Question about Cameras
SHIMPO FGC-50B code OVP
Fault code OVP is displayed. Force 0.0 is displayed when a force is applied
INTERLOGIC
  • 326 Answers
SOURCE: apply force to cable for phone to charge
try cleaning the connecting point
Posted on Jul 07, 2009
mulmol
  • 184 Answers
SOURCE: how to get a code of special force e-coin? no
steal it!
Posted on Oct 07, 2009
SOURCE: GE Profile top load washer - Agitator rotates very slowly with li
Agitator coupling is worn out. Replace coupling underneath the agitator (WH43X10032)
Posted on Oct 14, 2009
bala0605
  • 3 Answers
SOURCE: i have lost my key code for delta force 2 can you
The keycode is:
JKU7-CFKD-V4BJ-2VYQ-S5PP
Posted on Dec 19, 2009
  • 47 Answers
SOURCE: hi! my name is ali and i was used NVIDIA G FORCE
try another monitor or try bending the monitor cable. Sometimes a loose wire is the problem
Posted on Jul 23, 2010
What is the causes and remedies of drilling fault such as drill breaking
Drills (bits) typically break when too much force is applied at an angle to the workpiece. To reduce breakage, drilling should be perpendicular to the work.
If one is attempting to drill at an angle, less force should be used. A dull bit will always require more force when drilling. Angled holes should be drilled with a sharp bit to reduce the possibility of breakage.
Aug 12, 2014 | Drills
Change driver side cv axle I got it out need advise on how to get it to seat all the way back into place.
The axle must be "wiggled" while you apply force to seat it in the transmission. A helper would be good to have. Have your helper wiggle the shaft near the transmission, while you apply force, possibly some light to med knocking force to seat it. DO NOT USE A HAMMER!.. I use my foot to kick or knock it in.
Dec 04, 2013 | Cars & Trucks
A cricketball of mass 70gramme moving with the velocity of 0.5m/s is stoped by a player in 0.5 seconds.calculate the force applied by the player to stop the ball?
this is the wrong section, Anyway, to solve your problem you have to consider that F=m*a, and a=v/t. So, the force you hare looking for is F=-(70*0,5)/0,5=-70N where the "-" sign means that the force is applied in the opposite direction of the movement of the ball.
Hope it helped,
Franz
Mar 02, 2011 | Computers & Internet
What force are involved when a person opens a door
The door was once at rest and now it is moved so a force must be involved.
If the force you applied to the door is big enough, the door will move. The door will even apply its own force to you. Whenever an object A exerts a force on another particle B, B simultaneously exerts a force on A with the same magnitude in the opposite direction. Oh and since we're on earth there's always the force of gravity to consider. So you and the door don't float away.
Nov 20, 2009 | The Learning Company Achieve! Math &...
Auto zooming on power up, intermittent problem
Possibly a intermittent connection in the control buttons or the ZIF (Zero Insertion Force) connector from the controls to the main PCB.
Take it in for servicing, they will do a trial by substitution (swap out control) and lubricate the connector.
There isn't really anything you can do to fix with this sort of problem.
Cheers.
Sep 28, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Is the t603 and r672 part of the tv or the actual circuit breaker
Three blinks - B over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
DOES THIS ABOVE issue have anything to do with Cooling FAN?
I cannot hear the cooling fan come on when first turned on like
before THANKS
May 05, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
What is the program code to shutdown the pc in visual basic
I was wondering if someone could help me to convert this vb6 code to be used
in VB.net. It basically allows you to call the subs at the bottom to logoff
shutdown and restart the pc (By force if necessary). Any help is greatly
appreciated.
Private Const EWX_LOGOFF = 0
Private Const EWX_SHUTDOWN = 1
Private Const EWX_REBOOT = 2
Private Const EWX_FORCE = 4
Private Const TOKEN_ADJUST_PRIVILEGES = &H20
Private Const TOKEN_QUERY = &H8
Private Const SE_PRIVILEGE_ENABLED = &H2
Private Const ANYSIZE_ARRAY = 1
Private Const VER_PLATFORM_WIN32_NT = 2
Type OSVERSIONINFO
dwOSVersionInfoSize As Long
dwMajorVersion As Long
dwMinorVersion As Long
dwBuildNumber As Long
dwPlatformId As Long
szCSDVersion As String * 128
End Type
Public Type LUID
LowPart As Long
HighPart As Long
End Type
Public Type LUID_AND_ATTRIBUTES
pLuid As LUID
Attributes As Long
End Type
Public Type TOKEN_PRIVILEGES
PrivilegeCount As Long
Privileges(ANYSIZE_ARRAY) As LUID_AND_ATTRIBUTES
End Type
Private Declare Function GetCurrentProcess Lib "kernel32.dll" () As Long
Private Declare Function OpenProcessToken Lib "advapi32.dll" (ByVal
ProcessHandle As Long, ByVal DesiredAccess As Long, TokenHandle As Long) As
Long
Private Declare Function LookupPrivilegeValue Lib "advapi32.dll" Alias
"LookupPrivilegeValueA" (ByVal lpSystemName As String, ByVal lpName As
String, lpLuid As LUID) As Long
Private Declare Function AdjustTokenPrivileges Lib "advapi32.dll" (ByVal
TokenHandle As Long, ByVal DisableAllPrivileges As Long, NewState As
TOKEN_PRIVILEGES, ByVal BufferLength As Long, PreviousState As
TOKEN_PRIVILEGES, ReturnLength As Long) As Long
Private Declare Function ExitWindowsEx Lib "user32.dll" (ByVal uFlags As
Long, ByVal dwReserved As Long) As Long
Private Declare Function GetVersionEx Lib "kernel32.dll" Alias
"GetVersionExA" (ByRef lpVersionInformation As OSVERSIONINFO) As Long
Private Sub EnableShutDown()
Dim hProc As Long
Dim hToken As Long
Dim mLUID As LUID
Dim mPriv As TOKEN_PRIVILEGES
Dim mNewPriv As TOKEN_PRIVILEGES
hProc = GetCurrentProcess()
OpenProcessToken hProc, TOKEN_ADJUST_PRIVILEGES + TOKEN_QUERY, hToken
LookupPrivilegeValue "", "SeShutdownPrivilege", mLUID
mPriv.PrivilegeCount = 1
mPriv.Privileges(0).Attributes = SE_PRIVILEGE_ENABLED
mPriv.Privileges(0).pLuid = mLUID
AdjustTokenPrivileges hToken, False, mPriv, 4 + (12 *
mPriv.PrivilegeCount), mNewPriv, 4 + (12 * mNewPriv.PrivilegeCount)
End Sub
Public Sub ShutDownNT(Force As Boolean)
Dim Ret As Long
Dim flags As Long
flags = EWX_SHUTDOWN
If Force Then flags = flags + EWX_FORCE
EnableShutDown
ExitWindowsEx flags, 0
End Sub
Public Sub RebootNT(Force As Boolean)
Dim Ret As Long
Dim flags As Long
flags = EWX_REBOOT
EnableShutDown
End Sub
Public Sub LogOffNT(Force As Boolean)
Dim Ret As Long
Dim flags As Long
flags = EWX_LOGOFF
End Sub
Jan 01, 2009 | Microsoft Windows XP Professional With...
12th science maths(derivation,vector,conic section)
This is a repair and consultation forum. Are you doing homework, or do you have a technical question on a consumer, industrial, or commercial electronic product?
Feb 25, 2008 | Televison & Video
Sony KV30hs420 0 Stanby Light Timer Blinks 3 times and powers TV off
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. If you have electronic knowledge you may be able to fix it. Let me know if I could help you further.
Hope this helps.
Jan 25, 2008 | Toshiba CN36X81 TV
Cameras Logo
22 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
