Answers
SOURCE: 94 intruder 1400 wont start
Ok you have done all that is needed so far but as I understand you are saying that it is trying to turn over? How fast does it turn over? And do you have spark? Test the plugs by pulling one of them out at a time and grounding it to the engine and try turn the engine over a couple secounds while looking at the plugs. You should have a bright blue spark form all plugs. If you are needing any more help let me know.
Posted on Sep 17, 2009
Testimonial: "hey i have tht intruder tht sat 4 year was i checked the plugs, but there was u spark or blue light form either one so do u have any more suggestions"
Editor925
  • 285 Answers
SOURCE: I bought a 5 HP gamefisher outboard motor. It
If spark plug is dry, fuel is not getting to the cylinders. Next thing to check would be the fuel pump... Gas may be getting to carb, but the pump needs to push it into the cylinders too.
Posted on Oct 18, 2009
SOURCE: 1987 Bayliner capri 85hp force starts and idles fine,after it
if u have a seperate onboard tank i bet its the vent valve is closed
Posted on Jul 20, 2010
2011 f150 want start just click has new battery worked fine yesterday today want start just click
Possible internal starter problem. Try tapping on starter motor while key is held in crank position. If vehicle starts, suspect a starter motor problem and replacement will be required
Feb 28, 2016 | Cars & Trucks
Can't get the ideal set right
Is the exhaust converter over 12 years old
& restricted
How about mechanical timing of motor
Low idle- you check engine vacuum & timing,
as well as ignition timing
Have to stay with the so called old school basics
people seem to forget about
How about vacuum leaks,fuel pressure,battery
voltage,alternator problems
It all effects todays electronic vehicle systems
Mar 01, 2013 | 1994 Toyota Pickup
My truck sat up for probably 3 or 4 years cranked and run fine yesterday but today it wont crank at all any ideas?
If it won't crank over, it's not a fuel issue, but a starting circuit issue. The gas may be stale, but if tank was full all that time, I don't think that would be a problem.
Pull off the small wire on the starter solenoid, and see if it has power when key is held in crank position. If power there, the starter or solenoid or the battery connections from battery to starter need to be checked or tested. If no power to solenoid when key is in cranking position, the ignition switch may be bad or the neutral safety switch (or the clutch start switch if a manual) or the starter relay needs to be checked.
If you get it cranking, and still no start, look down the throttle body bore and watch your injector spray pattern while the engine is cranking-you should see a fine, cone spray pattern coming from the bottom of the injector. If it just drips and no cone pattern, or no gas coming out, injectors need cleaning (probably from stale gas). Good luck.
Oct 23, 2012 | Cars & Trucks
I have just bought 2 midi ATV quads, I got one started yesterday and today it won't start and keeps popping when pulling the cord to start. The other one I think the engine has flooded as there is...
If it started yesterday you might have fouled the spark plug or check crank case, air intake system, and exaust pipe for dirt dobber nests if both have sat up for some time I had this problem when I bought one of the same 4wheelers what happens is the crank case builds pressure also the exaust builds pressure and will not let the motor run check for ignition spark parts are vary cheap for the pocket minies check ebay i got a exaust pipe for 13 dollers 49cc also check motosports max.com or type Kazuma.com in your search bar
Jul 23, 2011 | Quad 47 cc / 49 cc Pocket Mini Bike...
Free download for repair manual for an Evinrude 1987 40HP outboard motor
My outboard motor is old and used.When I went to run it for the first time everything worked except when I went to put it in forward gear the boat went slowly but when I gave it more gas the engine just reved up but the boat wasn't going any faster.The motor is 40hp gale model.I think because it is bought used the prop is not the right one and it seems like it's slipping as I go faster.
I would appreciate any feedback on this problem.
Thax, Don
Apr 27, 2011 | Clymer Marine Maintenance and Repair...
My buddy has a 89 pontiac sunfire. It sat for a while and he just started driving it, let the gas run out and put new in and then it stopped running. Today we sprayed starter fluid into the throttle and it...
You could have a bad pump motor in your fuel pump. You will hear the "hum" of the pump motor but it won't continuously feed enough pressue to the system.
When you prime it the engine will draw enough to run for a bit then quit. They usually dry out if not kept full and sunfire fuel pumps are noted for this type of failure.
Try a used one for about 75 bucks. My kids Sunfire did exactly the same thing.
Jan 19, 2010 | 1989 Pontiac Sunbird
Wont start
Try this sequence. Pump up the fuel bulb until it gets hard. There should be something equvilent to a fast idle setting, then hold in the primer(electric choke) and finally turn the key and crank. When it tries to start go easy on the electric choke. You may want to see if the electric choke moves freely.
Mar 23, 2009 | Light Outboard Motor Boat Bass Fishing...
1999 blazer wont start??
Your battery is either faulty or ther is a parasitic drain, have it checked out at parts house. With a good battery installed, spray some starter fluid into intake housing. If it starts, then dies, you have fuel pressure/delivery problems. Can you hear the fuel pump run when you turn on the key? Hope this helps.
Dec 18, 2008 | 1999 Chevrolet Blazer
Boating Logo
61 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
