1994 crane bali hi 2-928w whirlpool tub parts manual
2 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: Pump does not start, it does have power
Touch pads usually have three wires connected to a low water sensor (two wires) all running into a control box with a circuit board inside.
If you are in the tub and the tub is full of water and you then touch the 'pad' to turn the pump on and it doesn't turn on then the problem is most likely the box those wires and the pump plug into.
Get us that number off the box and we can solve this for you.
Posted on Feb 24, 2009
Pump hums but nothing happens
Sounds like the pump impeller is stuck. Shut off the power and check to see if the pump has a small round cover on the end opposite from the pump. Some pump motors have a slotted shaft that you can insert a screw driver and manually turn back and forth to loosen the stuck impeller otherwise drain the tub and remove the pump to access the impeller and attempt to free it.
Hope this helps.
Bob
Jun 01, 2014 | Crane & Co Crane Plumbing 2430W Whirlpool...
I have crane whirlpool tub model #2326WL51 needs new pump and touch pad
Need to know the model number of the pump in order to find the correct panel on the top of the tub.
send to: uspartscenter@gmail.com
Rod
US Parts Center
Apr 04, 2014 | Crane & Co Home
Pump will not turn on when button in tub is pushed
Check the pump outlet to see if it is tripped or the breaker if used . These are usually GFCI (Ground Fault Circuit Interrupter) type equipment and are very easily tripped.
Hope this helps.
Bob
Nov 03, 2013 | Crane & Co Crane Plumbing 2430W Whirlpool...
A CRANE WHIRLPOOL TUB BOUGHT FROM MENARD'S IN THE 1990'S HAS TWO CONTROL KNOBS FOR AIR AS WELL AS AN ON/OFF BUTTON. WHERE CAN I FIND A REPLACEMENT SEAT THAT THE AIR CONTROL KNOB SCREWS INTO A
What you are looking for is called the wall fitting for the air control knob.
If you can email me a picture of the knob, topside and underside I can tell you who made it and if there are parts for it.
send your pictures to: sales@uspartscenter.com
Rod
US Parts Center
888-521-6183
Feb 10, 2013 | Crane & Co Crane Plumbing 2430W Whirlpool...
Installing a bathtub on concrete floor
Other than chopping out more concrete.elevating the tub is probably your only other solution. I would think 2" would be adequate.
Hope this helps.
Bob
Feb 08, 2012 | Crane & Co Crane Plumbing 2430W Whirlpool...
I have a ies control box that its hard to find can you help me
Were you able to find a part? I have the exact same part in my hand that I am trying to replace
Jan 05, 2012 | Crane & Co Crane Plumbing 2386W Oval...
How to repair a leek in a laundry tub
I have repaired this style sink with silacone then pained with garage floor paint
Nov 14, 2010 | Audiovox Crane Plumbing Molded-Stone...
Whirlpool spa bath touchpad wiring
you need to acquire a wiring schematic from the manufacturer for your tub,....get all info you can think of i.e. model#, serial# name, etc. so when you reach a human on the phone, you can give them all of this required info they'll need to get you the right info you'll need to re-wire this thing,..good luck
Dec 17, 2009 | Crane & Co Crane Plumbing 2386W Oval...
How do you put springs back on a laundray tub door
Get online and do a search for your brand and model number. Try and locate a contact number for the company and sometimes you can download a service manual for the unit that might have the info you are looking for. Otherwise you just might have to have a service professional come out and repair it. Good luck!
Apr 05, 2009 | Crane Plumbing 24 In. x 22 In. Laundry...
Feb 20, 2009 | Crane & Co Crane Plumbing 2386W Oval...
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
