Ruud model ugfd getting fault code 68 no signal
Working on a ruud furnace outside condenser comes on but no blower on furnace getting fault coed 68 no signal tried heat and fan on stil same problem no blower what does no signal mean
  • 25 Answers
SOURCE: ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Posted on Nov 22, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Carrier 58MVP; Blower on, no
A code 12 is "Blower on after power-up" Try resetting the furnace with either the Emergency switch or circuit breaker. If it continues, you may need a new control board.
Posted on Nov 28, 2008
SOURCE: Clunk noise Ruud Furnace
I had the same problem, the motor shaft and bearings were going bad. There was about 3/16" travel on the shaft that the blower attaches to. I replaced the motor myself and it runs nice and quiet. I have had that noise that you describe for over 8 years, but it got real noisy about a week ago. I talked to the maintance department about it where I work and they said the motor bearings were probably going bad. They were right, I took the motor out of the furnace and they took it to a parts store and got me a new one $270.00 for it. It is a special motor due to the fact that the frame mounts bolt directly onto the motor housing. Make sure if you do this job yourself that you take the motor to the parts store so that they can match it up. The guy at the store told our maintance man if it didn't require the bolt holes in the motor housing it would have been $100.00 cheaper.
Posted on Dec 24, 2008
  • 10 Answers
SOURCE: ruud heat pump
If I understand what you are saying, when your stat calls for cool the unit blows heat and when in heat mode it blows cool. Is this correct?
The problem is on a Ruud unit it does not use an "O" terminal it uses a "B" terminal (Reversing valve energized for heat) where all others use the "O" energized for cool mode.
As for the contactor not closing you need to determin if there is 24 volts between "Y" and "C" at the unit, if not then there is an issue somewhere up the line interupting the voltage, if there is then the fault lies at the unit, defrost boaard or pressure switch. call me and we can diagnose over the phone, this is what I do.
Richard (Rick) Drennan
Global HVAC Distributors
RUUD Field Support Representative / Instructor
rdrennan@globalhvac.com
900 Spreckels Ave
Manteca, Ca. 95336
Office (877)448-7263
Cell (209)456-0513
Posted on Jan 05, 2009
louislevel_2
  • 374 Answers
SOURCE: my outside condenser fan motor hums and slowly
hi there,
check the capacitor of your condenser fan,if busted replace,although thats the common causes of hummimg motor,it can't start,consider also after replacing capacitor still hum,check the motor start winding,and the supply from the source of relay in control panel.have a nice day
Posted on May 08, 2009
Ruud achiever 90 plus furnace-water leaks from the drain pipe
This furnace should condense, as long as it goes into the drain. If it is leaking inside the furnace, there may be a seal that needs replacing in either the pvc drain pipe or concentric drain trap needs resealed.
Feb 21, 2015 | Ruud Heating & Cooling
Ac blower motor attic
that is a model number for the outside condensing unit. to find the motor size for the inside unit, you will need the model off of the inside unit, gas furnace or electric air handler.
Aug 15, 2013 | Ruud UAKA048 Air Conditioner
Ruud achiever 90 condensation overflow
Not a furnace guy but I do know that your drain should be insulated. Gotta figure out if it's water from the drain leaking or actual condensation dripping from the outside. If sweat, it needs insulated. Good Luck.
Mar 11, 2017 | Ruud UBHC Air Conditioner
Ruud AC unit outside won't start, furnace and blower inside work.
It sounds like your at the point where you need an electrical meter to check out the problem. Make sure you have the proper voltage to the outdoor unit. Could be a bad contactor in the outdoor unit
Mar 01, 2017 | Ruud Heating & Cooling
All my other AC Units have had a drain directly to the sewer system...usually connected under a sink. Does my Ruud unit only have the drain to the outside of the house? Usually, when the AC is draining...
If you have a CENTRAL air unit, you should have an overflow to a drain in the furnace area. So I don't understand what you are saying about a connection to the drain under the sink!
Do you have the make and model correctly listed? Because with your question it does not agree what I know about the Ruud Central air that you listed.
Aug 08, 2011 | Ruud UBHC Air Conditioner
From the Isolator panel, how do I connect the condenser, and the blower?
MOST UNITS NOT HEAT PUMPS  WIRE UP WITH 2 WIRES TO CONDENSER RED WIRE AND WHITE . WHITE GOES TO COMMON C ON FURNACE AND RED TO Y TERMINAL OF FURNACE Y ALSO GOES TO Y ON TSTAT. BOTH YELLOW WIRES MUST MEET AT Y OF FURNACE.  WHITE FROM STAT TO W   GREEN FROM TSTAT TO G AT FURNACE IF YOU HAVE C ON TSTAT HOOK UP BROWN WIRE OR BLUE FROM COMMON TERMINAL WHERE YOU HOOKED UP CONDENSER WHITE WIRE AT FURNACE TO TSTAT , MOST THERMOSTATS DONT NEED C RUN FROM FURNACE. THE TWO WIRES GOING TO CONDENSER IS -  AND + TO ACTAVATE CONTACTOR IN OUTSIDE UNIT
Apr 19, 2010 | Ruud Central System Air Conditioner
What is the efficiency rating on the Trane model BLU055E936B1 upflow furnace and what new furnaces are available to replace this old Trane furnace without having to change the venting system.
Chances are you need to replace both the condenser and furnace, then you you should get a varaible speed blower with the new furnace, get at least a 90% gas system with a 16 SEER condenser, save on energy cost as soon as it's installed. Go Get IT
Jan 28, 2010 | Ruud Central System Air Conditioner
Ruud furnace Model URKA A030jK08 Code opt 589
Flip the lower panel over and look for a wiring diagram. On that diagram there will be a diagnostic chart. Let me know what 5 blinks represent. Then I want you to read on.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Nov 23, 2009 | Heating & Cooling
You can hear furnace running but the blower never comes on.
do you mean the inside blower or the outside unit blower ... actually the problem might be a similar part in either case ... the blower motor has a capacitor mounted on it or near it ... it will be marked something like 160 uf at 200vac or similar . it will have wires attached or plugged into it .. the capacitor is what gives the blower motor a signal to tell it which way to start turning ... once the blower is running then the capacitor is no longer needed ... its only used to get the motor started ... if its bad then the motor will hum but wont turn .. if you manually spin the fan then the motor will take off in the direction you spun it (dont get hit ) .. a new capacitor is not expensive .. you need the numbers off the old "starting" capacitor or just take it with you to the parts place to match it up .. you may be able to order it from Ruud ... a HVAC repair person would likely be able to bring one with him for repair if you give him the numbers off the part or the model number of the furnace .. make sure the blower turns freely by hand (with power off) .. if not it may need bearings lubed .. ..
Nov 05, 2009 | Ruud Central System Air Conditioner
Rheem Central Air united stopped working, no hum but power is there
It looks as if the 24 signal from the thermostat is not getting to the contactor. Or possibly the coil in the contactor itself is dead. Or a third option may be a bad control power board in the condensing unit itself. If you feel comfortable reading through these devices comment back. PLEASE REMEMBER THERE IS HIGH VOLTAGE INSIDE THE CONDENSER AND A CAPACITOR.
Jul 06, 2008 | Ruud Heating & Cooling
Heating & Cooling Logo
130 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
