Question about Dell Mobile Precision M4600 Computer Workstation Intel Core i52520M (bwmc7t22) PC Notebook
Error code 2000-0142
Start computer,Press F12,and choose Diagnose, I get HardDrive0 test unsuccessful, error code 2000-0142
5 Suggested Answers
  • 3940 Answers
SOURCE: Dell Inspiron 1420 freeze at starting
This is an easy one.
You hard drive has DIED.
Call or chat with Dell tech support and get a replacement drive
http://support.dell.com/support/topics/global.aspx/support/chat/hardware_chat?c=us&l=en&s=gen
Since the system is less that a year old, you can request a replacement drive witht eh factory image on it too.
Posted on Jul 14, 2008
  • 3940 Answers
SOURCE: i get the error code 2000-0146 only when i run the f12 diagnostic
The 2000-0146 error code indicates a read/write failure of the hard drive. There is at least 1 sector that is failing on the drive. While it is working at the moment, the drive is failing and will over time degrade and eventually fail completely. Backup any important data, then replace the drive.
Posted on Dec 11, 2009
  • 12 Answers
SOURCE: ERROR CODE 2000-0142
Hard drive is failing. Reseat hard drive cables. If it does not work, have to replace hard drive. probably damage from overheating or powersurges.
Posted on May 15, 2010
  • 268 Answers
SOURCE: When I started my DELL Inspiron 1525 running Win 7
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Posted on Oct 18, 2011
Got an Acer 4050 from ebay and it goes straight to enter boot password
can you click on f12 before it goes to boot password?
The F12 Boot Menu allows you to choose which device that you would like to boot the computer's Operating System from by pressing the F12 key during the computer's Power On Self Test, or POST process. Some notebook and netbook models have the F12 Boot Menu disabled by default.
If this sounds like your problem then try this:
If this sounds like
To enable the F12 Boot Menu:
  1. Restart the computer.
  2. Press the F2 key to enter computer's BIOS Setup during Power-On Self-Test, or POST, process while the Acer logo is being displayed.
  3. Press the Right Arrow key to select Main
  4. Select F12 Boot Menu
  5. Press the Enter key
  6. Select Enabled
  7. Press the Enter key
  8. Press the F10 key and then press the Enter key to save the changes and restart the computer.
Note: Not all Acer notebooks or netbooks have the F12 Boot Menu feature. Computers that do not have the F12 Boot Menu feature will not be able to enable the feature within the BIOS. I hope this works for you if not, then the problem is obviously not the boot menu. Go to Acer support for more help
Aug 30, 2014 | Computers & Internet
Tip
How to Diagnose Hardware Failure on Dell Computers
1. Turn off the Computer
2. When you turn the computer on, repeatedly press F12.
3. When a boot menu comes up, select boot to Utility Partition.
3. Press Tab and than select Test System and hit enter.
4. There is than two options:
Express Test - 15-20 Minute Basic Test
Extended Test - Hour long Thorough Test
5. This is built in to all dell machines and it will save you from having to pay a lot of money to have your computer "professionally" diagnosed by computer shops.
on Dec 25, 2009 | Computers & Internet
When starting it appears normall gives F2 and f12 option after that the screen becomes black
Was the laptop on? Projector on?
If so this = No.
Toshiba Satellite C600 specifications,
http://egadgetsclub.com/laptops/toshiba-satellite-c600-notebook-review-specifications/
Intel Pentium Dual Core T4500,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_microprocessors#NetBurst_based_Pentiums_2
Go to F2 option. That should be - enter BIOS Setup.
Look at the main menu (Which it automatically goes to)
Or use Down Arrow to highlight Standard BIOS options, and press Enter key.
Is the Harddrive listed? HDD0 has harddrive info listed to the right?
(HarDDrive0)
Post back in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | Computers & Internet
GE error E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
credit to the original author of this solution rcadieux4444
Jun 30, 2012 | Computers & Internet
Error code 0147 spindle test failed
The error you received (2000:0147) indicates the drive has failed. It cannot be fixed. You need to replace the drive.
May 27, 2012 | Dell Studio Xps 8100 Desktop Computer
Comoputer: DELl precision T5500 Workstation Problem: cannot start normally Error CODE 0142 Msg: Error Code 2000-0142 Msg: Hard Drive 0-Self-test unsuccessful Status: 72
sounds like a bad hard drive. Press f12 during the dell logo on startup and choose "diagnostics" from the boot menu, see if more failures relating to the hard drive are returned.
Feb 23, 2011 | Computers & Internet
My computer logs on to the Dell Latitude 600 start page, and then properly transfers to the windows start up page. But, after this, I cannot get any further. It will not take me to my icon page. It reverts...
It seems that yuor harddrive have some errors
boot from windows xp cd
enter into recovery console pressing R
at the prompt type chkdsk c: /p /r
After that type fixmbr and press enter
Aug 04, 2009 | Dell Latitude D600 Notebook
Disk read error
try to run diagnostics,restart your computer, press f12, choose utility partition,choose test system, then run express test..that will tell you if hdd is bad, it will give you an error message/ number
Oct 15, 2008 | Dell Dimension™ B110 PC Desktop
Jul 14, 2008 | Dell Inspiron 1150 Notebook
Dell Mobile Precision M4600 Computer Workstation Intel Core i52520M (bwmc7t22) PC Notebook Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
