Question about Vehicle Parts & Accessories
Blower switch is not working on my 05 dodge magnum rt 5.7
    New Friend:
  • 53 Answers
Check the blower motor resistor.
Posted on Jul 10, 2013
Where is the EGR selonoid fuse on a 05 Dodge Magnum 5.7L?
There is no solenoid fuse , the PCM - engine computer supply's the control voltage . You have a wiring problem ! http://www.obd-codes.com/p0404 Engine Code P0404 EGR Position Sensor Performance
Feb 25, 2016 | 2005 Dodge Magnum RT
2005 dodge magnum rt. a/c gauges not working an i cant tell how much ac im putting in because the high pressure side is not moving from 50psi. but if i turn car off it goes up
If both sides are reading the same, the compressor is not working, or you have the gauges hooked up to the same side somehow.
The system should read what the outside air temp is until the compressor starts running.
Aug 28, 2013 | 2005 Dodge Magnum RT
05 dodge magnum the a/c high pressure gauge dont move and it leaks it out but i cant check the pressure
You need professional a/c manifold to check the system
If you have no knowledge or training on any type a/c system,
then don't work on it,you will ruin it
Have a shop do that
Where is the resister for the blower motor on a '05 dodge magnum
Hi Rory, I'm glad to help. The blower motor resister is always close to the blower motor. Sometimes right next to the blower motor and sometimes on the side of the A/C Housing and always behind the glove box. Hope this helps and have an awesome day Rory!
Aug 02, 2013 | Cars & Trucks
My blower switch is not working on my 05 dodge magnum how to fix it and how to remove the face plat
If not working on any speed make sure check all fuses as they don't usually go could also be blower motor resestor
Jul 11, 2013 | Cars & Trucks
How to change the spark plugs in my 2005 dodge magnum rt hemi 5.7 ???
There are only 8 spark plugs there are also 8 coil packs over the spark plugs the you need to remove to get the spark plugs out
Jan 12, 2013 | 2005 Dodge Magnum RT
We just bought a 2006 R/T Hemi V-8 Magnum. The cruise does not work. It worked the other day, but thats it. How can we fix this? I need cruise control!
Its possible that you have a faulty crank shaft position sensor. Mine went out in my 05 RT and the car stalled frequently at stoplights and the cruise control would not work. It could be something else but after replacing my crank sensor I haven't had an issue.
Aug 24, 2010 | 2006 Dodge Magnum
05 Dodege Magnum blinkers and wipers not working
Both of these work from the turn signal switch. Replace the switch.
Jun 29, 2009 | 2005 Dodge Magnum
05 Dodge Magnum new long block
Might be a bad mass air flow sensor. Need a little more info. I am a crysler master tech so give a bit more info,plz
Jun 20, 2009 | 2005 Dodge Magnum
Strus or shocks in the front end of the magnum?
According to the replacement parts guide, they are struts and I checked for all wheel drive and 2 wheel drive and all are showing struts.
Apr 04, 2009 | 2005 Dodge Magnum
Vehicle Parts & Accessories Logo
54 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
