I have a ritetemp thermostat 8030C and the manual shows how to recalibrate but I want to return it to the factory default of -1. How do I do that
3 Suggested Answers
Brandonmxb
  • 115 Answers
SOURCE: how I return the factory defaults??
This can be quite simple. Look for a little button on the back of your router, it should be sorta pushed in because it shouldn't be hit unintentionally. Once you have found that button, you should press and hold it in for at least 5 seconds to ensure that it is fully reset. Restoring it to factory default will erase the password, any other saved information and be replaced with factory settings.
If you need help, feel free to comment, I will respond.
Thanks,
Brandonmxb
Posted on Dec 15, 2009
SOURCE: ritetemp 6022 programmation manuel Where can i
when the furance turns on it never shut off. how can I fix this.
Posted on Dec 18, 2009
How can I disable the programmable function and just use as a conventional thermostat
5. Temperature Adjustment
Extended Hold (Vacation) Mode
1. Press the HOLD button to bypass the program schedule. The current set point temperature will be held either permanently or for 24 hours, depending on the setting selection made in section 4.
2q==
2. Press the
HOLD button again to return the thermostat to the normal program operation.
3. The hold period will last until the hold is released as in step number 2 above, or is limited to 24 ours if the default was changed in the User Options Settings (see section 4).
4.Programming User Settings
Setting the Extended Hold Time (see also section 6)
The default setting is Long (indefinite) Hold. If the HOLD feature is activated, the current set point will be held until HOLD is released.
1. In normal operating mode, press and hold the
RETURN button for 4 seconds. Press RETURN again to skip past differential setting. The display will show "HOLD LG", where LG is indefinite hold.
z
2. Press the or button to change the Extended Hold time from indefinite (LG) to 24 hours (SH).
3. Press the
RETURN button again to set the Filter Check Monitor or wait 30 seconds for the thermostat to return to the normal mode.
6.Additional Operation Features
Resetting the Thermostat
The Reset feature allows the user to completely reset the thermostat to register new manual switch settings.
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the
RESET button using a paper clip or a small pencil tip.
2. This will return all thermostat settings to their default values and register all new manual switch settings for proper operation (incl.
Extended Hold = Indefinite).
Dec 28, 2014 | Proselect PSTS21P52 Programmable 2 Stage...
How do i recalibrate the st4000 tiller for the starboard side
Hi Tina!
The ST 4000 is factory default to the starboard side. If you require a port side mount, see chapter 7 of the manual to which I have provided a link below. (3.16 MB) About halfway down the page.
The text reads as follows:
OPERATING SENSE REVERSAL
Press +1 and -1 keys together for five seconds.
The display will then show port or starboard and the phase of the autopilot will automatically change.
The control head will automatically revert back to its normal operation within 5 seconds.
Note: This should normally only be required if the actuator is port hand mounted.
Hope this helps.
(Sorry about the orientation of the manual, it's pretty cheesy coming from Raymarine.)
-Steve
Raymarine Retired Autopilot Manuals
Dec 05, 2014 | Boating
Ritetemp 8022c
After you program the thermostat..the temperature numbers stays on the screen a few seconds then starts to indicate the temperature of the room. This is normal.
Nov 29, 2013 | Heating & Cooling
Como resetar o gfx8
zoom GFX-8:
The All Initialize/Factory Recall function is a special function
that lets you reset the GFX-8 to the condition in which it was originally shipped. When All Initialize is performed, all settings of the unit including all user group patches are returned to the default condition. Factory Recall can be used to reset only specific user group patches group to the default settings.
1. Turn power to the GFX-8 on while keeping the STORE key depressed.The display shows "ALL-INIT".
• To perform All Initialize, Continue with the next step.
• To perform Factory Recall, Use the BANK UP/DOWN foot switch and foot switches 1 - 4 to select the patch (from a user group) that you want to return to the factory default condition.
2. Press the STORE key once more.
All Initialize or Factory Recall is carried out.
If All Initialize was carried out,
the unit automatically returns to the play mode.
Note that when All Initialize is executed,
the contents of all patches stored by the user will be overwritten (erased).
When wishing to cancel All Initialize/Factory Recall,
press the EDIT/CANCEL key before step 2.
source: ZOOM GFX-8 User Manual.
Oct 13, 2010 | Zoom G1x Guitar Multi Effects Pedal with...
I have hp 1522nf printer & it is showing memory low. It is continously showing error 49
Hello ! you can try doing the following:
1. Please ensure that the printer is directly connected to wall outlet.
2. Print a configuration page and check the firmware datecode. If possible update printer firmware and check if the issue occurs.
3. If the issue occurs, please perform a restore factory defaults. Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number.
a. On the product control panel, press Setup .
b. Use the arrow buttons to select Service, and then press OK.
c. Use the arrow buttons to select Restore defaults, and then press OK. The product automatically restarts.
4. If the issue still persists, perform a NVRAM initialization. An NVRAM initialization will return the following device settings to the factory-set defaults:
a. Turn off the product.
b. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
c. Wait until the message Permanent storage init. appears, and then release the buttons. When the NVRAM initialization process finishes, the product control panel shows the Ready message.
Jul 02, 2010 | HP LaserJet M1522n MultiFunction Printer
Ritetemp 6022 programmation manuel Where can i
Dec 08, 2009 | Heating & Cooling
Garmin nuvi touch screen has become mialined cannot get into setting to realine any ideas
yes first use the reset ( see manual) button to return it to factory default The recalibrate the screen
Aug 29, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Used Lanier LD435c needs to get reset to factory settings
enter the [user tools/counter] then before you press [system settings] hold it down pressed the [#] key and while the [#] key is pressed press the [system settings] key (on the touch screen or if dose not have touch screen than press ok) and the copier will return the settings to default. You can repeat the procedure for all settings.
Jan 10, 2009 | Ricoh Office Equipment & Supplies
Cannot have 2 phones in use at the same time 25952
Here is a selection from the manual and a link to the full manual to download.....it should help.
http://www.home-electronics.net/ge/pc/IB/25952EE2_IB.pdf
Transfer ON/OFF
In order to use the Call Transfer feature (applicable ONLY with additional handsets), you must have the Transfer ON/OFF set to ON through the menu of the transferring handset.
1. Press the mute/menu button until TRANSFER 41OFFshows in the display.
2. Use the CALLER ID-VOLUME (5or6) button or the touch tone pad on the handset and select 2ON.
3. Press mute/menu again to save.
Default Setting
You may return handset settings to the factory default setup using this menu.
1. Press the mute/menu button until DEFAULT 4NO shows in the display. NO is the default.
2. Use the CALLER ID-VOLUME (5or6) button on the handset to scroll to YES or NO.
NOTE: If you choose YES, all settings in the programmable menu return to the factory defaults.
Jan 27, 2008 | Uniden Cordless Phone
20 people viewed this question
jasbo
jasbo
