Everything was working fine until we noticed something wrong with the power button .then if you shut it off when you turn it back on the monitor wouldnt always display so we started leaving the computer on now it wont shut off or display anything.
Power will not shut off even when the wiring harness is unplugged from the switch and motherboard. also both fans are running wide open
I have a digital photo keychain. I put the cd in my computer to download and it does. But that is...
(More)
I have a digital photo keychain. I put the cd in my computer to download and it does. But that is all that it does. I can't put any pictures on the keychain. One there are no other instructions and two because the cd is telling to pull in the usb cable to the keychain which i have done and then it says it is still uploading. I have had it on all night uploading and nothing has happened yet. Can you please tell me how to get it to down load my pictures.
Need to separate main case to repair DC socket. Cannot find last screws? around socket. Seems 2...
(More)
Need to separate main case to repair DC socket. Cannot find last screws? around socket. Seems 2 halves are glued together? Can you supply a disassembly instruction pdf, or a sevice manual?
have an older jiffy ice auger its starts, but does not stay running. when i start it, it runs and...
(More)
have an older jiffy ice auger its starts, but does not stay running. when i start it, it runs and while running i push the primer and it stays running. then when i stop pushing the primer it stallss. how do i fix this
