Question about Murray Garden
Why is lawn tractor crankshaft pulley smoking
I have replaced everything, from gas lines to transaxle pulley. Brunning smell and smoke began coming from under engine. The crankshaft pulley was smoking!
  • 2,049 Answers
Sounds like something is binding. or belt is slipping. Does it smoke when not in gear. Check and see if everything turns by hand when out of gear and no motor running. Make sure its not binding anyplace. If that is ok Start it up and just idle the engine and try to run the deck and put it in gear. If that stalls it out then you do have a problem.
Posted on Jan 07, 2017
rockitman187
  • 2559 Answers
SOURCE: loud screech noise from deck area
This can be due to a belt slipping or a bad spindle bearing.
And on the difficulty scale,10 being extremely difficult, The belt would be a 1 or 2 and the spindle about 6 or 7 (because the deck usually needs removed for this job)
Posted on Apr 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: White smoke from my Craftmans tractor,
Use the lawnmower's oil dipstick to determine whether the oil level is correct. Maintain the correct level of oil. If you've overfilled the oil, open the drain plug, and drain some of the oil into a waste container.
Dispose of any excess oil properly. Burning off excess oil is undesirable. It can foul the mower's spark plug, piston rings, and other engine components and contributes to air pollution.
If your mower's engine has not been overfilled with oil, but still is smoking, it may have stuck or worn piston rings or another maintenance problem.
If it has sat over the winter, and didnt have stabilizer in it - it may be bad gas too. Drain it out, and put in fresh.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 10, 2009
wadembly
  • 489 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
  • 133 Answers
SOURCE: what would cause white smoke from the front of my
It could be your valves. My friends mower was blowing a lot of smoke and I think some oil. I replaced the valves and it runs like a dream.
I can't remember the steps to remove and replace, sorry.
If you are mechanically inclined it shouldn't be that hard. The only problem I has was the new valves (keeper or whatever holds them in place) was different than the old one.
You could call a repair shop and get an estimate.
Good luck. Let me know if this any help.
roundo4
Posted on Aug 16, 2009
Testimonial: "Thanks for your opinion - now I have a few options to consider as I tackle to problem in the morning. Navytime"
  • 6 Answers
SOURCE: smoke when blades engaged on yardman 42'' yard tractor
The oil on your pulley could definitely be the culprit. You need friction in order for your belts to work properly.
Posted on Apr 18, 2010
Wizard 42" (Craftsman) lawn tractor transmision locked. Belt smokes. 6 speed transaxle
if the trany is locked up u will have to remove the trany
most the time its the needle bearings on the input shaft
there 10-15$ each takes 2
but trany has to come aparts
they are fairly easy to open n fix them
Sep 14, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My craftsman lawn tractor smokes when I start it and it is blowing oil out. What is causing this?
check the oil and see if it smells like gas the needle valves int he carb have had alot of problems seating and gas over flows into the crank case change the needle and seat and change the oil
Jun 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftman 917.270.711
check to see if the oil smells like gas the needle valve in the carb doesn't seat and gas drains into the engine the oil gets thin and burns it fast
May 30, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn mower engine smokes
check the oil and see if it smells like gas the needle valve in the carb can leak and drain the gas into the crankcase
May 11, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Husqvarna CT151 Smoking
the belt is smoking because a pulley isnt spinning like its supposed to. its gonna break the new belt if you don't remedy the problem. try taking the belt Back off. then see if you can spin the pulleys by hand with no belt .
Jul 31, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have CraftsmanLT1000 lawn tractor, Smokes heavily.
First check the oil, not only the level but the smell
if its overfull and it smells like gasoline then the problem is that your carb is dirty or the float is sticking and flooding the engine with gas. If the oil is at the correct level then the problem is more likely the valve stem seals, as the engine warms they leak. I presume you have checked the airfilter is clean? The choke is comming off completely when you move the throttle cable? The LT 1000 is the entry level rider in the sears line. The engine usually starts wearing out in about 50 hours use. Remember the sweetness of low price is long forgotten with the bitterness of low quality!
Nov 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Wont go and screeches when letting off clutch/brake
Take off the shift plate between you legs, put it in nuetral, crank up the engine, put speed lever in high gear and slowly let off on the clutch. Everything will work as if in gear, it just won't move. you should be able to see what the problem is. Which belt did you replace and why? Watch the varible speed pulley (the one both belts go around). The bearings may be bad in it and not letting it turn, thus, smoking the front belt.
Jun 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hard starting smokes white like gas is getting into cylinders
White smoke in a small engine is oil. Oil in the cylinder will create too much pressure for the engine to achieve compression. Make sure the engine is not getting fuel into the oil and thinning the mixture (literally smell the oil... gasoline and oil smell nothing alike, if it smells like gas, it is). If this is the case, the carb is leaking fuel into the engine, thinning the oil and causing the oil to leak past the rings into the cylinder head, through the valves and, from there, into the exhaust to burn off. Black smoke indicates a direct fuel issue in a small engine, white is oil based.
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
63 people viewed this question
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
