Question about Pool & Spa
Intex 12x20x48 how many gallons of water does it hold
2 Suggested Answers
  • 8404 Answers
SOURCE: how many gallons of water
Depends ... 15 feet round? 36 inches deep? = 3976 gallons
15 feet by 36 feet rectangle, how deep? if 5 feet deep = 20,250 gallons
Hope this addresses your question.
Thanks for your interest in FixYa.com
Posted on Jul 10, 2011
How many gallons of water the intex 15x36 pool holds?
Jul 10, 2011 | Intex Easy Set Pool 15x36
HOW MUCH WATER IN INCHES AND GALOONS DOES A 10FT ROUND AND 30 INCH HIGH METAL FRAME POOL HOLD ?
It will hold ~1175 gallons assuming it is filled to 24" deep. The formula is pi x radius x radius x depth x 7.48.
John
Mar 14, 2011 | Intex "" Metal Frame Pool Set (56998e)...
What is the screw or nob in the middle of the intex 530 gallon pump lid for.
That is an air release valve screw. After you fill you rpool with water - open this screw until water comes out then tighten until sealed firmly. Turn pump on.
This allows the air to be released from the pump chamber "priming" the water flow.
Aug 05, 2010 | Intex Easy Set 530 Gallon Swimming Pool...
I've been reading the blogs and have ascertained that the intex filter is too small to properly circulate pool water for optimum salt chlorination. i have a Krystal Clear system model CS8110 and would like...
You have about 8588 gallons of water in your pool ... One inch of water contains about 159 gallons in your pool. You should consider a 6 hour turn over rate. I recommend a high rate sand filter with at a minimum 1.5 sq feet of filter area. You need to move about 24 gallons a minute to achieve the 6 hour turn over rate.
Continue your research with these figures at hand.
Thanks for your interest in FixYa.com. If you found this information helpful, please vote ...
Aug 02, 2010 | Intex Pool & Spa
How many gallons of water in the intex pool 15 x 36
I presume you are speaking 15 feet in diameter and 36 inches average depth. 3976 gallons 176.7 square feet
Jul 21, 2010 | Intex Easy Set Pool 15x36
High salt readings
Start by getting a salt test kit that reads in #'s not color strips.
you need to be at least 2800ppm so that you generate enough chlorine and no higher than 3800ppm
3000ppm in the best.
Now drain 10-20% of your water and add fresh. go as much as 30% if you are way over the 3800ppm and depending on how many gallons of water your pool holds
Jul 03, 2010 | Intex Automatic Salt Water System for ...
How many gallons of water does this pool hold?
CIRCULAR POOLS
Diameter x Diameter x Average Depth x 5.9 = Total Gallons
Example: pool_gall_round.gif
Jun 12, 2010 | Intex Easy Set Pool 15x36
Salt generator
My manual doesn't give a table for a 1500 gallon pool. The smallest it shows is the 15x33 at 2587 gallons at which you'd at 65 pounds of salt. If you could possibly tell me how big your pool is I could look that up for you. If you don't have an intex pool, the formula is Gallons x 0.025 so about 37.5 pounds for your pool. then you'd add 10.05 pounds when the Low Salt light comes on.
To start it up, hold the down arrow until it beeps, hold the up arrow until it beeps. Now you're ready to set it (the 15x33 pool you'll run 1-2 hours a day) When you have the time set, hold the down arrow until it beeps and then the up arrow until it beeps. Now it should be set!
May 28, 2010 | Intex Automatic Salt Water System for ...
How do you set the panel on a salt water intex pump mdl no.8110 and how much salt do use
to set the system, hold the down button until it beeps, then hold the up button until it beeps. Now the system is ready to set. Push the up button to the desired number of hours you want it to run. Now, hold the down button until it beeps, then the up button until it beeps. It should be locked and ready to start working.
Without knowing how large your pool is, I can't give you an exact amount of salt to use. If you know how many gallons your pool holds the formula is Gallons x 0.025 = pounds of salt to start up. When you need to add salt, its gallons x 0.0067 = pounds of salt to add when needed.
May 20, 2010 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
69 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
