Question about Crosley Conductor CR73 Turntable
Motor 6T3RWKO 9v 12v cw
No work
Itching after colour my hair and after blow dry my hair
you need to wash your hair....If you wish to get some details; check the site linked here.
AmanStino Car Charger Quick Charger USB 3 0 3 Port with Smart Sense IC...
Nov 29, 2016 | Health & Beauty
88 shows up when i turn projectmix on
It sounds like an adapter issue. The PMI/O say's to use a 9v adapter, but the manual on page 9 says 12v. Try 12v if you use 9v or vice versa.
Powering on while holding the Zoom button will enter a test mode.
To do a reset. Setup>Factory Defaults>SEL>Yes
Nov 26, 2015 | M-Audio ProjectMix I/O
What kind of fuse do I need for the symbol 4 slot battery charger
The UBC 2000 Fuse part number: 217005 (5A 250v Quick Blow), orderable from Little Fuse (Phone: 847-824-1188).
Apr 27, 2014 | Symbol 4 Slot 4 Sled Universal Battery...
I Have A Nikon Coolpix s210 Camera And Everytime I Plug It In To Charge With The Wall Charger It Doesn't Work..But I Don't Have The Separate Battery Charger.Any Ideas Why This Happens?
HiIn order to check quick, you might need extra battery. In your neighbor some who has multimeter you get help from them. Or your local repair shop could help you easily.
Jun 02, 2011 | Nikon Cameras
Power pack creates 'hummmm' in wireless headphones.
I don't think the 12V power pack is the problem. Generally there would be a regulator on the plug pack input to the transmitter (as power packs are notoriously bad at voltage regulation).
My guess is it an 'earth leak' between the TV and the transmitter via the audio lead. Does the powerpack have a earth pin. If so, are you able to plug it into an non-earthed power outlet.
If this isn't possible try removing the ground connection from the audio lead.
It could also be a bad audio lead.
Is the TV mono and the transmitter stereo or visa versa? You may need a mono to stereo lead.
Hopefully something in here will help.
Mar 17, 2009 | Electronics - Others
Power pack creates 'hummmm' in headphones.
GKLHKJHKLHKLHKLHKLHKJLHKL
please rate this solution?? hahaha lol here you go
Mar 17, 2009 | 1996 kawasaki ZZR 1100
Durabrand DUR-7 dvd player
the 12 volt car adapter only puts 9v to the dvd player. It is poorly marked. It really only runs on 9v. If you plug 12v into it it will smoke... thats what mine did.
Aug 14, 2008 | Durabrand DUR7 Portable DVD Player
Crosley Conductor CR73 Turntable Logo
119 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
