Question about Black & Decker Classic Metal APP F63D Iron
Remove back plate on black and decker iron
What kind of screw is in the back plate
tbreeze47
  • 3083 Answers
SOURCE: On my Black & Decker
I wish I could tell you where the screw is, but I can tell you this- it's going to be tricky, as you know.
Black & Decker makes these units as unserviceable as they can, probably because they don't want any lawsuits from people tampering with 220 live, nasty volts. Sometimes they use special tools, and manufacturing processes that makes it virtually impossible to disassemble a unit without damage- clearly indicating attempted repairs, and destroying the iron in the process, making it unusable.
The short and simple of it is that they're made as throwaways, and even if you can get to the potentiometer, you're going to find a broken support or switch piece most likely, and won't be able to get a replacement part (you can try to google parts for irons, but will only get the whole iron).
Wish I had better news, but I've been through this years ago, and ended up breaking the iron in the process of getting it open, and I doubt it's gotten any easier over the years.
My advice is to see if you can, hopefully, get it open as far as you can, and see if you can somehow free the jammed arm. Otherwise, buy a good used or new one.
Wish I had better news, but good luck.
Posted on Nov 07, 2010
JULIANFIX
  • 975 Answers
SOURCE: How to clean the plate
I suggest to purchase a bottle of CLR , at any mega store (WAL , K ...) HOPE THIS HELPS , THANKS
Posted on Apr 28, 2008
SOURCE: Does anyone know how to
I think I have the solution now!
First of all, remove the temperature knob. Than remove the temperature indicator (it's like a little disc). Theres a hidden screw under the temperature indicator! Remove that screw and continue with your fixes.
I hope it could help you.
Jardel
p.s. - Sorry for my noob english...
Posted on Mar 07, 2009
protek480
  • 1714 Answers
SOURCE: I can't seem to open up my ICR-250 B&D iron
Sometimes you can gently pry it open if you can't see any more screws.
Posted on Jul 02, 2009
heatman101
  • 43501 Answers
SOURCE: Black & Decker D2020 Iron - Burning Smell & Beeping
The iron is probably junk...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
How do i remove a black smear on my sole plate icr 500
clean it with a sharp edged blade slightly ,only when it is hot
Nov 13, 2014 | Black & Decker ICR200 Iron with Auto...
I need to know how to take apart a Black & Decker Press 'n GO
Maybe a direct inquiry to Black & Decker will yield some useful information.
Feb 20, 2014 | Irons
Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Apr 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Black rubber burned onto plate of iron
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Apr 12, 2010 | Black & Decker ProFinish X750 Iron
Jun 30, 2009 | Black & Decker ICR200 Iron with Auto...
Does anyone know how to open a Black and Decker digital advantage iron? - I suspect a loose connection where the power cord attaches to the iron and have taken the two screws out of the back plate but the...
Jardel
Sep 21, 2008 | Black & Decker D2030 Iron
I want to repair myself
There is a security screw in the back of the F63D classic iron. It must be removed to get the back plate off. I haven't found the right tool yet myself, though it was suggested it is a "security" Torx.
Aug 21, 2008 | Black & Decker Classic Metal APP F63D Iron
Melted material on face of iron
Yes- I had the same problem and could not clean it off. It was a plastic sticker that melted on the iron plate- placed there by the manufacturer. I called Customer Service at Black and Decker, and after all their solutions failed- they sent me a new iron. But this one leaks water terribly to the point where the clothes are soaked after only 1 or 2 articles are ironed! I am beginning to lose faith in Black and Decker products.
Dec 24, 2007 | Black & Decker D2030 Iron
Black & Decker Classic Metal APP F63D Iron Logo
64 people viewed this question
Top Black & Decker Irons Experts
tfelton3
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
