Question about Matsonic MS8137C Motherboard
Large hard drive
Now I have HDD 120GB I am planing to bay new one 160-200GB. Will HDD of this size work on MS8137C motherboard?
  • silver_srb Aug 27, 2007
    Latest drivers are from 2003.
    Do you have this motherboard and large HDD?
  • 39 Answers
You should be alright, just make sure you have the most recent bios drivers.
Posted on Aug 26, 2007
I plugged in a 120gb internal toshiba mk1234gax hdd2d16 hard drive and when turn laptop on it says SMART failure predicted on hard disk. how should i go about fixing this
Try turning off SMART in MotherBoard Settings (BIOS Settings) and if it won't work, Call a Computer Professional. If Warranty is alive, Call Authorized Service Center.
Mar 29, 2014 | Toshiba MK1234GAX 120GB 5400 RPM 8MB Cache...
Sata hdd very slow
hard drive maybe slow 5400rpm not 7200 rpm check drive speed on them
Nov 08, 2013 | Intel D101GGC Motherboard
MS8137C-when installing win xp starts then, of course, the computer restarts and then should the HDD begin boot windows, but throw me an error "no operating system found ".... hdd is active and...
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure your computer ram modules are securely seated with no dust in sockets hope this helps
Sep 05, 2011 | Matsonic MS8137C Motherboard
Kx18ds pro cannot boot hardisk ata or sata, but can boot from any OS live cd
what is the size of the hard drive that you used before you upgade to 160 gb, if you used a smaller size and the motherboard is working properly, then the motherboard doesnt support large hdd like 160, sometimes an update on the bios will be helpfull in order to support these large drive, hope these help
regards
michael
Nov 19, 2009 | Albatron KX18DS Pro Motherboard
What is the maximum size of hdd to used with abit kv7
Good day sir/maam, yes you can use a 1 TB HDD, get the SATA version depending on the bios but im not sure it be compatible with SATA1 on your motherboard, any new hard disk canor cant be read by any old motherboard, you may have problems with SATA versions, there are 3 versions, but the problem is the response of the hard disk. The rule of thumb, fast motherboards, for large hard disk, because it can access large amount of data very fast usually they are SATA3. So slow motherboards with large hard disk is kinda slow, you be bored. I suggest you stick on the recommended hard disk. If you want extra storage, get 3 hard disk and daisy chained them as master/slave.
Oct 14, 2009 | Abit : KV7 Socket A KT600 Motherboard
What max large hard disk support Matsonic MS8137c?
unlimited really the biggest harddrive that is out knw is about 2 terrabites if you have a Sata connector and if you have a IDE ribbon connector then its something close to that
Oct 09, 2009 | Matsonic MS8137C Motherboard
Replacing HDD in ACER 2920Z
never use internal HDD without knowing. Use same old HDD and use external hard dsc now u brouught 320 sata use casing now
Jun 18, 2009 | Acer Aspire 3690-2900 Notebook
Motherboard specification not available.
Are you uning the recovery CD or a new OS?
A new Os (XP) will allow the second drive even if the old one will not. Of course you can always add a USB hard drive and a USB PCI card to make it all work. What are you using this pc for seems a little old for todays applications. Suggestion If your going to use this that you Replace the main hard drive with a 120GB or larger, new video card at least 256MB if not 512 and at least 1 gig of memory as I believe it will only take a max of 1 gig. you cannot use vista as it requires more resources than this Pc can give to support the OS. you may want to try XP LITE as well one you get XP installed to speed it up a bit!
Joe
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
K8V-MX motherboard+HDD size limit
yes the mother board supports SATA However if you connect large Disks to the SATA connectors they are recognized correctly with full size. So leave your 500g and less HDs on the IDE and the big ones on the SATA. you can check this link for the manual for more information ftp://ftp.chiligreen.com/Desktop/Manuals/manual_a_k8v-mx.pdf hope this helps .thanks and Godbless pls appreciate by rating as fixyaa
Oct 03, 2008 | ASUS K8V-MX Motherboard
Matsonic MS8137C Motherboard Logo
71 people viewed this question
Top Matsonic Computers & Internet Experts
Ram kundu
Ram kundu
Robert Karst
Robert Karst
Gateway information...
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
