Question about LG 42PX5D 42 in. Plasma HDTV
Sparkles My LG 42PX5D 42 in. plasma is about 15months old and suffers badly from "sparkles" during light to black transitions when displaying Sky digital TV pictures. I have changed to satellite to TV scart cable to a heavy duty gold plated version but no improvement was shown. Does anyone one know what might cause this "sparkling" problem and how it might be cured?
  • 2 more comments
  • The Daddy Sep 04, 2007
    It sounds like that could well be the answer. Unfortunatley I'm m not sure how I go about making the recommended adjustment. Are you able to expand in a little more detail on what exactly needs to be adjusted i.e. where the relevant menu/switch/button etc is located.
    I would be most grateful for further guidance.
    Thanks a lot.
  • The Daddy Sep 12, 2007
    would appreciate further help as above??
  • Nas05 Nov 19, 2007
    I own an LG 50" plasma tv. It is 6 months old. Just recently i have noticed that as soon as i turn the tv on, i see a green hue wherever the picture is light. This is visible on all inputs, cable tv channel and dvd. I does disappear after a little while. I do not know how to fix it. Is this pixel burning?
  • Les Davis
    Les Davis Jun 14, 2014
    It is usually due to a faulty display made by LG. Please read my posts below.
    President:
  • LG Master
  • 776 Answers
Makes you wonder why nobody is taking on the problem, doesn't it?
Well , to the best of my knowledge, it is because nobody really can.
To understand why you have to understand what do they sparkles come from.
They are random electricity discharges coming from capacitors or other components that act like capacitors, but mostly capacitors.
When laymen hear about capacitors they usually associate the word with bulged electrolytic capacitors, which often cause problems in electronics of all kind.
Well this time it isn't about them.
It's about all other capacitors - or other components exposing similar qualities - which are installed on the board. Most of them are small filter capacitors put in parallel to the big ones or to other passive components such as diodes and resistors.
The excessive heat developed by the sustain boards damages those capacitors. It hardens the electrostatic material they are made of and small breaks in it start occurring at voltages that shouldn't otherwise be causing issues.
The trouble is, they can be everywhere. You can't just pinpoint which ones were caught at fault and causing the sparkles.
When it gets REALLY bad eventually the whole capacitor burns and either shorts or, more commonly, just breaks.
Believe it or not I've seen a board that exploded before my very eyes and , after the explosion, started working LIKE A CHARM!
Turned out a small filter capacitor had blown. It as not essential for the board's functionality and after being problematic for so long and causing image deffects it had eventually shorted completely and literally exploded.
Luckily, the short it had created was too short in time and apparently in a circuit that could take the load for a short while without getting damaged.
So after it blew everything worked just great!
it's a real story from my repair experience.
Hope this helps all consumers, DIY enthusiasts and competitors alike :-)
For more you are welcome to visit our site and read our tech repair blog at
http://www.coppelltvrepair.com
and
http://blog.coppelltvrepair.com .
Posted on Dec 04, 2010
A couple of months have passed since I contacted Akaii for service/replacement under warranty. They referred me to two service centers who both refused to make the service call -- unless they got paid extra from Akaii for the long trip. although I am in a major metro area, Akaii cannot find a service dealer to make the call and they say that replacing the set will take months.
They refuse to let me speak to corporate or even to follow up.
Do yourself a favor DO NOT BUY ANY AKAII PRODUCTS!!!
Posted on Feb 15, 2008
    Sergeant:
  • 247 Answers
Many TV's with an LG plasma display (or built by LG for other manufacturers) have a manufacturing defect that has been reported widly on the Internet. LG, Akai, Samsung and Zeneth among others.
The sparkles are (usually red) visible on a black background with all inputs after the set has been used approximately one year. Soon after a pop is heard and the picture no longer shows at all.
LG and some other manufacturers using the LG displays have not acknowledged this defect and will only repair them free during the warranty.
Often techs will merly adjust voltages and or picture controls, which does not fix the problem but it just disguises it -- until the display blows -- usually after the warranty expiration.
I own a 42" Akai that is 9 months old that has recently been showing the red sparkles. I just called for service but feel that the set should be replaced with a non defective one and a new warranty.
Does anyone know what the laws are about manufacturer defects and how to get Akai or LG to make good?
Posted on Jan 15, 2008
  • Les Davis
    Les Davis Jun 02, 2014
    Akai replaced my TV at no charge under waranty with another model. Although it also had an LG display, It is still working well after aproximately two years. If you got a defective LG plasma display it is a manufacturing defect and in my opinion should be repaired or replace at no charge even after the waranty has expired.
Mine had the same sparkling problem with red dots. Luckily I had an extended warranty because adjusting the voltages did not fix it and the actual plasma panel had to be replaced. Now I have colour problems where skin tones are not displayed properly and result in bright pink or green shades instead of true skin tones.
Posted on Nov 04, 2007
  • Les Davis
    Get the display/set repaired or replaced under warranty. It may have been replaced with another defective display.
Adjust the Vs and Vscan voltages on the panel power supply. Stay within the ranges on the sticker on the back of the panel. Usually a change of 10vdc is enough to cure
Posted on Aug 30, 2007
Unfortunately, I have no solution but a somewhat similar problem. I have my computer connected via an HDMI cable to my Vizio 55" 240 Mhz 1080i TV. When I use the tuner in the TV to watch TV, I have no sparkles. But when using the TV as my computer monitor, I've noticed sparkles in dark areas of whatever is being shown. The sparkles are not red. They are white. I have a avry dual tuner TV card in my computer that I use for watching and recording TV and it seems that the sparkles are the worst when using the TV tuner that's in my computer. But the sparkles are even there with my desktop screen. The video card in my computer is not the best nor the worse. It's an ATI HD6570 Radeon with 1GB of DDR3 memory with no fan for cooling. Just a large heat sink disippator. It appears that the sparkles get worse the longer I watch TV using the TV card in the computer so I suspect it's probably the graphics card that is causing the sparkles. If anyone has some insight on what might be causing the sparkles, I'd appreciate hearing from you.
Posted on Feb 15, 2012
I came across this LG 42PX5D 42 in. HDTV Plasma Television question on FixYa.com and thought you might be interested in reading it.
Sparkles.
My set is around 16 months old & has recently started doing this. it is linked to a Sky HD box.
I have several inputs including P.C using-(RGB)SKY -(HDMI), Home Cinema -(AV4) and DVD -(gold plate scart (AV2).
The problem is active on all connections/inputs despite checking the connections. Occasionally (very rarely) it disappears for a programme or 2.
At first didn't know if it was my sky signal strength but obviously, cant be that, if its active on all inputs. going to try the idea on fix to see if it works.
if anyone knows how to fix this, would be greatful Regards,
jason1
Posted on Oct 17, 2007
Samsung plasma tv 42inch PS42E THDX Blue sparkles on dark areas
Hi yes i had the same problem and its basically because the tv needs a software upgrade. I contacted argos and they sent an engineer to sort it and he plugged something into the back of the tv to upgrade it. all in all it took 5 mins to do and not had a problem since.
Jan 31, 2009 | RCA PHD42600 42 in. Plasma Television
LG 42PX5D sparkles on black
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 23, 2017 | LG 42PX5D 42 in. Plasma HDTV
Coloured sparkles appear in dark areas of picture
Sometimes just adjusting the VSCAN voltage inthe set will cure it. Other times it will be a faulty panel. Either case requires a technician to do the repairs.
Jun 10, 2008 | LG 42PX5D 42 in. Plasma HDTV
Plasma tv
change the z-sus panel or control panel
Feb 28, 2008 | LG 42PX5D 42 in. Plasma HDTV
Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Jan 14, 2008 | LG 42PX5D 42 in. Plasma HDTV
Lg 42pc1d plasma tv red sparkles
I had the same problem, LG came out and it turned out to be the board that filters out the interference around the screen. I pretty sure that was it, took them 10 mins to fix by replacing a few of the boards inside the screen. Sorry I can't be more specific but its not an unfixable problem, so nothing to worry about.
Nov 11, 2007 | LG 42PC1D 42 in. Plasma Television
Sparkles
call tech ..suggest main power pack..
Oct 17, 2007 | LG 42PX5D 42 in. Plasma HDTV
Vscan voltages on LG Plasma
Are your sparkles mainly red pixels flashing randomly over the TV screen, especially over darker areas? If so your sparkles are I believe a discharge problem, and can be fixed with a firmware upgrade, which I think resets and corrects the voltage and removes the sparkles, which is caused by misfiring of the gases produced with plasma TV's. I have had my TV repaired with a firmware upgrade, which takes only 10-15 minutes and is reasonably cheap repair, and now the TV looks great, no more sparkles. Don't play around with the voltages let the pros fix it, also beware! leave this too long and it can become permanent, and need a new screen which is half the price of the a new TV.
Oct 15, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 32LC2D HDTV
Many TV's with an LG plasma display (or built by LG for other manufacturers) have a manufacturing defect that has been reported widely on the Internet. LG, Akai, Samsung1.gif and Zeneth among others.
Often techs will merely adjust voltages and or picture controls, which does not fix the problem but it just disguises it -- until the display blows -- usually after the warranty expiration.
I own a 42" Akai that is 9 months old that has recently been showing the red sparkles. My set is being replaced.
You should contact service if your set has this problem is under warranty and it should be replaced at no charge.
Good luck. :)
Aug 07, 2007 | LG 32LX3DC 32 in. LCD HDTV
LG lcd tv 32lc2d
Good luck. :)
LG 42PX5D 42 in. Plasma HDTV Logo
4,804 people viewed this question
