Rus4265-wm need to replace plastic washer in canopy braces.
busboy2
  • 50 Answers
SOURCE: Washing canopy on Graco Snugride
if the wash is hot you might melt the plastic parts
Posted on Mar 01, 2008
  • 553 Answers
SOURCE: Screw backed out of wiper motor at the arm
I don't know the answers to a lot of your questions but you should be able to find the part you need at an auto salvage yard for a lot less than what you've been quoted.
Posted on Jun 13, 2010
Testimonial: "thank you for your help. Evidently, these wiper arms have never been removed, and after countless soaking in WD40 and trying to wiggle and lift of, (over an hour!) I finally used a wedge, a screwdriver and a hammer to get them off! Chipped windshield edge!!"
macnutz
  • 541 Answers
SOURCE: The plastic part on side of stroller that attaches
I doubt that can be found as a part but plastic can be welded google to find a local plastic welder. If the plastic is black the repair will be almost invisible,
Posted on Nov 11, 2010
  • 239 Answers
SOURCE: I have a Bugaboo frog. I accidentally broke the piece that attaches the canopy to the frame, on one side. What do I do now?
if it's within 2 years old it's covered.
Call toll free: image_gallery?uuid=6a479f2d-8718-40f4-b775-292deedb9bd4&groupid=10136&t=1318502576820 800.460.2922
Email : serviceus@bugaboo.com
Fax: 310.496.0988
Hours: Mon-Fri: 10am-7pm EST
http://www.bugaboo.com/all-products
Posted on Sep 07, 2012
sunjoyonline
  • 16 Answers
SOURCE: need part for a smith and hawken gazebo
As per your need you should contact with sunjoyonline(dot)com.Last month I bought one gazebo from this shop at a very suitable price.
Posted on Jan 29, 2016
Need part for a smith and hawken gazebo
Sorry but think you need to check with the maker not us
Sep 29, 2015 | Garden
Brace is broken
Metal brace for the canopy is broken. Is there a replacement that I can purchase.
Feb 22, 2014 | allen + roth Garden
Trouble code!!!!!!!!!!!!where and how do i get to this thermistor / te
Simple, Unplug washer, lean it back against the wall, brace it so it won't fall while you crawl under it. The thermistor is on the bottom front of the tub, some units twist out. Some you have to unscrew one or two screws. Download this, http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf and look at page 28. The thermistor is to the right of the heating element. Make sure the connections are tight. Replace if you are still getting an error codefor a thermistor problem. Good Luck, Appliance Specialists
Jan 26, 2010 | LG WM-2277HW Front Load Washer
Is there anything that can be done to stop the shaking and movement of the LG washer? It is on a ceramic/vinyl tile floor which we already bolstered from below with braces. Moving it to cement is not an...
I bought some black plastic snap together mats from Canadian Tire 12 inches by 12 inches and fairly thin. They are the ones you can put in your garage to drive your car on. A bit pricey but it solved the problem of "walking washer" also works very well as a sound dampener. Hope this helps. CAB.
Jan 04, 2010 | LG WM-2277HW Front Load Washer
How do I remove the canopy from evenflo infant carrier?
use a tiny flat-head screw driver to pull outwards on the tab (this is a blue plastic tab on mine) that holds the white plastic u-shaped (canopy part) in. I didnt think it would be this difficult but it is... the graco ones are much easier to take off to wash.
Apr 18, 2009 | Evenflo Embrace
Feb 28, 2008 | Graco SnugRide 8649
Changing the Canopy
The canopy has two plastic poles for shape that you can remove so you can put the material in the washer.
Aug 18, 2007 | Eddie Bauer Musical Rocking Bassinet...
Suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
Aug 14, 2007 | LG WM-1480FHD Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
