Question about Sirius Satellite Radio Sirius Starmate ST1 Satellite Radio Receiver
Static Hi, My radio has become static now and then. At first I thought it might be the signal or lack of. But, I found if I push the face plate it works fine for a moment, then back to static. If I keep pushing or pulling on the radio from the mount it works for a while. Is there something I can try before purchasing another radio? Thanks.
  • pbowler Aug 26, 2007
    I've narrowed it down to the connection between the medal plate and the control panel. It seems the connection is loose. How can this be fixed. Thanks.
  • 473 Answers
I had the same problem with mine. I purchased the Sirius FM direct adapter and now it comes in crystal clear.
Posted on Oct 07, 2007
SOURCE:
Hi. I have a blaunpunkt CD34 stereo in my car and it seems to be locked into one radio station as no buttons work accept the volume. It will allow me to play a cd but I can only adjust the volume on this...
is your radio come with remote control? you can confirm other function with remote control, if still working, then most likely the face plate connector connection is loose, you have to dismantle the radio out from car, and then open out the side screw secure the face plate to radio body, Unplug the face plate out from body and re assemble back to test.
Aug 20, 2011 | Blaupunkt Car Audio & Video
How do i get the dash off to pull the old radio out
I'm not totally sure about the La Sabre, but there should be trim screws that hold the Dash face plate in place. There are three on the top portion of the face plate, and I think three on the bottom . The face plate extends from Light switch on left to radio on right. You may have to tilt the steering wheel column down to remove the face plate from around the steering wheel. From what I remember, the only thing that needs to be unplugged from the face plate is the plug for the rear defroster. Also, there are clips that hold the face plate in place. They just push in and out. Once the face plate is off, you can get to the radio mounting screws.
Aug 16, 2009 | 1993 Buick LeSabre
No sound after dropping S350.
Probably one of two things:
The dropped caused the speaker leads from the PCB to Speaker to disengage (check the earphone jack, too... 'cause it is in the circuit)
or
The bounce cause the Audio amplifier IC to become desoldered from the PCB.
Mar 06, 2009 | Grundig S350 AM/FM/SW Radio
FM radio intermittent static on '95 volvo 940
Sounds like you either left something loose or lost a piece of shielding. Was there a filter on the antenna that you forgot to put back on?
Jan 10, 2009 | 1991 Volvo 740
1999 Mercury Radio don't turn on.
check for a accesories fuse if that is not blown or is non existent then you might have to pull your raido out and check the fuse that should be on the wire. by plugging in your emergency battery charging device you might have shorted out and popped the fuse on the raido. if none of this is the problem then it may possibly be that your "power" wire might have melted when the battery charger device shorted the circuit.
have a nice day and a nice year and i hope this fixes your problem.
Jan 03, 2009 | 1999 Mercury Cougar
Xplode cdx-gt460u CD Reset Error
REMOVE THE FACE PLATE THERE SHOULD BE A RESET BUTTON ON THE FRONT OF THE RADIO PUSH THAT AND TRY AGAIN IF THAT DOESNT WORK THEN PULL THE RADIO AND DISCONNECT FROM POWER 4 A LIL BIT AND THAT MAY WORK
Dec 29, 2008 | Sony XPLOD CDX-GT200 CD Player
How i install car stereo in sonata
I have a 2004 Sonata and I'm currently in the process of installing a new stereo system. It's really easy to remove the original radio, you just have to remove the wooden panel face plate that surrounds the radio and air vents.
There are two notches that pretty much lock the face plate on. Right above the ash tray and the bottom of the wooden panel face plate, there's a tiny notch that you can push up on. There's another one that's hidden right above the cigarette lighter. Just push a flat-blade screw driver into both notches and gently push up. Once you lift that up, slowly pull it towards you, and keep prying it open starting from the bottom and moving towards the top. Make sure you pull on it carefully since the air vent ducts and wiring for the fan controls are attached to the face plate. I didn't have to remove the wiring for the fan controls, since I was able to easily move the entire face plate out of the way.
There are four screws that hold the radio in place. Keep in mind, these are screwed in by some machine, so I'd recommend using a power screw driving so you don't end up stripping the screws. Once you remove the four screws you can easily slide out the radio and unplug the wiring harness and antenna.
I searched a lot of places for a converter that would fit directly from the wiring harness in the car to the plug in my new radio, but to no avail. I'm at the point now that I'm going to cut off the original harness in the car and splice the wires, and connect them to the new radio's wires using a crimper. It's really not that hard, but I wanted to avoid cutting and splicing since I previously thought you would lose a lot of sound quality. It turns out, I spoke with several people who did the same thing, and as long as you crimp the wires together properly, you really don't lose out on the sound quality. It's a fairly easy task since all the wires are color-coded, so just match the wires, splice just enough for it to fit inside the caps, and crimp them together.
Then just plug in the adapter into your new radio, screw it in, and you're good to go! I wish there were more adapters out there, but it looks like more and more cars are changing their wiring harnesses, probably to discourage us do-it-yourselfers and pay some insane amount of money to some chump in a dealership garage. Don't be discouraged though! It's really not that hard!
Dec 18, 2008 | 1999 Hyundai Sonata
1998 beetle radio buttons
The face plate buttons actually activate small buttons on a printed circuit board behind the face plate. When I removed the radio and then the face plate many small pieces of plastic fell from behind the face plate. These small plastic pieces align the face plate button to the printed circuit board buttons. My Beeetle is almost 10 1/2 years old so I imagine the plastic is just becoming brittle with age. I could not set the radio to FM, so I removed the face plate button and now slide a toothpick in the slot to toggle between FM1 & FM2. Not he best solution, but probably the most inexpensive one. I also made my on tool to remove the radio from a diagram found at: http://www.alientech.net/nbinfo/stereo.html
Jul 02, 2008 | 1998 Volkswagen Beetle
Radio Mic
Check the squelch on your radio thats not recieving. If there is a monitor button ( when pushed you will hear static) try pushing it.. then get someone to call you so you can check if you can hear them. On these radios you have 2 types of squelch....1 is called carrier squelch.... it basically opens when there is a strong enough signal. This lets you only hear strong signals and "squelch out" the distant ones and background static. The2nd. is "tone squelch" ... with your radio they are often called privacy tones. If you have 2 radios set with the same privacy tones you will only be able to hear each other... only radios that are transmitting with that privacy tone will be heard on your radio. Its a high frequency tone that can't be hear by the human ear that gets "embeded" with the transmitting signal. The recieving radio hears it and opens the squelch. So... if the radio thats rxing (recieving)your signal has its squelch set for just carrier squelch it will hear any signal thats strong enough to break the squech open.... basicaly any radio within a certain range. But if your radio (one with problem) has its squelch set for privacy tones you will not hear any other radios except the ones set with the same privacy tone.... the squelch will not open until it gets a tx signal with the right tone.... so if the txing (transmitting) radio is not using tone squelch but is using carrier squelch.... and the rxing radio is set for tone squelch... the rxing radio will not hear it. With tone (privacy tones/codes) squelch you need a tone to open the squelch and then the audio can be heard... with carrier squelch the squelch will open if ANY radio is within a certain range. Check the squelch setting on the problem radio... it could have a privacy tone set. Try pushing in the monitor button so you can hear static ( you want to hear everything including static) on both radios... tx on one radio at a time and listen if it can be heard on the other with the monitor button pushed. If you can't hear any audio when the broken one is transmitting then it COULD be the mic.... if you can hear both radios with the monitor button activated than the radios are txing and have tx audio and are working... if thats the case its the privacy tones that are the problem. Take care
Sep 12, 2007 | Garmin Rino 120 2-Way Radio
JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
Sirius Satellite Radio Sirius Starmate ST1 Satellite Radio Receiver Logo
285 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
Perry Mellott
Perry Mellott
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
