Question about Freezers
Freezer coils ice up and rust
Freezer coils inside upright freezer rusting
  • 1314 Answers
SOURCE: Rust On Bottom Of Chest Freezer
id sand it paint it with white rustolm and go from there and no it couldn't there is a layer of foam between the bottom of the outside and in side
Posted on Feb 11, 2008
huuum
  • 750 Answers
SOURCE: Kelvinator Chest Freezer will not cool after spray painting rust spot.
Dear Landport2
Welcome to the site,
You said, you have a Kelvinator chest freezer, model number CFS101SM1W. This freezer is in excellent condition and was working ok. I notice that there was a rust spot on the bottom area so I decided to spray paint the entire inside with the appropriate appliance spray paint. After spray painting the freezer will not cool.
How old was your freezer?
This must be an ancient freezer!
And Unfortunately I was not able to tell you to leave it alone and not to turn it off!
You did not cause this!
Unfortunately it was so old that it probably was already on it's last legs.
Here is an interesting report I just read!
Repair or replace your appliances?
When to pull the plug on your old freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model ?
The answer depends mostly on the age of your ,freezer
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old freezers),
paying for a repair makes sense.
Note that freezer under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your freezer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new freezer.
Data also shows that it doesn't pay to fix a less-expensive freezer
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a freezer you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Oct 10, 2008
  • 311 Answers
SOURCE: I am accumulating ice inside my freezer
It needs to be defrosted. If ice builds up quickly again then start shopping for another freezer as the repair is not worth it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
  • 11 Answers
SOURCE: My GE upright freezer does not get cold.
Sounds like the system is low on freon. The other common problem is a dirty condenser. Insure the condenser is clean, if it is. You will need to charge the system with freon. Which only a qualified refrigeration tech should do.
duby1990
  • 370 Answers
Sounds like you are low on freon.
Posted on Dec 01, 2008
Why will it not come on?
The rust shouldn't make any difference.
When you plug it in, does the interior light turn on? If not, suspect the wall outlet - test it for power by plugging in something else. If the interior light turns on, listen very closely to the freezer. It should hum. If it doesn't, toy with the freezer control inside - it may just be turned off. Turn it to about midpoint and listen very closely to it again. If still no hum, wait a short while, then feel carefully on the outside of the cabinet - it may be running through a defrost cycle. The outside of the cabinet may get warm while that's happening, especially around the door gaskets. Wait a while (half an hour, an hour, for the defrost cycle to finish - the freezer should run then.
If it never hums, then the compressor isn't running, so adding freon won't make any difference. Instead, suspect the defrost timer - that's a little electronic circuit board inside.
If it HUMS but never gets COLD, then you potentially have a freon leakage problem. It's difficult at best, though, to refill a refrigerator or freezer - they don't usually have refill taps.
Oh, yes. If the internal light never comes on but you've proven that the wall outlet has power, it's entirely possible that the plug is bad and needs to be redone.
Jul 29, 2014 | Kenmore 12.1 cu. ft. Upright Freezer 2826
Why does my camper freezer have rust all over?
Probably condensation building up inside from running hot, cleaning out the coils with one of them dusters or vacuuming the coils (underneath the unit on some models or on the back of some models of refrigerators and/or freezers helps them to run cooler and to avoid that rust. With our pets I have to clean our freezers coil every 2 or 3 months.
Apr 23, 2014 | Thetford Norcold 618847 Refrigerator Part...
I have condensation coming off the refrigernt tube that runs from condenser to freezer also ice build up on inside to the point of tearing the metal on inside back panel. What causes this ?
A side door heater is already defective.
It has heating element, it is there to dry any moisture build up around freezer door.
When it become defective, moisture or condensation occur, hence moisture is there.
Causing it to rust build or develope on the metal of the freezer.
Rust weaken the metal and soon tearing it.
Have it check by a service technician before it getting worse.
Good luck.
Jun 26, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
I purchased a Sears upright freezer in 2007. We keep it in our kitchen. Recently I noticed brown spots on the door of the freezer. Upon looking closer, I discovered it's rust! What can I do? The...
dear sir /madam
i think you should use anti rust spray WD-40 on your door after make clean it with sand paper . after clean make same colour there coz your freezer is working good so i think no need to buy new.
hope answer the question
thank you
please vote!
Aug 23, 2010 | Kenmore 13.7 cu. ft. Upright Freezer 26442
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Fridgeaire upright freezer is getting warmer and warmer.How do I
there is no way of cleaning the coils.there maybe a problem with the compressor.you should hear a fan running inside the freezer when it is in the cooling cycle and the compresor is running if you do not here the fan running this could cause a cooling issue and the evaporator could be building up with ice.
check the rear of the freezer to see if there is any ice build up.
Jan 18, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My Whirlpool upright freezer keeps building up ice inside the bottom back wall. The fan starts rattling and freezer will not stay cold enough to make ice. If I take everything all out and leave it off...
Either your defrost timer, defrost heater or defrost thermostat has failed. All parts are located behind the lower back panel inside the freezer. Most likely are the defrost heater and defrost thermostat.
Jun 09, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
Frigidaire Upright freezer Baskey
remove the basket sliders frome each side and install a couple of nylon washers between the slide and the side of the freezer on each side it will narrow the distance and the nylon washers will not rust
Mar 24, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Freezers Logo
222 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
