Question about Kenmore 71055 Air Conditioner
Manual change filter
How do I deleate the change filter light?
My model is the psp511lca but it may be the same type of reset. I have a dial I turn to the "change filter" option and then press the up and down temperature buttons simultaneously and hold for a few seconds. When you turn the dial back to "run" the change filter light on the display is gone.
Sep 12, 2014 | LuxPro PSP711TS Touch Screen Programmable...
SRS580DW Water filter indicator red light is on. Where in the fridge do I find it to take it out to replace pleace?
Resetting the water filter indicator light can also be found in the user manual for your SRS580DW Refrigerator User Manual page 8 The water filter indicator initially lights up green. Press the ICE TIMER and ICE MODE buttons at the same time for about three seconds to reset the water filter installation date. • The green light changes to orange after five months to indicate that you should soon change the water filter. It changes to red after an additional one month (six months after the water filter was changed or installed) to indicate that you must change the water filter. • If you wish to turn off the filter indicator lamp or the filter is not connected, press the ice timer & ice mode button simultaneously for 5 seconds. If you wish to turn on the filter indicator lamp again, press the ice timer & ice mode button simultaneously for 3 seconds. Click Here for the SRS580DW User Manual I am here should you have questions Thanks Sea Breeze
Jun 03, 2013 | Refrigerators
How to change water filter on msd2352kew
Instructions on how to change the water filter are found on page 20 of the user manual Here=> MSD2352KEW User Manual
I will be here should you have questions, Thanks Sea Breeze
The water filter is located in the upper right-hand
corner of the fresh food compartment.
1. Remove blue bypass cap and
retain for later use.
2. Remove sealing label from
end of filter and insert into
filter head.
3. Rotate gently clockwise until
filter stops. Snap filter cover
closed.
4. Reduce water spurts by
flushing air from system.
Run water continuously for
two minutes through
dispenser until water runs
steady. During initial use,
allow about a one- to two-minute delay in water
dispersal to allow internal water tank to fill.
• Additional flushing may be required in some
households where water is of poor quality
Mar 22, 2013 | Maytag Refrigerators
How do i replace the water filter.
http://www.frigidaire.com/manuals Enter your model number
Manual link:
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241661500en.pdf
Actual precedure with pictures is on page 14 of the above link.
GENERIC Installation Instructions:
  1. Unscrew the filter cup and dump out the water
  2. Pull the old filter straight down and discard
  3. Place the new filter in the filter cup
  4. The end of the filter with the small o-ring should be up
  5. Screw the filter cup (with filter) up onto the housing
  6. The filter will self-align as the cup is tightened
  7. Reset your 'change filter' light (if your fridge has one)
Resetting your filter change indicator light:
  • Press and hold the reset button on the dispenser until the green light flashes (up to 15 seconds)
Thanks for choosing FixYa,
Kelly
May 24, 2011 | Frigidaire Side By Side Refrigerator 26...
I've got a side by side Whirlpool refridgerator. The Water Filter status light is not indicating. What could be the problem and solution?
There are several pages that explain dispenser programming. This is on page 10 of the owners manual.
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> sea_breeze_132.jpg Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
Apr 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house in June. The change filter light came on a few weeks ago and I can't get it...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house the change filter light came on and I can't get it to go off. How do I reset the change filter light (it's not time to change the filter)? The model # is MSD2732GRW and I don't have a manual for this refrigerator. Thanks!!
Sep 07, 2010 | Maytag Refrigerators
NO manual for Fridge.
I can get the service manual for you. Here is what the manual tells you on page 101.
WATER FILTER CHANGE REMINDER
(Select Models)
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER
indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Thanks, Sea Breeze
Jan 18, 2010 | Maytag MSD2756G Side by Side Refrigerator
Frigidaire filter problem..
After changing the filter it is necessary to reset the filter status light. Press the filter status reset button for 3 to 15 seconds until the green light flashes.
If you want to look at the entire service manual you can access it at : http://www.fixya.com/support/p61551-frigidaire_frs26r4a_side_by_side/manual-4115/page-14
Feb 09, 2009 | Frigidaire FRS26R4A Side by Side...
Maytag lock and filter change
to reset the change filter light:
Press hold the LIGHT and LOCK pads until the CHANGE FILTER light blinks (approx. 3 sec.)
Dispenser lock:
to interrupt power to the water and ice dispenser so it cannot be used , press the lock pad 3 times within 10 seconds.
Jan 21, 2008 | Maytag MSD2454G Side by Side Refrigerator
Kenmore 71055 Air Conditioner Logo
21 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
