Question about Refrigerators
THF24PR FREEZER LEAKING WATER,COILS FROSTED
  • 143 Answers
SOURCE: Maytag Model MZD2766GEW iced coils
This sounds like a defrosting problem. There is a defrost timer, a heater element, and a therm-o- disk thing that shuts the heater off when the frost is melted. These are the things to check, but it's usually the heater that is burnt out.
Posted on Jul 23, 2008
  • 11 Answers
SOURCE: my freezer is leaking inside
This water comes from the defrost cycle. The drain hole is probably plugged with food. The drain usually goes to a small pan under the condenser where it eventually evaporates. Look for a hole or slot in the bottom of the unit.
Posted on Apr 18, 2009
jvernice
  • 63 Answers
SOURCE: water leaking from top of freezer into icemaker
Is the water condensing and winding up in the ice maker or is there an actual leak in the ice maker water feed line?
Posted on Jul 29, 2009
SOURCE: freezer all frosted
i have the same problem and the maytag repair man said 99% of the time its the auto defrost board. i ordered one from ebay for 32.02 and will let you know if it works when it gets here.
Posted on Jul 26, 2010
  • 1891 Answers
SOURCE: water is leaking in the
when the cold coil is freezing up this is caused by a failed defrost system ( a bad heater or terminator . or the aditive defrost control . it also will freez the drain in the back of the freezer and this will cause the water to end up on the floor . . i would defrost the frig and repl the terminator . the heate is usualy good . and if problem comes back then replace the a d c . // the a d c pt # 241508001 and the terminator 5303918214 . this is a very common problem .. mm hope this helped and thanks for using fix ya ..
Posted on Oct 31, 2010
I have a side by side whirlpool fridge and the freezer is fine but the fridge is now freezing everything. It's about 11 years old.
Since you stand to loose all the food I would call a service tech ASAP. But here are the most common reasons for the problem you have.
Cause 1
The Evaporator Coils are Frosted Over The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
Nov 19, 2016 | Whirlpool Refrigerators
The freezer is working but the refrigerator is not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Oct 01, 2009 | Dometic RM2652 Refrigerator
Kenmore frost free refrigerator
Hi thanks for te question .If all the coils are frosted. no its not going into the defrost cycle. and you also have a problem with a clogged drain thanks the appliance doc
Sep 18, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Leaking Whirlpool fridge
Thanks for the question When this happens if the evaporator is all frosted up you have a derost problem could be your timer or your defrost thermostat which is located on the coils of the evaporator you can check this with a volt meter these meters are cheap you dont need a very expensive for ahout 20 dollars or the defrost timer one of the two is your problem thanks for the question The appliancedoc
Sep 11, 2008 | Whirlpool ET8WTKXK Top Freezer...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
