Question about Drills
Makita hr 2220
Looking to purchase a drill bitt for this Makita hr2220. It's an old machine but still works. I do not know what shank size drill bit I need.
  • 313 Answers
SOURCE: makita 1420 - 14.4v 1.3Ah cordless drill
try toolpartsdirect.com & go to makita & type in model #
Posted on Jun 09, 2008
SOURCE: Makita drill 6349D
dont think its http://www.toolbarn.com/product/makita/6349DWDE/
Posted on Oct 05, 2008
  • 9 Answers
SOURCE: drill bit is stuck inside my makita drill chuck
Try using the low torque setting on the drill when reversing and something to assist you getting a better grip to hold the chuck from spinning when reversing. This may help.
Good Luck
Posted on Dec 04, 2008
rowdy45176
  • 2176 Answers
SOURCE: makita 6408 drill motor. can't see how to replace the chuck.
If you have the 6408 as listed the spindle is threaded and you are correct there is no retaining screw. What you would need to do is find a bent handle allen wrench about the size of the chuck capacity 3/8" and insert the shorter end in the chuck and tighten. put the chuck on a block of wood or workbench and position the long end at about a 30 degree angle in the counter clockwise position and strike it with a hammer, this might take a couple hits. If this is not a 6408 let me know and I will look at the tool for you and see what you got.
Posted on Jan 23, 2009
  • 15 Answers
SOURCE: my makita 18v 2.0 battery
It appears that your battery is worn out. They will charge, but miminally. If it is a nickle cad battery, and relatively new, you may have a memory problem. Try draining the battery completely several times and recharging each time. Be sure the battery is completely dead before recharging.
Posted on Jan 28, 2009
Hi. I have a makita 08070 hammer. when I will start this the power light is work but machine not work
Australia Drill Battery offers a complete and comprehensive product line of high quality MAKITA power tool batteries. Our MAKITA drill batteries are designed to be fully compatible with the original cordless tools. http://www.drill-battery.com.au/batteryshop.php/makita_power-tool-battery.html
May 09, 2017 | Makita Drills
Hi, Makita hr 2450 stop hammering but drilling works fine?
check the position of the setting for the small lever for the drive box at the front of the drill section
Jul 11, 2015 | Makita Drills
I'm looking for keyless chuck to makita btd 140
The Makita BTD140 is an impact driver that has a hex-drive anvil and bit holder assembly, it does not have a keyless chuck accessory. There are some aftermarket chucks with hex shanks on them to put into impact drivers but I've seen very few that hold up.
May 29, 2014 | Makita Drills
My makita hr-385 is leaking grease from the bit
You don't say which part you brought for the HR3850k but if it is the Xring and O ring for the front of the tool cylinder you need to unscrew the tool holder from the cylinder and then just hook out the old seals and put the new ones in. This can very very tight and you will need a good vice to hold the machine. Can't remember if it is left or right hand thread.
Jun 08, 2012 | Drills
What keyless chucks will work on my makita hammer drill will a dewalt xrp chuck work on a makita
as long as the chuck is used for a hammer drill and the thread size is exact yes it will. I believe the thread is 1/2-20 and also make sure the chuck has a hole in the center for the reversing screw to keep it from loosening up. Let me know if you need more assistance. The thread size is usually stamped on the side of the chuck. Makita sometimes used a metric thread.
Dec 31, 2011 | Makita Drills
Can I buy a new motor for a 12 v Makita cordless? How much?
You need to contact Makita directly. But from experience, it's usually cheaper to purchase new drill than replace parts.
Mar 09, 2011 | Makita 12 Volt Cordless Drill/Driver Kit
I bought a new highter current ni cad for my makita; however, the
As long as the charger voltage and the battery voltage match (7 volts) there should be no problem. A fast charger just runs more current thru the battery (per unit time) than a not-so-fast charger. If you notice the battery getting really hot when it's charging (like too hot to touch), stop using it.
Apr 28, 2009 | Makita 6019DWE 3/8 Cordless Drill Keyless...
Makita BHP451 Question
Buy a hitachi li-ion 18 volt ds18dl.
All parts are repairable & replacebable should they breakdown. Ie gearbox.
Gearbox parts are not available on makita , only whole gearboix which can be expensive.
Cheers
Laurie
Aug 27, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita manual
too cool I have the same drill I think broken trigger on mine but managed to find this for you
its the parts diagram with everything
http://www.ereplacementparts.com/makita-6012hd-cordless-drill-parts-c-97_106_107_264.html
hope that helps. I will have to check if I still have my old manual and if I do I will post it up for you.
Aug 01, 2008 | Makita Electrical Supplies
Drills Logo
47 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
