Question about Dura-Block Commercial Spray Gun - AFB7S
Need assembly page
Spray gun for cambell hausfeld model.#al2305-02..where can i get one
http://www.searspartsdirect.com/partsdirect/part-model/Campbell-hausfeld-Parts/Painting-equipment-Parts/Model-AL2305/0166/0733055
Dec 14, 2014 | Air Tools & Compressors
Iwata eclipse G6 airbrush gun - no paint flow, bubbles forming in gravity feed bottle.
it is rather large (usually 0.6mm nozzle) airbrushing gun,
symptom indicate that needle is closing the nozzle and not retracting, gun need cleaning! or adjustment - seem like both...
remove paint from the feeder, remove feeder bottle from the gun body, clean it well with paint stripper and then solvent/water allow it to dry
remove front casing from the gun and check for any physical debris around the needle or in the chamber, carefully clean without damaging the needle. needle is stainless should be nearly mirror finish.wash with solvent and use toothbrush - DO NOT USE METAL BRUSH!
put it back together and check if it works correctly, if you have any flow from the front - fill about 1/3 of the tank with paint stripper and then spray it to the sink or whatever other safe place. do not forget to wear safety mask, goggles and gloves! paint stripper will eat through your skin! if you splash yourself, have few spoon of vinegar mixed with 2pints (1 liter) of water and this solution will deactivate paint stripper! SAFETY FIRST!
if gun still do not work - you need to strip needle assembly and clean it correctly, put your gun on the table on butcher paper, remove screw holding needle on the back (watch for the spring!) put whole assembly on the paper in the order in which you removed it,
clean needle and needle seat, lightly grease it with vaseline and in reverse order put it back together.
regulations:
very bottom screw - this close to the airhose, it regulates volume of the air to the gun, you very rarely need to adjust that one, you increase volume with haevy paint and decrease it with light paints
needle screw - it regulates volume of the paint itself, closing it clockwise will decrease amount of paint, anticlockwise will increase volume of paint
top screw - it regulates the spray pattern, totally closed - round pattern as there will be no flow to side vents, more open, more flat the spray pattern,
i would suggest fill the bottle with water and put some butchers paper on the wall and experiment what is what and what pattern is most suitable for your use.
hope this little info will help you solve your problem, it is good you give the model, it will be better if you provide as well what medium you use, was it acrylic, oil, water based? all of them behave little bit differently in airgun...
please do not hesitate to leave your opinion and points... thanx!
Oct 04, 2013 | Air Tools & Compressors
If air supply in mask hooked up can sprayer gun work correctly
you should put an inline air flow valve in the line for the mask you can put a T connector on the end of the hose so both the spray gun and mask can use the air line at the same time. It will work well if the compressor is large enough to handle the CFM of both the gun and the mask
Apr 04, 2013 | DeVilbiss MPV-625 Air Vizor Air Supplied...
Air feed through gun with out touching the gun
take and screw out your top knob which is your fan control and clean it and also make sure none of the rubbers and seals are cracked, it might be possibly out of adj, but probably just dirty with old paint, clean it out really well with pipe cleaners or brush with paint laquer thinner
Sep 16, 2011 | Binks 54-1341 Air Valve Assembly For 7...
Can I use my Kirby Spray Gun for coating a paint over the wooden items like windows, wooden shelters etc.?
It can be used, but be sure to use a water based, non-flammable paint or stain. Blow the dust out of the hose before attaching the spray gun.
Sep 01, 2010 | NRS KIRBY UG/DE&G3 SPRAY GUN ASSEMBLY
My Kirby G3 paint attachment isn't spraying the paint. I have everything hooked up according to the manual, and it sprays a continuous stream of air, but isn't sucking up the paint to spray. Sometimes I...
mcdevito75 here, Sounds like it"s cogged with paint, the paint is not being sucked up into the Spray gun itself, the air flows thru thr spray gun thru the trigger assembly. Follow the makers cleaning of the spray section of the spray gun. Try running paint thinner thru the spray system. Hpope this helps.
Jul 19, 2010 | Kirby Generation 3 Bagged Upright Vacuum
When tank pressure is on gun sprays without trigger pulled
The only seals I know of that would cause this are around the spindle assembly. If you have changed these then you may have a problem with the seal retainer, a weak spring or bent spindle. Also make sure there are no metal shavings to hinder the sealing. Sometimes they can be left in the gun during machining process.
Hope this helps but if not please let me know and I will try and trouble shoot further.
May 14, 2010 | Binks MACH 1 HVLP Pressure Feed Spray...
Siphon tube on cup gun blows into the cup
Other than a missing or deformed gasket ring around the nozzle assembly, there might be a gun casting leak from the air passages to the fluid passages. Hope this helps!
Apr 02, 2010 | Binks SPRAY GUNS & OUTFITS
Dura-Block Commercial Spray Gun - AFB7S Logo
37 people viewed this question
Top Dura-Block Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Dura-Block Air Tool and Compressor Expert? Answer questions, earn points and help others
