Question about Arcam Audio Players & Recorders
Connecting a subwoofer to Arcam AVR350
I want to connect a subwoofer to my Arcam AVR 350. I don't see a dedicated terminal on the AVR 350 to connect a subwoofer. How do you do it?
5 Suggested Answers
ttech
  • 139 Answers
SOURCE: connecting a PASSIVE subwoofer to the denon AVR-1507
Yes on B Connect Left+ Right+ Equals Mono And Turn on B Side with A
Posted on Jul 20, 2007
SOURCE: Arcam AVR 200 OSD
Hi
Think you might have to use composite video out for the OSD menu to appear. Think I heard somewhere S-Video out doesn't work for.
Haven't tried yet on my own, but I will in time :)
Cheers,
Simon
Posted on Jan 30, 2008
SOURCE: arcam avr 300 keeps switching off intermitently,
I wonder if anyone can help explain what the likely problem will be with my Arcam AV300 amp. Whilst watching TV for no particular reason an extremely loud (what i can only describe as feedback) sound comes out of my B & W speakers for approximately 3 seconds, then silence as the Arcam switches off, I’m then unable to switch it back on for a period of time, (this varies between 5minutes to a few hours) when it eventually switches back on everything seems to be working perfectly. This has happened quite a number of times although it’s intermittent & occurring every 1 - 6 weeks.
Posted on Dec 13, 2009
dunnbiker
  • 8546 Answers
SOURCE: My receiver doesn't have a dedicated subwoofer
That would depend mostly on your subwoofer. There are some that slave off the front left and right speaker outputs and still pass the amp's power to the Front Speakers. That would be the only way that would ensure volume control.
Otherwise you have to feed a self-powered sub from the Tape Outs but that won't allow volume control from the H-K.
Posted on May 29, 2010
Arcam avr-250 shuts off after 2 seconds?
check the vent area, need to be clean, also insure the cooling fan is runing
May 28, 2014 | Arcam AVR-200 Receiver
Using an avr 350 on direct can you use subwoofer?
you can use a sub on any reciever/ amp if the sub has the right inputs, please be more discriptive and specific with make and model of components
Mar 08, 2013 | Audio Players & Recorders
Recently had the amp repaired. Set up used to play sacd fine but since repair the sub offer does not play on sacd. Plays on everything else fine. Can only assume a setting has been changed in the avr200...
It's in the manual.
The ".1" in 5.1 is for the subwoofer. Recheck the analog cable for that channel as it comes from the unidentified SACD player. If you had mentioned the make and model of it that would have been helpful.
Jun 27, 2011 | Arcam AVR-200
Hi, I have a denon AVR 889 about 4 years old and the subwoofer suddenly stopped working,how can i check if its the amp or the sub thats the problem?
A Denon AVR 889 is not a sub so we don't know anything about the sub in question.
Maybe the existence of the sub is no longer set in the AVR. Look at the speaker definitions first before going to wild.
Try another cable to the sub.
OR, run the sub's signal supply cable to one of the Tape Outs on the receiver and tune in something on FM. If that works a) it will be loud, and b) go back to the SUB settings on the AVR.
Crack the sub open and access the terminals on the speaker itself. Disconnect them from internal components and run one of your amp channels directly to it. If it works, the amp or signal path are dead. If it doesn't work, it's a dead driver.
May 19, 2011 | Denon AVR-889 Receiver
We just purchased an LG, LED, LCD, TV and just realised that our existing Arcam AVR 100 does not have an optical out. Does this mean we need a new amp or are there alternative solutions? Many thanks.
Actually, it doesn't have ANY digital outputs. Just what do you require one for? Name specific models and functions when replying.
Do you think the TV NEEDS optical audio from the receiver? Maybe the TV could survive on just analog audio from the video source, while the GOOD audio goes to the ARCAM since the ARCAM is going to do the hard work of managing and driving the REAL speakers.
http://www.arcam.co.uk/_ugc/file/avr100e_manual.pdf
Feb 06, 2011 | Arcam AVR-100 Receiver
I do not how to connect subwoofer to this one...
There are two ways that I see for connecting a subwoofer to this unit. One input and one pre-out connection, both are analog connections. Both connecting sections are placed laterally from each other about the center of the panel. I can see the high probability of confusion with the connection options.
Connect your subwoofer via the terminal labeled "sw" in the Pre-out section.
Oct 31, 2010 | Denon AVR 3808Ci Receiver
How to hook up a computer sub to a hometheater amp
http://www.arcam.co.uk/_ugc/file/avr280e_manual.pdf
If you have the whole Z5500 package you could run the Arcam's optical- or coaxial digital audio output to the corresponding input on the Logitech.
But I'd be careful about letting BOTH the Arcam and the Logictech perform Digital Sound Processing on the sound. DSP's aren't meant to be stacked. My money says the Arcam is better in the DSP department than the Logitech.
If you have just the sub, run the Sub PRE out from the Arcam to the Sub/Center input (adapt it to 3.5 mm) on the Control Center and set the switch to "6 ch direct".
Mar 06, 2010 | Jensen JW250 Main / Stereo Speaker
Arcam AVR 200 OSD
Hi
Cheers,
Simon
Jan 11, 2008 | Arcam AVR-200 Receiver
Connecting a PASSIVE subwoofer to the denon AVR-1507
Jul 01, 2007 | Denon AVR-1507 Receiver
77 people viewed this question
Top Arcam Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
berggei
Are you an Arcam Audio Player and Recorder Expert? Answer questions, earn points and help others
