Question about Raymarine C70 GPS Receiver
Lost data Hi my c70 unit shows land sea and coordinates, however it does not tell me where I am. Is there a setting I need to turn on to show the names of the areas on the chart plotter? I can figure it out by the lat and long but I am pretty sure that one point, this unit used to identify the area it was in. Thanks for any and all help
  • 16 Answers
SOURCE: Raymarine RL70CRC GPSRadar
Hi Matt,
There is a feature in these chartplotters called "Plotter Mode" that is often misunderstood and causes the exact problem you describe.
Press menu.....chart setup.....and scroll to the bottom until you see Plotter Mode in the list of options. It should be set in the OFF position.
If you have more than one display networked onboard check the setting in each one invividually.
What Plotter Mode does is allows the chartplotter system to access range scales not supported on the chart. It is not normally used for map-based navigation but more so for chartless electronic plotting (it can display routes, waypoints and track-recorder breadcrumbs.) open-ocean cruising, or for ultra-precise GPS operations (like a precision anchor drop, finding a very specific location etc. When plotter mode is on you can zoom in to a very, very small working area. The indicator it is enable is the cross-hatch background on the screen, the lack of map information, and the NO CHART DATA watermark on the screen.
Posted on Dec 28, 2007
SOURCE: raytheon rl70
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
Posted on Aug 17, 2008
SOURCE: RL70CRC crashes with new "Wide" C-map cartridge
get a new burn on the chip, I have seen this issue on a particular burn.
Posted on Oct 13, 2008
SOURCE: I have a raymarine rl70
A replacement backlight is available from a company called Being Seen Technologies,
I believe their toll free phone number is 888 457-0117
good luck
Posted on Jul 04, 2009
SOURCE: My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Posted on Apr 28, 2010
Testimonial: "Factory reset solved the problem. Soft key next to power button worked a treat!"
Height above sea level of my house in Southampton
3 metres
Geographic coordinates of Southampton, United Kingdom. Latitude ...
dateandtime.info/citycoordinates.php?id=2637487
Latitude of Southampton, longitude of Southampton, elevation above sea level of Southampton. ... Coordinates of Southampton in degrees and decimal minutes. Missing: my ‎house
Southampton - Wikipedia
https://en.wikipedia.org/wiki/Southampton Southampton is the largest city in the ceremonial county of Hampshire, England. It is 75 miles .... The city walls include God's House Tower, built in 1417, the first ..... [hide]Climate data for Southampton, elevation 3 metres (9.8 feet), 1981-2010 ... The centre of Southampton is located above a large hot water aquifer that ...
Frequently asked questions about Southampton in Queensland - Bonzle
www.bonzle.com > home > homesteads > Southampton
myBonzle menu: Add to my places Add picture Add story Add note. Skip to map ... What is the elevation/altitude/height above sea level of Southampton? Southampton is at an ... Old Parliament House, East Parliament House Picture relating to ...
An Oceanfront Home Built Above Sea Level ' Southampton, House ...
https://www.pinterest.com/pin/172122016986387096/
Southampton · House · House beautiful ... Balconies · An Oceanfront, Southampton Home Built 17 Feet Above Sea Level ...
Height above sea level of my house in Southampton Google Search
Oct 16, 2017 | Computers & Internet
Tip
Learn About an Aircraft, Part 1
First we'll cover panel instruments and how they're used.
Familiarize yourself with the six pack.The six instruments in the center of the instrument panel used mostly for IFR (Instrument Flight Rules) and are always in the following order:
  • Top left: The "Airspeed Indicator" shows aircraft airspeed, in knots. (nautical miles) per hour. It also displays the airspeed limitations in white, green, yellow, and red arcs.
  • Top center: The "Artificial Horizon" Has a small aircraft symbol that depicts the aircraft required attitude,for level flight, and shows whether the aircraft is climbing or descending, as well as the angle of bank.
  • Top right: The "Altimeter" a three hand clock type instrument that shows altitude of the aircraft in feet MSL, (feet above mean sea level).
  • Lower left: The "Turn and Bank Indicator" is a dual instrument which tells your angle of bank and whether you are in a coordinated turn. Sometimes called the "Needle Ball". For straight and level flight, keep the wings level and the ball centered.
  • Lower center:The "Heading Indicator". A stable gyro instrument that shows the aircraft's current compass heading. Use the Control Wheel to keep the aircraft on the desired heading.
  • Lower right: The "Vertical Speed Indicator" which tells how fast you are losing or gaining altitude, in feet per minute. Keep this instrument at zero to maintain level flight.
http://i.fixya.nethttp://i.fixya.net25643176-w123deulyqo0pc5nhlq3ghvj-3-0.jpg
on Apr 12, 2015 | Sport & Outdoor - Others
On google plus it allows you to share your location with whom ever you choose, so my husband and I share our location with each other, but for some reason his is always wrong, and it always shows him in...
Hi Brenda
You need an App that will give you your current GPS coordinates.
Install an App Like MotionX or similar. Check the Latitude & Longitude or Better still the UTM Easting & Northing (same thing but UTM is the new digital coordinates & is easier)
Compare one phone coordinates with the other phone.
they should be almost identical if your in same location.
Otherwise check your phone SETTINGS for GPS & how it's set up.
Even a standard Garmin GPS tracker (which I use for prospecting) can be set fro the wrong side of the world. Usually its set for WGS 84 or 94 & UTM. I have seen people set up for the northern hemisphere when they are in the southern hemisphere.
Also, you said that your husbands settings never change. Well... it's GPS either turned off or broken.
I also use my "Find My Phone" App to check on the wife.... and she's on her way home... so GoodLuck
Cheers
Trevor
PS
Poor choice of Brands.... but thats another story.
Aug 06, 2014 | Cell Phones
Can you show how to convert pola to rectangular o
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Hope it helps.
Nov 14, 2009 | Casio FX-115ES Scientific Calculator
Why is my coordinates off by 50-80ft. why? Side by side comparision of another gps shows my gps is not accurate.What do I do?
Your GPS is accurate for that brand. I have a Lowrance I Finder Pro. We could both put in the same coordinates and come up in different locations. It is just the way the different GPS's get their signal from the satellite. I use my GPS most of the time for a sport called Geocaching and so when I am given coordinates and don't find the thing I am looking for I so about a 30ft-60ft search around where my GPS took me. So yours is basically doing the same thing. I wouldn't worry about it......it's just the way the different models receive the signal that thows them off a bit. If you went out and got a set of coordinates and then I put those same coords into my GPS I would arrive at a completely different location as you. All is well....no need to worry.
Aug 07, 2009 | Garmin eTrex Legend Cx GPS Receiver
Just bought yester day turns on show card goin in
The animation is telling you to insert a data card, which should have come with the device. If you have already inserted the data card (make sure there isn't a blank in the slot) then the unit is faulty and needs to be returned.
May 17, 2009 | Tomtom RIDER 2nd Edition GPS
Garmin always 1/2 mile left of actual position
it could be the unit or the film on the windows of your car .... most of the time it is the unit messing up i have ran into this problem a few times installing
Aug 18, 2008 | Garmin Nuvi 660 GPS Receiver
ETrex Legend, GPS Coordinates from Google Earth Don't Match Basemap
Are you sure you're using the exact same format on GoogleEarth and your GPS?
GoogleEarth: save the waypoints in a KML file (NOT KMZ) to your computer, naming it appropriately.
Go to http://www.gpsvisualizer.com/gpsbabel/ and convert the KML file to a GPX file, using their converter. They will present you with a file to download. Download it and send those waypoints to your unit and you'll be set to go.
Apr 01, 2008 | Garmin eTrex Legend GPS Receiver
System Coordinator Password Reset
Press "Feature 985" - this will show the voicemail extension. Dial "9" and it will prompt you for a password. Using the dialpad, dial "RESETSMPSWD". This will change it back to the default of "0000".
Good Luck!
Mar 31, 2008 | Nortel Norstar 16-Line PBX Speakerphone
GPS car system
Most of the NUVI units will show you your coordinates, but none show you your altitude, to my knowledge. When you ask if they can be used as a "handreceiver", again, the NUVIs can be set to "Pedestrian" mode and used hand held.
Nov 25, 2007 | Garmin StreetPilot c550 GPS Receiver
Raymarine C70 GPS Receiver Logo
37 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
