Question about Garden
Push mower surging
My Honda HRS2162PDC surges works a little better when I give it choke.I have taken the carb. apart and cleaned everything and it still surges.What could be causing this issue which I thought was dirt or a vacuum leak which doesn't look apparent.
SOURCE: mower surging
let it surge, it will usually get better as it warms up. These 6.5 Hp engines are fine except they have an cheap badly designed carburator. Nothing can be done about this problem. They all surge eventually.
Posted on Jun 16, 2009
blown725
  • 15 Answers
SOURCE: My Honda 160 push mower starts and then runs rough
take off the bowl of carb....the main jet is clogged ....remove it with a screwdriver...a small piece of wire will work as something to clean it out.....clean the whole carb....fixed many of them...
Posted on Aug 24, 2009
mowerman1857
  • 389 Answers
SOURCE: Honda Harmony II HHR216 Governor Surge
You have dirt and/or moisture in your carburetor float bowl. Remove the bowl, clean it out, remove the main jet and clean it out and you should be good to go
Posted on Sep 14, 2009
bbreton
  • 437 Answers
SOURCE: honda mower with GXV140 engine
A new carburetor will definately help. The old carburetor may have some ports still clogged. I would also spray some penetrating oil in the spark plug hole to help loosen up the rings on the piston. It may smoke alittle when you fist start it up. Plus try some "engine start" spray, to see if the engine will crank.
Posted on Sep 28, 2009
redbeard00
  • 957 Answers
SOURCE: my cub cadet tank stops running 5-20 minuts after
Yes you may need a carb kit. It is not good practice to by-pass the fuel filter. The orifice in the jet is very small.
But anyways, There Could still be a blockage inside the carb, a small leak at the manifold, or the jet is worn out.
Let me know how it goes.
Posted on Apr 28, 2010
Motorcycle will start when choke is out but stalls when choke is pushed in
Carbs needs to be taken apart and cleaned. What I did with my GL 1500 SE was put in some Amsoil Carb cleaner(don't recall the proper name at this time) for cars in the gas tank and within a tank or so, it straightened right up. This may not be recommended by all but mine never run better.
Oct 19, 2014 | Honda VT 750 CD Shadow A.C.E. Deluxe...
My 1993 gl1500 goldwing does not want to idle unless the choke s partially on. It also surges. If I take off the choke it syops running
Sounds like either the fuel filter is dirty or the carbs need to be taken apart and cleaned of varnish buildup from old gas.
May 17, 2014 | Sport & Outdoor - Others
I have a MTD Honda Lawnmower that is having idling trouble. It starts great, but once the chock has disengaged itself the engine surges. If I continue to hold the choke on just a little, it runs just...
Generally this indicates a "lean" condition in the carburetor and there are no adjustments. Depending on your abilities, the best fix is to remove the carburetor and clean all the metering passages/jets. In some cases you are better off just replacing the carburetor. I have seen some Honda carbs. as low as $15-$20. Hope this helps to some degree.
Mar 08, 2011 | Mtd 22" Yard Machine Push Mower
After about 30 minutes engine will start surging, by partly pulling the choke out it will run better. The carb has been recently rebuilt as well as new filter and fuel line to carb. Tried different fuel...
Typically a surge is caused by a lean condition. I'd say the float is set to low and this is causing the engine to lean out & when you apply the choke it richens it back up.and the surge stops.
Oct 12, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
09 JD X 340 27hp Kawasaki eng\ surges
Hi
That is a fuel problem caused by stale gas you will need to remove and clean the carb with carb cleaner.
Sam
Jan 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Governor keeps surging fast and then slow
Check to see if the engine runs smooth will slowly pulling choke out. if it runs better without surging, then its a carb problem.
Also may have an air leak in carb gaskets
Nov 20, 2009 | Craftsman Garden
My Honda 160 push mower starts and then runs rough and or a little arratic and puffs of black smoke blow out of the muffler. I checked the choke and it is open. I pulled the air filter off and it seemed to...
Aug 24, 2009 | Garden
Mower surging silver serieslawn boy 6.5 h.p. tecumseh motor model lev 120 spec 362006a. I cleaned out carb bought a rebuild kit replaced o rings in center jet and another under float also little metal...
Jun 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Motor surges up and down
I would suggest that you give the carb a good cleaning. before you take it to a shop, you may want to try just taking the bowl off of the carburetor and rinse it out with carb cleaner. The bowl nut should be a 10mm metric wrench. Be careful and patient-everything needs to be put back together in the order it came apart.
Apr 27, 2009 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
