Question about Jensen SRWS-1000 AM/FM/Weather Radio
Owners manual Lost manual. How to set to two counties only not all. Thanks
How do I add another tax (county) to my register
You set a tax rate to the next tax setting available e.g tax2. Then you link each product that uses that tax to T2 in the settings for the product (usually PLU prog). There will be various codes to do this in your manual. If you have lost it, one of the users has most programming manuals here:
https://the-checkout-tech.com/
May 27, 2016 | Retail Supplies
I have a Oregon Scientific weather radio. I have lost instructions and am try to figure out how to set alert status by counties.
From the Oregon Scientific site top ten questions: click the link below to download the manual for the model number of your radio:
Manuals XF
Apr 08, 2015 | Oregon Scientific Audio Players &...
2001 dodge durango R/T 5.9 liter owners manual
You;d be best to contact the dealer for an OWNERS MANUAL.
If you are looking for a REPAIR MANUAL:
Check your local library and by calling ahead, ask them to check the county wide branches as it may only be at one branch, not all. You could alternatively get one at your local auto parts store for about $20. WHAT you would be asking for is a HAYNES or CHILTONS Repair Manual.
Please provide feedback - thanks
Best regards
Ck
Oct 03, 2011 | Cars & Trucks
How to find correct county
A. First, determine the counties you are interested in. Then do one of the following
three steps to get the codes:
1. The National Weather Service Toll-Free Number provides S.A.M.E.
County Codes at: 1-888-NWS-S.A.M.E or (1-888-697-7263)
This is what to expect when you call the NWS number. When you call the NWS
toll-free number, automated instructions will guide you to the S.A.M.E. County
Code(s) you need. The number will be six digits long.
• You will hear, "Welcome to the National Weather Service. You have
reached the Specific Area Message Encoding Program Service."
• If you select "touch-tone" to make your entries, you will be prompted to
enter the name of your state using the telephone keypad.
• Next you will be prompted to enter your county name.
• Then you will hear, "Your geographic code is xxxxxx." (This is your
S.A.M.E. County Code.) Be sure to write it down for future reference.
The system will then give you the option to enter "another combination": This
enables you to get additional S.A.M.E. Codes for surrounding counties.
2. The Internet Web Site of National Weather Servicewww.
nws.noaa.gov/nwr/indexnw.htm.
This is what to expect when you go to the website.
• The link above takes you directly to the list of states.
• Click on (your state).
• Find your county, and record the "S.A.M.E. #" (the S.A.M.E. County
Code) that is listed to the right of your county, and for any other counties
in which you are interested.
WR-100 Owner's Manual
Page 8 www.midlandradio.com
3. Go to the Midland Radio Corporation website at www.midlandradio.com
• Click on the weather radio link at the top of the page.
• At the top of the weather radio page will be the link to the NWS list of
states and corresponding county codes. Click on the link.
• Click on your state and a list of counties and codes will be listed. Locate
your county and then find your code.
To set the country follow the below steps:
A Single S.A.M.E. County Code:
Press "MENU" button to open menu options.
• Press the "UP" arrow to scroll through menu options until "S.A.M.E.
SET" is displayed, then press "SELECT" button.
• Press the "UP" arrow to scroll through: "SINGLE", "MULTIPLE", or
"ANY."
• Display "SINGLE", then press "SELECT." "S.A.M.E.01" will be displayed.
(Note if you are programming a single S.A.M.E. County Code, only the
"01" setting will be used.) Press "SELECT".
• Using the "UP" arrow, find the first digit of your S.A.M.E. County Code.
Press the "RIGHT" arrow to save the digit and automatically
advance to the next digit.
• Program all digits of your S.A.M.E. County Code in the same way.
• Press "SELECT" to store your S.A.M.E. County Code. Press "MENU"
to close the programming menu.
Helpful Tip: The S.A.M.E. code is created using the following method:
• The first digit is the subcounty code-currently 0 in most areas.
• The second two digits represent the state code.
• The last three digits represent the county code.
Multiple S.A.M.E. County Codes:
"ANY."
• Display "MULTIPLE" as explained, then press "SELECT".
"S.A.M.E.01" will be displayed, indicating you will be programming your first
S.A.M.E. County Code at weather radio menu location "01."
• After programming your first S.A.M.E. County Code, press "SELECT" then
the "UP" arrow to advance to "S.A.M.E. 02." Program all of your S.A.M.E.
County Codes in the same way as above.
• When finished entering all your codes, press "MENU" to
Hope that helps.
Regards
Anand
Apr 27, 2011 | Midland WR-100 Weather/RDS Radio
How to get the Ross County, Ohio code
Go to http://www.nws.noaa.gov/nwr/indexnw.htm#sametable and click on Ohio then find Ross County. The code is 039141 out of two NWR transmitters in Chillicothe and Otway. (The website to obtain this info was printed in the owners manual. ;) )
Oct 29, 2010 | Eton Solarlink FR600 AMFMWeatherSW Radio
Need flash card data
only the counties loaded on the CF card would be lost - the main base map is in the units' main memory. If you have both disks simply copy the wMap program over to your PC to download counties to the CF card. See Whistler's FAQ page for more info on Galileo GPS unit.
Jun 13, 2008 | Whistler GPS100 Galileo GPS Receiver
Jensen SRWS-1000 AM/FM/Weather Radio Logo
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
