Question about Dell 942 All-In-One InkJet Printer
Dell 942 AIO printer cartridge problem
I recently installed a new black ink cartridge but ink levels are still reported by the printer as being empty.
  • Stephensm44 Aug 01, 2008
    I am having the same trouble. Did you find a solution. I installed new windows vista driver thinking that would solve it,but no such luck. Any ideas?
Was your replacement cartridge a new dell product? If it was, the sensor on the prnter should recognize it as new and reset the indicator to full. If, however, the cartridge was refilled, remanufactured, or otherwise an off brand, the ink indicator will show it to be empty. Just ignore and use the printer as normal -- it will print just fine, but you may need to press the select button to get it to start printing the first page.
Posted on Dec 11, 2008
SOURCE:
My Dell 926 AIO Printer will not print after installing new ink cartridge. Ink level on computer still says empty.
you must cleaned cartridge before you plug on printer, for level ink detection you must waiting for moment for ink spread on cartridge.
Mar 09, 2011 | Dell 926 All-In-One InkJet Printer
I have a Dell 942 AIO printer and though I have replaced both ink cartridges, the printer shows "Cartridge Missing - install black or colour cartridge on left hand side"
Have you removed the shipping tape on the print head of each cartridge? Is each cartridge locked in each of their housing? Try reinserting the cartridges. Turn the printer off then on again.
Nov 08, 2010 | Office Equipment & Supplies
Dell 942 AIO printer won't recognise black cartridge:
I think you purchased a black cartridge with bad electronics. Basically your cartridge can't communicate with your printer and you should exchange it for a new one. There is no way to "fool" your printer into accepting refills with bad electronics. What you can do is when you get the message that you aren't using genuine cartridges and it won't be able to estimate ink levels is to check the box indicating to ignore the ink levels.
Nov 13, 2009 | Dell 942 All-In-One InkJet Printer
Dell AIO 942 Error 2200
I would recommend cleaning off the contacts where the cartridge is loaded as well as the any other spots to see if maybe there is just something on the contacts.
Sep 19, 2009 | Dell 942 All-In-One InkJet Printer
I just put a new cartridge in my dell AIO 946 printer but it still says the ink level is low.
well this always happens with all printers. I have a HP, in the beginning when I first bought the printer, it came with a ink cartridges, it showed the levels. But after the ink was all gone, it showed empty ink levels. The best way to solve this is to ignore this. When you see that your paper is poorly printer, then your ink cartridges need changing.
Aug 28, 2009 | Dell 946 All-In-One InkJet Printer
WILL DELL AIO 942 PRINTER CONTINUE TO PRINT DOCS. IN BLACK IF
You print more documents then anything else, therefore you use more black ink, no color at all, assumption with information provided
Jul 16, 2009 | Dell 942 All-In-One InkJet Printer
I bought a new Dell color ink jet cartridge for my Dell All in One 942 printer and after I replaced it it still showed it as an empty color cartridge. I order it as new directly from dell. I tried to take...
  1. I TRIED HOLDING THE INK JET OVER A POT OF BOILING WATER AND THEN BLOTTED IT WITH A PAPER TOWEL AND PUT IT IN THE PRINTER..CICK ALIGINMENT AND IT WORKED!!!
Jan 18, 2009 | Dell 942 All-In-One InkJet Printer
Dell 942 all-in-one printer problems.
The problem is simple. Try inserting your old in cartridges. If the old ones work, the ink cartridges are defective. Contact Dell and get these replaced.
Otherwise the printer has a problem. try cleaning the metal contacts of the ink cartridge and the ink carrier.
Sep 19, 2007 | Dell 942 All-In-One InkJet Printer
Dell 942 All-In-One InkJet Printer Logo
197 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
