Question about Pit SSR 110CC Pro Beginner Bike
My pit bike kick start is stuck in upright position
Was over woods today pulled away in 1st an hear a horrible sound and jolted to a standstill. the kick start is stuck (upright) but will go into manual an be pushed. it seems to be this way in all gears as I tried putting it in all gears but still feels jammed. please help, many thanks
SOURCE: gears
it needs new gears mate
Posted on Nov 27, 2008
  • 200 Answers
SOURCE: flywheel doesn't spin on kick over
Flywheel has a keyway that has been sheared or bolt on shaft is loose.Either way you need to pull the flywheel and inspect it...replace keyway..reinstall retorque...Good Luck to you my friend....Tim
Posted on May 10, 2009
  • 104 Answers
SOURCE: I cant start a pull start mini pit bike. Its pull
Spray a small ammount of starting fluid into the aircleaner. It will fire much easier and should start if your ignition is ok.
Posted on Aug 28, 2009
SOURCE: 110cc pit bike; The kick start kicker used to
Hello - i don't know whether you have sorted this or not, but ill help you anyway. Well.. First of all to get to the kickstart mechanism, you need to drain the oil. Get an oil tub, or a metal jug, or anything along those lines and place it underneath the engine..
Underneath the engine there is a big bolt which should have a red rubber washer, well.. undo that. The oil will drain out of it, tilt the bike left and right to make sure it's all out.
Now you undo the bolts, holding the clutch cover on, this will reveal the clutch. In the middle of the clutch there is a ring with teeth on it, bend them out and the clutch will just pull off, also there is a circlip so be careful and dont lose it. Now it's time to take the whole engine casing off, just undo all of the bolts, and keep them in order because some are different sizes. There is a large gasket so make sure you dont rip it!
There it is. The spring mechanism, if you want to go further, you will have to take the cylinder off to split the engine to get to the gear box.
Posted on Feb 04, 2010
  • 186 Answers
SOURCE: hi im brett i was in fields behind me with my
check for bad spark plug.has it got spark?also ckeck the carb for contaminated fuel and blocked jets in carb
Posted on Dec 24, 2010
I ran my 125cc Apollo pit bike for long distance and it died, won't start with kick start. We had to pull start it,but won't stay idling? How can I fix it?
TRY INCREASING THE IDLING FROM 1.5 TO 2.5 RPM DURING THE START . CHECK YOUR SPARK PLUG AS IT MIGHT CONTAIN CARBON RESIDUES .
Mar 17, 2016 | Pit Motorcycles
Although I can change between 3,4,5 and 6th gear I cannot get first or second especially down shifting
It sounds like the clutch.May be dragging.does it creep forward if the clutch.is in at a standstill in gear.and can you get 1st and 2nd and neutral if the bike is not running and you rock it back and forth to move the shafts around.
Mar 08, 2015 | 2004 Aprilia SL 1000 Falco R
How can my
Stuck in 1st and neutral is correct on a Kawasaki...2nd won't engage until the output shaft is turning at approx. 12 mph. This is to make neutral easier to find at a standstill. If you spin the back wheel to a decent speed by hand then second should engage. The stalling problem when trying to pull away is due to the sidestand switch...it's either sticking or not engaging with it's activating bracket properly. If it stalls as soon as you put it in 1st then the microswitch on the clutch lever has a problem also...
May 02, 2014 | 2000 kawasaki VN 1500 Vulcan Classic
125cc pit pro, pit bike Kick start lever jammed
remove the cover that houses the kick starter and look for a failed return spring or some other reason that keeps the kick start dog engaged.
Jun 03, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
1997 kawasaki ninja zx6r will only select 1st gear
You need to be doing over 10 mph to select anything other than 1st...if it will not change up while riding then I would suspect that the bearings that stop the other gears engaging at low speed are stuck or worn. This system is designed to make it easier to find neutral at a standstill. If you haven't tried to change gear while moving get someone to spin the back wheel as you change up and the problem should go away...
Sep 20, 2012 | kawasaki Motorcycles
I av a 140cc pit bike and when the engine is off the gears work, when the engine is running i can get 1st but then av to force it into 2nd and 3rd any advice plz
when you put a bike into gear the chain tightens sounds like it is to tight move the back wheel closer to the swing arm about an inch that should do it
hope this helps
John
Jul 10, 2011 | Pit Bike 125cc 4 Stroke Dirt Bike
Pit SSR 110CC Pro Beginner  Bike Logo
26 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Are you a Pit Cycling Expert? Answer questions, earn points and help others
