Question about Sewing Machines
Singer quantum le replacing bobbin case after cleaning
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
louislevel_2
  • 374 Answers
SOURCE: hand wheel is stuck
hi there,
well,stuck up hand wheel, is due to mechanical obstruction inside machine,bushing on shafting need to oil,and on handwheel bushing near clutch there is oil port there. since hand wheel are connected to cam shaft with set of gears and pulley is coupled to motor pulley,and other linkage under bobbins,shuttle race etc,broken gears are most common causes of stuck up handwheel,we can consider also the brush carbon,when worn out and damage the rotor commutator brush.if you can open the cover of motor below side of handwheel,you can see the pulley and motor assembly.also on top of machine there an opening to see the top gear assembly,this should be done by service technician.try to bring to nearest service center if still under warranty claim this for lesser maintenance cost.have a nice day,don't forget to rate me.thank's.
Posted on Apr 20, 2009
  • 4 Answers
SOURCE: Replaced Singer 5932 bobbin case, need help. *pics*
there may be uneeded friction occuring. are you sure you inserted it correctly? sorry. photos aren;t appearing. but it may be that it is the wrong type or in the wrong place. do some trial and error and fit it into different positions on the bobbin runner
Posted on May 11, 2009
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
Posted on Mar 21, 2010
chrismyers67
  • 53 Answers
SOURCE: how do i replace the bobbin case in singer machine
When you insert the bobbin case, make sure the "knub" on the bobbin case (#1) is just to the left of the position finger bracket (#2). It should sit in there nicely and you should be able to spin the hand wheel freely.
Let me know if you need more help,
Chris
Posted on Jun 07, 2010
Singer quantum xl-600 bobbin case spinning
sounds to me like you need a professional cleaning and timing adjustment.
Jul 09, 2012 | Singer Quantum XL-6000 Computerized Sewing...
When i'm sewing the bobbin holder jumps out of place the needle then lodges it's self in casing and locks machine up,i have replaced the casing/holder and it did the same thing again
It sounds like the wrong size bobbin, try calling Singer is your bobbin is right because they should be able to answer why it is acting so strange. Good luck
Oct 05, 2010 | Singer Quantum XL-5000 Computerized Sewing...
The bobbin tension too tight on my Singer Quantum 9240. I believe there is a tension adjustment I can make on the bobbin case, but I have not been able to find my manual since we moved 2 months ago.
I am having this problem also; the thread catches in the **** in the bobbin. I am thinking maybe I am not threading the machine correctly--the bobbin area, not the top thread. I will try this & see if it fixes the problem. You may be doing the same as I am.
Jul 15, 2010 | Singer Quantum 9920 Computerized Sewing...
The thread and bobbin are nesting up in the bobbin case
Two things I have found that make my singer ce-200 nest. 1st. When I change threads, sometimes I thread it wrong - always nests when I do that. 2nd. When the bobbin runs out of thread it always nests for me, so I have to check the bobbin often. And I remembered a 3rd thing. 3rd. The area for the bobbin & bobbin casing has to be clean, no pieces of threads, and the bobbin casing itself can move, so make sure it's seated correctly.Whenever I get nesting, I take the metal cover off, under the needle, to get in and clean the bobbin area and under the needle good, before I go back to embroidering.
Oct 28, 2009 | Singer CE-200 Quantum Futura Computerized...
Bobbin case futura singer sewing machine came out
The opening fits on the right side, toward back. There is the silver ring with the slot in it for the bobbin. That slot is facing the sewer.
Jul 19, 2009 | Singer CE-100 Futura Computerized Sewing...
Hi I'm trying to get some new bobbins for my Quantum 9910 and have found some 66k bobbins which they say fit all singer machines. Is this true or do I need a different type? Thanks
The bobbins are generally interchangeable between singer models.
You have to watch out for the bobbin case though as this is the one specific to model families.
Hope this helps.
Jul 03, 2009 | Singer Quantum 9910 Computerized Sewing...
I just purchase a Singer 301 and cant get the bobbin case out
Raise the bed extension, revealing the bobbin area. Gently pull out on the bobbin case latch and it should pop right out in your hand. Congrats on your 301, they are wonderful machines!
Jun 08, 2009 | Singer Quantum XL-1000 Computerized Sewing...
BOBBIN SLIPPING AND STOP EMBROIDERY
First,call the technician and see if he will honor a warranty on his repair work. Next, sew on the machine until it messes up again. Do NOT take all the stuff loose. Take the machine, the garment, the thread,everything just as it is to the technician. Don't even lift the presser foot. He will probably find the problem.
Usually, on a problem such as this, it is the wrong bobbin, the bobbin inserted the wrong way, the tension not working , not threaded correctly, a rough spot on the bobbin case or the bobbin case is not properly positioned.Some times the thread jumps out of the thread take up lever.
sewman7
Aug 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
