Question about Whirlpool Dryers
Dryer awz 8465
I exedentaly turnd on dryer without filter,now it wont dry,I tryed claening it but it is after I turnd it on filter botton turns on(red) and it ofcourse stops with work...
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
ginko
  • 19396 Answers
SOURCE: condenser dryer not getting clothes dry
There must be one or two circuit breakers, usually at the back of the dryer, check them out.
If this does not fix the problem, then possible faults are the thermistor or the heating element.
Most likely you will need to have the heating element replaced.
If you decide to call a technician you can use the phone number listed on the owner manual.
You can find parts and diagrams here.
See also this website, the also sell parts and have some schematic: What is wrong with your Dryer?
Posted on Nov 05, 2008
onthejob5130
  • 640 Answers
SOURCE: 90 series dryer wont start
first check and see did any clohes fall down in the blower wheel,,from fillter no...check the belt that its not jammed,,check your idler wheel ...always unp[lug unit first.....now we will check motor ,turn unit on if you get a humming for about 10 to 15 seconds than a click,,replace motor
Posted on Dec 26, 2008
  • 23 Answers
SOURCE: dryer stopped working... wont turn on
Before starting troubleshooting-Unplug the dryer, because you will be removing front panel for this check.
There are several things that can cause your problem:
#1 of which is a clogged up lint trap and/or vent duct raising the heat that could cause your thermal fuse to open (blow). What to do: Make sure that duct and vent outside of wall are clear, if they were obstructed, then the thermal fuse can be checked for continuity with an ohm meter, it is located in the fan housing with 2 terminals coming off of it, if it does not have continuity (connection) between terminals, you will need to replace it, simple and less than $15 bucks.
NOTE: this problem can also be caused by a bad thermostat letting dryer get to hot which in turn blows the thermal fuse., sooo after changing thermal fuse you need to check that the temperature of air leaving dryer duct does not exceed 150 degrees, if it does replace the thermostat for less than $25 bucks, this maybe be what caused your problem in the first place. Good Luck!
Posted on Apr 29, 2009
  • 77 Answers
SOURCE: Whirlpool AWZ-7813 won't dry - no heat
it will either be you element or the thermostats that have failed.
Posted on Mar 20, 2010
We have a awz 865 dryer element & thermostat working yet clothes not drying what could the problem be
How can the heating element be working if the clothes don't dry?
Feb 28, 2017 | Dryers
Trying to get the service Manual for awz 3477 whirlpool dryer. The heating element goes on but after about 5 minutes it turns off + lint light goes on. Have cleaned the traps. thinking thermostat?
Have you cleaned the sensor bar? Did you remove the grates and clean out the lint traps, not the filter the actual traps? Does it have any codes stored? Most modern dryers can give error codes (even ones without a display)
Oct 13, 2016 | Whirlpool Dryers
Whirlpool AWZ 8578 - does not stop, always needs manual switch off
These symptoms most usually are a bad timer/control. If the dial turns all by itself, and continues to turn by itself like a clock does, it is likely a timer/control must be replaced. Same results if it will not advance by itself either.
You could type in "Sears Parts" for the new part, typing in your complete model number. If you wished to try a used control, after obtaining a part number, you could type that in to "e-bay" and see what you find in new or used parts there. I do.
Be blessed.
Feb 15, 2014 | Whirlpool Dryers
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
Whirlpool awz 475 washer/dryer combo, clothes will not dry. I have even used manual mode for drying, with no success.
make sure filter is clean, and that exhuast hose is not kinked , not allowing flow, , also door switch may be bad, or timer is defective
May 19, 2010 | Washing Machines
Mar 20, 2010 | Whirlpool Dryers
Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 11, 2009 | Dryers
Dryer thinks clothes are dry but they are not
1 start with claening the sensor strips located just inside the unit itself under the lint filter. pop yourheadinside dryer drum andyoull see 2 metal strips. witha scotchbrite pad, give it ascouruing, to remove any build up form fabric softener / dryer sheets
2 check for good, not kinked or clogged venting
3 replace the thermsitor about 30 bucks.
Mar 22, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
