Question about Refrigerators
Frigidaire FAH085NIT leaking water onto floor
Leaking water onto the floor
yalmer
  • 552 Answers
SOURCE: frigidaire refrigerator with ice maker leaks water
It sounds like your ice maker is leaking.
If you are able, try opening up the ice maker for a visual inspection.
just remember to unplug first.
Apparently there is a leak somewhere.
Sometimes ice makers will over flow if the float gets stuck or a connection has come loose.
If you cannot work on it yourself, then I suggest looking up a service technician on the Fixya website.
Posted on Apr 22, 2008
  • 1122 Answers
SOURCE: I have a Frigidaire upright
yout drain in the frig. is clogged,find the drain reservoir most times in the back top of frig. remove cover and clear it out with a hanger or shop vac,if ice is there melt it with hair dryer then claer out,hope this helps,thanks-mike
Posted on Jun 01, 2008
SOURCE: WATER LEAK IN FREEZER POOLING AT BOTTOM & FREEZING THEN MELTING
The problem was indeed a clogged frost water drain. I had to pull the frig out from the wall (found an incredible amount of dust accummulation in the alcove), then remove the vertical metal and horizontal cardboard covers to expose the drain catchpan. The 1/2" rubber drain hose end was only about 1/8" above the pan pointing directly into it perpendicularly. This was not enough clearance. There was a plug (formed by dust and water) in the end of the hose that came out easily when I 'roto-rooted' it with a screwdriver. The water flowed easily after that, but I went ahead and trimmed about 3/8" off the end of the hose and pushed it back into its slot. Then I cleaned as much as I could. The prevention is to keep the area behind the frig cleaned!
Bob
Posted on Nov 08, 2008
  • 123 Answers
SOURCE: Water leak under refrigerator, Frigidaire, FRS6R5ESBC
chk out dis video
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Posted on May 14, 2009
  • 56 Answers
SOURCE: Frigidaire leaking
the drain in the freezer compartment is frozen up you can remove all items from lower freezer and remove access panel on back of freezer compartment pick the ice out of the drain hole with a small screwdriver DO NOT USE SCREWDRIVER AROUND THE ALUMINUM COILS! once all ice is gone that you can see use hairdryer to blow into hole on medium heat. once it looks like it is gone take a small 1/4 plastic tubing and push down the hole to try to clear obstructions then run hot water down hole. if it still doesnt drain take rear access panel off of compressor area (back of refrig) look for drain hose and remove clamp take off and clean u might try this first. but you will have to remove ice from drain.
Posted on May 27, 2009
Frigidaire side by side refrigerator is leaking water
I assume you are talking about water leaking from the freezer onto the floor. It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube.
Aug 15, 2014 | Frigidaire Refrigerators
Ireland
Hey friend, thank you for the post!
From my understanding you have water leaking out of the freezer of your Frigidaire refrigerator and onto the floor. I would like to ask you a couple of additional questions. First, do you see where the water is coming from? Secondly, what is the model number of your appliance? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side in a top mount. But on a side by side it can be found on the right hand side. I look forward to hearing back from you. -Matt
Jul 17, 2014 | Frigidaire 20.6 cu. ft. Top Freezer...
Fridge leaks water on floor constantly
does it have an ice maker and or water dispensor? if so start by turning off the water supply, see if the leaking stops. if it stoped you may have a broken water line or the water level valve is leaking. if that isn't the issue check your seal around the door to make sure it isn't leaking in warm air. if that is ok you will need to look at the self defroster to make sure it isnt defrosting all of the time.
Jan 17, 2013 | Frigidaire Refrigerators
Water leaking into bottom of frezer,water frezing on bottom then leaking onto floor
defrost drain bottom rear of freezer is blocked . Defrost and clean drain tube.Poor water in trough at back under rear panel. If it drains out quickly then it is clear.
Oct 29, 2010 | Frigidaire Kitchen Ranges
Water leaking onto floor when defrosting automatically
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
SEA BREEZE TIP's
Sep 04, 2009 | Frigidaire FRS26R4A Side by Side...
Constant leaking water
The unit must be level and the hose lower than the machine. -Good Luck-Ned_
Aug 23, 2009 | Frigidaire FAP094P1Z Portable Air...
Leaks onto floor
your defrost drain is stopedup if its a sxs its in the back bottom of freezer side if its a top mount its behind the back over in the freezer remove and use hot water and blowdryer you will see a little drain tube under the evap coil
Jul 05, 2009 | Frigidaire Gallery Series GLRT218WDZ 30"...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
