Question about Freezers
Schaub lorenz Dont freeze
Freezer does not freeze at top half and fan stopped working
your full freezing system is gradually damaged.
Mar 21, 2013 | Daewoo FRSU20IA Freezer
I got 1 beep and I dont fine the problem
stuck hot gas valve or relay, hot water entering unit, bad headmaster. continue your checks.
May 22, 2012 | Hoshizaki Commercial Freezer KM-500MAH
My deep freeze locks on its own. We dont have a
nothing to do with temp changes. only to do with a broken lock mechanism.
Jul 26, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
My freezer does not seem to be freezing properly. Some of the meat is staying frozen while some is getting soft. All my bread products are not freezing at all they are staying cold but soft???
THE RED WARNING LIGHT KEEPS COMING ON AND I HAVE TO KEEP PRESSING THE FAST FREEZE BUTTON, THIS IS EVERY FEW DAYS. IF I DONT NOTICE ALL THE FOOD DEFROSTS!
Mar 23, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My freezer doesn't seem to be freezing as well as it has in the past. somethings are frozen hard but ice cream isn't as solid as it should be
Try this... unplug...
take everything out and defrost the freezer
(go get a couple bags of ice and a big clean garbage can so you can keep the food cold)
you can defrost the freezer faster with a hair dryer
when you finish turn t'stat to high setting... put all food back in and dont overload and dont block any air vents (if they are located at top dont overlaod)
plugg in wait 24 hrs...
if you dont notice a difference let me know...
hope this was helpful
Mar 08, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Bottom 2 shelves not freezing
if it does not freeze it is because the refrigeration system is low on freon. this will cause the bottom shelfs to not freeze...
you have to decide if it is worth putting the freon back in (they wont fix it because very hard to find)
so you could spend anywhere from $80 to $150 to get the freon back in... then after a while it will leaks out and you will have the same problem
why dont you instead move that money to a new freezer
Mar 04, 2010 | Freezers
IT KEEPS FREEZING VERY BD AND SO MUCH O THAT WE
turn 2 lowest setting and if it continues to run u may have a bad thermastat.
Jul 25, 2009 | Belling Freezers
Red light on not green ...has to be green to freeze up again
Try to unplug it for about 5 minutes, and then plug it back in
Apr 17, 2009 | Freezers
Freezers Logo
16 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
