Question about Coleman Pulse 1750
Generator does not produce power
Does anyone know where I can get a repair manuel for a Coleman Pulse 1750 Generator/ Thanks
  • 211 Answers
SOURCE: coleman 5000 generator will not idle up under load
Hi
You have to find the governor linkage.There is a spring adjusting by a screw to increese speed to get more power.Try to locate it.
best regards savumihai71
Posted on Feb 03, 2009
SOURCE: I have a Coleman Powermate Pulse 1850 Generator.
If the generator hasn't been used for awhile the rotor may have lost it's magnetism. All you need is to re-excite it. There are several websites that explain how to do this. It's a good place to start.
Erick
Posted on Apr 04, 2009
SOURCE: generator will not produce electric power
SUBURA COLEMAN GENERATOR RUNS FINE..IT RAN OUT OF GAS AND MY UNCLE FILLED IT UP AND RESTARTED IT..HOWEVER HE LEFT EVERYTHING PLUGGED..LATER ON, WE NOTICED IT STOPPED SENDING ELECTICAL CURRENT TO THE PLUGS..DOES IT HAVE A FUSE OR DID SOMETHING POSSIBLE BURN OUT...HAVE NOT HAD A CHANCE TO TAKE THE COVER OFF TO SEE
Posted on Jun 10, 2009
protek480
  • 1723 Answers
SOURCE: I have a Coleman Powermate Pulse 1750 generator.
Engine speed is low, does your meter read frequency? Set for 60 Hz @ speed. I doubt there is a voltage regulator adjustment. This may help
Posted on Jun 26, 2009
  • 5603 Answers
SOURCE: I have a 1986 or 1987 coleman pulse 1750 generator
Read this info:
http://www.endtimesreport.com/dead_gen.html
Posted on Nov 02, 2009
Where can I find a copastor that is no longer made for a Coleman 1750 powermate generator
take that you mean capacitor( compastor)
take the unit to a gen set repair shop and they will have suitable capacitors or will know where to get one
Apr 11, 2017 | Coleman Electrical Supplies
Coleman pulse 1750. Low volts
If you have checked the AVR you can disconnect the rotor brush wires and force a field in the rotor with a variable DC supply (note brush polarity) if the AC voltage comes up, then the problem is in the voltage regulator, if not you may have a rotating short in the rotor.(Only present with centrifugal force) I assume you have checked the resisitance of the stator and rotor windings
Feb 21, 2013 | Coleman Pulse 1750
I have a coleman powermate pulse 1800ex generator w/subaru engine. It runs and produces no electricity.
try flipping the breaker or fuse this could be it or one of the wires came off the plug in or the plug went bad or the diod blew but all of these cane be fixed pretty easyjust need a meter to see what is bad good luck
Aug 03, 2011 | Coleman Powermate Powermate 5000W...
My coleman powermate1800w generator (pulse ) is leaking gas through a hole at the bottom of the round metal float-filter where you can see a screw is suppose to be there. it looks like a drain screw should...
The seal is bad so get the model number off the engine and the manufactures name as well. You did not state the name of the manufacturer of the engine so I can not reaaly tell you were to go to. Coleman does not produce engins. It can be a Tecumseh or a Briggs & Straton or ?? The yellow pages will list this under lawn and garden equipment or go on the web
Apr 16, 2010 | Coleman Powermate Subaru 5000W Portable...
I have a Coleman Powermate Pulse 1750 generator. The engine runs fine but lately I've noticed I'm only getting approx. 105 volts. Any suggestions.
Jun 25, 2009 | Coleman Powermate Premium Plus 6250W...
Need manual for coleman powermate 1850 generator
google it! use the specific search terms, Coleman power pulse 1850 - it worked for me!
Jun 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
My Coleman Powermate Pulse 1750 generator shuts down
Your generator should run a power tool rated at 10 amps. The 15 amps you mentioned for the PM1750 is for the DC rating. The AC rating is 11.6 amps.
May 28, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Erick
Mar 23, 2009 | Coleman Electrical Supplies
Coleman Pulse 1750 Logo
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
