Would any DOCSIS 2.0 work with all cable outlets? I have a RCA DCM315R
not on the apporved with comcast but will it still work? I need to know
if needed to sell or something. DFW Texas Comcast.com service
Rating: 0%, 0 votes
when my house was remodeled, and there is an UPS on each system, and
surge suppression even after the UPS. Now just what the cable system
has to protect the cable lines, other than the ground wire I can see, I
don't know. No problem with the TVs, just the cable modems. The most
recent problem was a defective run of power adapters from the
manufacturer, so they just replaced the modem as well.
Ron Hunter rphun @charter.net
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
in here next.
Rating: 0%, 0 votes
the ground block and wrapped it around the PAINTED electrical entrance
conduit.
Rating: 0%, 0 votes
as it was the day it came out of the box.
Manufacturing defects should appear far faster than 6 to 8 months. They
ought to show up within a few days. Longer than that, and any failure cause
is probably external or environmental. Power surges from lightning strikes
would be an example of a sudden failure cause. Poor air circulation
resulting in higher than normal operating temperatures would be an example
of a more subtitle cause. Extreme humidity, excessive dust, and pets marking
territory would be other issues. Most of these could affect the power supply
or the modem, and have the effect of shortening the life of a modem.
On the other hand, it may not be a modem problem at all. Swapping-out a
modem is an easy step, and may temporarily mask the real problem. A new
modem may get you working off a different card on the CMTS, and/or may
change your upstream and/or downstream channels. And there's also a
psychological effect of something new. Marginal, intermittent problems may
not seem as bad as they were before the modem was changed. The "new" modem
may have been in the home of someone else who thought they were having modem
problems, too.
If they're swapping modems every 6 to 8 months for you, they're not
addressing whatever the real problem is.
Warren H.
Disclaimer: My views reflect those of myself, and not my
employer, my friends, nor (as she often tells me) my wife.
Any resemblance to the views of anybody living or dead is
coincidental. No animals were hurt in the writing of this
response -- unless you count my dog who desperately wants
to go outside now.
Have an outdoor project? Get a Black & Decker power tool::
http://www.holzemville.com/mal l/blackanddecker/
Rating: 0%, 0 votes
over $3, I would buy my own.
Rating: 0%, 0 votes
modem. If I had REALLY been in a hurry, I could have driven over to the
office and picked up one myself.
Rating: 0%, 0 votes
check out your modem.
Rating: 0%, 0 votes
think your TV would suffer the same issues!)? Maybe try running it through
a small UPS?
The charge for the modem used to be $5 or $60 a year. The change came about
3 years after I bought my first one, so I'm a little ahead of the game
(total expenses for the two was about $150). Of course, being ahead could
only last as long as the second modem.
Rating: 0%, 0 votes
comcast 6 months 6Mbps for 29.95 orignal price is 62.95 - I had @home
but I the wire was cut. while Dish Network setup our dish.
Rating: 0%, 0 votes
Rating: 0%, 0 votes
had new modems over the years, I have saved a bundle.
Rating: 0%, 0 votes
6 to 8 months, on average. I think the old 'sharkfin' model went nearly
2 years....
Current one is less than 2 weeks old.
Rating: 0%, 0 votes
If you rent, you're cut back to 3 Mb. The price is the same for both
service levels.
Rating: 0%, 0 votes
If you use their modem, the cost is included in the monthly rate. If you
own it, they either have to reduce the service cost or offer better
service.
Rating: 0%, 0 votes
a modem, why worry about it? Renting has been by far the best option
for me, since the current modem is the 8th since I went to cable
internet service about 6 years ago! Better yet, the modems keep getting
smaller, and better.
Rating: 0%, 0 votes
model number, and the R just means retail. But the 315 is right there under
TCE/RCA. (Thompson Consumer Electronics owns the RCA brand name.)
http://www.comcast.com/Support /Corp1/FAQ/FaqDetail_2427.html
Whether it will work at any particular outlet depends on whether there are
any filters on the line to specifically block it, or whether there are cheap
splitters or amps that effectively block it.
Warren H.
to go outside now.
Post a New problem for RCA Cable Modem DCM315R
Email this problem
