Question about Samsung Refrigerators
I have samsung refrigerator model # RF323TE THAT THE ICE MAKER IS FREEZING UP
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
mikedurland
  • 481 Answers
SOURCE: ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Posted on Jul 05, 2008
MNTECH
  • 1543 Answers
SOURCE: not cooling or freezing
When the compressor is running, both the fan inside the freezer and the fan down by the compressor should be running. If OK, look for frost on the back wall of the freezer, indicating a probable defrost heater failure. If yes, remove back metal cover in freezer, defrost with hair blower, replace defrost heater (the thing at the bottom of the freezer coils with two wires going to it)
If no to these, send me an "ask me" follow up question.
Posted on Aug 28, 2008
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
SOURCE: lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Posted on Jul 12, 2009
What does error codes 8E and 26 E mean
You have a defective sensor or the main board is defective. Will take a service call
Oct 28, 2015 | Samsung RF323TE 31.6 cu. ft. French Door...
Why will the ice not dump? I replaced the ice maker because it was not turning to dump the ice after the ice was frozen. Same problem with new ice maker. Reset button causes the ice tray to turn, dump...
Your ice maker is controlled by the main board. The ice maker has a sensor that tells the board what the mold temperature is. The first step is to make sure your ice maker is turned on. There is an "on/off" setting on your control panel. Look very closely at the glass depicted. Some models show ice cubes in a glass, others have the words ice off. It's difficult to tell without looking close. If your ice is on, a Samsung qualified tech should be called to check connections, and the board.
Apr 29, 2014 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
How do I change the water filter for the refrigerator, Samaung RF323TE
Page 13 of the User Manual explains where and how to change the water filter RF323TE User Manual
Click link below for instructions
Where Is The Water Filter And How Do I Install It on my French Door or Side-By-Side Refrigerator?
Or click HERE If you have questions or trouble navigating the Samsung site please ask questions and I will try to assist you, Thanks Sea Breeze
Mar 31, 2013 | Samsung RF323TE 31.6 cu. ft. French Door...
I would like to ask for some info and troubleshooting techniques in which my refrigerator samsung model number RT22S. I noticed that the water inside the water bottle container is freezing and most likely...
Its not normal.The problem is related to defrost.Unplug unit from power outlet for 12 hours and then reconnect it and start.These resets the refrigerator.But its not working even after reset then internal defrost assembly and condenser/ compressor needs inspection.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
My ice maker stop working and so did the to part of my freezer its not freezing
you have a freezer problem. lots of possibilities, computer, compressor, start device, power board, sensors. cheaper in the long run to cal a pro and replace only what is needed.
Apr 29, 2012 | Samsung RS2530BBP (25 cu ft) Side by Side...
Ice maker filling with water but not freezing into cubes.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
Samsung refrigerator model RS2577SW. Can't lower
Try turning off the unit. Then leave both doors open for 48hrs to defrost it 100%. Now try moving the icemaker bar as there may be ice in side freezing it solid. If not I'd say it's time for a new ice maker Cheers
Mar 28, 2009 | Samsung RS2578BB Side by Side Refrigerator
Ge tfx20jr side by side
make sure your freezer freezing if freezing check water valve check icemaker
Mar 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker freezing up
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
Oct 16, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
158 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
