Question about Ricoh Copier Toner for Aficio 551 700 Type 5105D Black RIC885235
Ricoh aficio sc364 error code
Sc 364 qual o probrena
jaylex
  • 417 Answers
SOURCE: error code 0-09
Hi there I can only find in the service manual 6-09 and 9-09 I will attach the reasons for both if they are of any help great if not there are no tech bulletins for this machine that says otherwise.
Thanks J
9-09 Paper jam in the fusing exit
area
If the problem persists, replace the FCU.
6-09 G3 ECM - ERR received Check for a noisy line.
Adjust the Tx levels of the communicating
machines.
See code 6-05.
6-05 G3 ECM - facsimile data
frame not received within
18 s of CFR, but there was
no line fail
Check the line connection.
Check connections from the NCU to the FCU.
Check for a bad line or defective remote terminal.
Replace the FCU, FCU or NCU.
Try adjusting the rx cable equalizer
Cross reference
Rx cable equalizer - G3 Switch 07 (PSTN), G3
Switch 08 (PABX)
Posted on Jan 06, 2008
SOURCE: i need some information about
please tell me the problem of canon fax-L100 error code of <100>
Posted on May 22, 2008
Bubbabear64
  • 2794 Answers
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
SOURCE: Have a Ricoh Aficio 3025
ERROR SC 548
Posted on Nov 07, 2008
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
What could be the problem on ricoh printer sp c420dn its given me error code sc 364
Probably you have just replace some of the toners (black). The toner density is too high. Restart printer and try to print full A4 black page.
Aug 30, 2014 | Ricoh Aficio SP C420DN Laser Printer
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
I have a ricoh c410dn and it has an sc364 error.
sc364 is a black toner density error. Typically, replacing the black PCU will get rid of the error message.
Feb 18, 2011 | Ricoh Aficio SP C410DN Laser Printer
I get an error sc361 and sc364
sc 361 Magenta TD sensor (pcu)
sc 364 Black TD sensor (pcu)
check if the pcu's are in position tight
May 08, 2009 | Ricoh CL4000DN Laser Printer
Error code sc364 I have exactly the same problem Ricoh no help wat so ever. Now have a heavy paper weight!
there is no specific error code decoding for this error sir.
this must be as service error.
please refer to a service manual for decoding this error.
Aug 08, 2008 | Ricoh Aficio SP C411DN Laser Printer
Error code sc364
reseat or replace black drum unit. Open left side 1 screw and reseat drums
Apr 26, 2008 | Ricoh Aficio SP C411DN Laser Printer
Ricoh Copier Toner for Aficio 551 700 Type 5105D Black RIC885235 Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
