Question about Toro 52" 27hp Z Master Zero Turn Lawn Mower
Timecutter 74325 1129763 The switch won't engage the blades. I hear a clicking sound but that's it. Is it some kind of relay that's bad?
2 Suggested Answers
  • 6468 Answers
SOURCE: toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Posted on Apr 12, 2012
My timecutter z480 won't start using the ignition. Can jump it over on solenoid and it runs but the blades won't engage and key won't shut it off do you know why
Sounds like you need to get it serviced! You have a solenoid problem, which might tie in with a faulty switch, but the blades not engaging is a different problem. When was the last time you had it serviced?
You could test the ignition switch connections with a meter. You should have power on the first position and then a second set of power when you move to the second position which powers the solenoid. There should only be power at the positive terminal with the switch in the off position.
May 23, 2016 | Garden
Toro zero turn starts fine and stalls as soon as I disengage brake
Sounds like the seat switch is not reading you are in the seat. Without a wiring diagram, it is difficult to say exactly.
May 30, 2015 | Toro TimeCutter Zero Turn Lawn Mower...
Timecutter PTO clutch switch clicks when I engage the switch but will not engage the belts
Check under the deck and make sure the blades can spin freely, there will be resistance but mostly check to see if they are stuck. If they are not and can move, yiu can try to remove the belt from the pto, engage and see if it spins then. If it does not than there is probably an issue with pto clutch
May 12, 2014 | Toro TimeCutter SS5000 zero turn mower
Clutch won't disengage on my Riding Mower
WITH THE ENGINE TURNED OFF, open the hood and watch the engagement cable. engage mower lever and then disengage the switch sounds happy, possibly the cable is starting to seize up
Apr 19, 2014 | Husqvarna Garden
Pto will not engage
if something was stopping the blades the belt would make all kinds of noise if your hearing the relay click with a test light or volt meter check for power to the electric clutch if not check the safety switches start with the one under the seat
Apr 22, 2012 | Garden
YARD MAN 42 '' RIDEING MOWER WON'T START PROBABLY SAFETY PROBLEM
safety switches that all riding mowers seem to have include a seat/brake safety which means that you have to be sitting in the seat or the brake must be engaged for it to start. also there is the blade engaged safety, which means the mower will not start normally with the blades engaged.
if you meet those conditions check the switches themselves
non safety related, do you hear a click or a clunk when you turn the key to the start position, this is the starting coil pulling in to send power from the battery to the engine starter, all safety switches will interupt power from the key switch to the starting coil
if you hear the coil energize and the engine does not start you have low battery voltage or loose connection or some other mechanical problem
Jul 03, 2011 | Craftsman 25cc Gas Line Trimmer
My blades wont engage and just hear click sound?
No permanent solution, but you probably can get by once by "riding" the clutch engagement lever - pushing it only part way forward and holding onto it.
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Toro 52" 27hp Z Master Zero Turn Lawn Mower Logo
42 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
