Question about Body by Jake Ab Scissor Exercise Equipment
Assembly instruction manual for ab scissor - Body by Jake Ab Scissor Exercise Equipment
Need instructions for a MARCY APEX plus
Free Impex Home Gym User Manuals ' ManualsOnline.com LINK:
http://fitness.manualsonline.com/manuals/mfg/impex/impex_home_gym_product_list.html
There are five downloadable manuals at this link:
AB 4000 - Impex Home Gym OWNER'S MANUAL AB 4000
AB 4050 - Impex OWNER'S MANUAL MARCY AB BENCH AB 4050
Apex TC-2210 - Impex Inc. Power Tower Owner's Manual
Apex TC-3500 - Impex Fitness Home Gym Brochure
AX-PWR7 - Impex Home Gym OWNER'S MANUAL AX-PWR7
Jul 16, 2014 | Televison & Video
How to replace battery on black & decker SZ360 cordless scissor
I found a 1200mah 3.6v NiCd pack at BatterySpace.com for $10.99 each, the lowest shipping cost was FedEx Ground at $13.04 so I bought three of them, I'm sure I know some others that will need the other two. The quote 5 days to ship, in case they need to assemble them from individual cells.
The only issue is that I probably will have to modify the tabs to match the wiring in the scissors body, I'm sure Mr Dremel will come through for me on this point.
Black and Decker is most certainly *not* the best place to look, they have an exploded-view diagram of the scissors but have discontinued all parts for this model.
Van
Aug 17, 2013 | Black & Decker SZ360 Cordless Power...
Body by jake ab scissor is broken
I just fixed one for a friend of mine. The rectangle tube goes inside the square tube for handles and is welded. The problem I think is the heat from welding changedo the hardness of the metal and it breaks instead of bending. I fixed it buy welding two 1/2" X 4" solid still bars inside the broken tube. Thereason is no way that joint will break now. Somewhere else, maybe, but not there.
Mar 27, 2013 | Body by Jake Ab Scissor Exercise Equipment
Need to reassemble ab lounger
I have found a website with instructions on assembling an ab lounger - I hope you find this helpful.
http://www.livestrong.com/article/49201-put-together-ab-lounge-sport/
Sep 20, 2012 | Exercise & Fitness
How to dissassemble Vidal sassoon VSCL816. (e.g. scissors area). two phillips scresw unscrewed, but two shells of housing cannot be separated completely. Hint needed for taking away scissors. Scissors got...
I have a Vidal Sassoon Max hair clipper, and I suspect the construction of it is similar to yours. To take the two halves of the body shell apart you need to remove the blade assembly. Try this:
After removing the two visible screws, place your thumbs at each end of the cutting blades and push upwards.
The blade assembly should unclip, revealing two more screws underneath. Remove these, and the two halves of the body shell should come apart.
Graham
Apr 10, 2011 | Vidal Sassoon VSCL816 Beard Trimmer
No assembly directions
Here is a link to a website with the assembly instructions. You can view it as a PDF or HTML...depending on your internet connection. Hope this helps ya.
Assembly Instructions
Jan 17, 2010 | Fitness Quest Ab Lounge Ultra 1ea
R&R wheel hub assembly
try www.autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
Mar 22, 2009 | 2004 Saturn VUE
Ab lounge sport assembly
I had the same problem I found the manual on line and it shows how to put it together http://www.fitnessquest.com/images/ABLOUNGmanual2_18_0.pdf I hope this is helpful as it was for me.
Dodie B
Nov 01, 2008 | Fitness Quest Ab Lounge Ultra 1ea
Body by Jake Ab Scissor Exercise Equipment Logo
683 people viewed this question
Top Body by Jake Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Body by Jake Exercise and Fitnes Expert? Answer questions, earn points and help others
