OM03521 stopped working
I was shredding a bunch of things and it just stopped working.
2 Suggested Answers
  • 133 Answers
SOURCE: It stopped working after a big shred. I suspect an overheat. How do I reset it?
it's overheated, after you turn on the shredder, is it working?
if not, that means your shredder's motor is death.
need to buy a new shredder.
Posted on May 23, 2009
Top thread is shredding Automatic needle threader stopped working
If the top thread is shredding it is usually because the needle and thread are not compatible. If thread is too large for the eye and the thread groove, the action of sewing will cause the thread to shred as it pieces the fabric.
Try a different needle and thread. Here's an excellent web site:
All About Needles
Sep 27, 2015 | Sewing Machines
Qualcast manuals
Unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 25, 2014 | Office Equipment & Supplies
Omnitech shredder ot-nxc10pa
You must first unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 23, 2014 | Office Equipment & Supplies
My paper shredder stopped working
First things First...UNPLUG THE UNIT. It sounds like it has been fed too many pages at one time. You may also want to dump any shredded paper so there is plenty of room for the shredder blades to pull in the paper. If the paper catcher is too full the blades can grab shreds from the bottom and stop the blades movement. Just be careful. Shredders can be dangerous.
Jun 01, 2009 | Office Equipment & Supplies
May 06, 2009 | Office Equipment & Supplies
Shredder Malfunction
Sounds like you have a jammed shredder. Unplug it, and then look under the shredding output side. You might see a bunch of compacted paper in there. If so, you'll need to have someone take it apart and remove the paper. Be sure the shredder is UNPLUGGED before you or anyone else attempts to do this.
Mar 19, 2009 | Office Equipment & Supplies
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
Powershred 380-c
Possible door switch or the bag full plate under the machine jamed ot switch bad. Also All shredders need the wheels oiled with shredder oil now and then...
Jun 16, 2008 | Fellowes Powershred 420 Shredder
Stoop running
very easy to take apart. since all the skin and hard parts of fuits and veg. are shredded theybtend to stick and bunch up in the machine, sumtimes against blades.clean after every use inside and out
Jan 09, 2008 | Jack Lalanne Power Juicer (Stainless...
My shredder stop shredding. has paper caught in it
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Aug 29, 2007 | Quartet gbc 6120S Shredder
14 people viewed this question
jasbo
jasbo
