Question about Garden
Duerr chipper remove carburetor
Does the Central Chipper 55 hp model 95964 have a fuel pump, if not how does the fuel get to the engine
You can check if it is a fuel problem by spraying some carburetor cleaner into the intake inside the air cleaner and then trying to start the engine. If it has a gravity feed with tank above the float bowl level, check for debris in the tank, and flow through the fuel line and finally, drop the float bowl and check that the needle & seat allow fuel to flow into the bowl. If it has a carburetor mounted fuel tank (underneath) try removing the tank and inspecting the pickup screen (plastic) and the integrity of the diaphragm and gaskets. It needs to be sealed to work.
Oct 27, 2014 | Heavy Machinery
How can I make my old 5 hp Craftsman chipper-shredder Model #247.795940 run?
The pilot jet is probably clogged. Take the fuel bowl off the carburetor and look for the hole that passes from the top of the bowl into the main venturi of the carburetor. Try spraying carburetor cleaner spray into the hole; if it doesn't come out in the venturi, it's clogged. Take a really fine wire (a single wire pulled from a wire brush will usually work), and slide it up until you see it protrude into the main venturi. Once you open the orifice, spray carb cleaner throught it. The thing should run after you put it all back together.
Jul 09, 2014 | Heavy Machinery
S & S carburetor Gas leaking out of overflow tube
I own one of those, assume it's the same model. I'd go to the B&S carb page. If that doesn't help, you can contact them. https://www.briggsandstratton.com/eu/en/support/faqs/adjusting-the-carburetor
May 18, 2014 | Troy Bilt Walk Behind...
When I have the choke fully on, the engine in my snowblower runs. When I take it off choke, it sputters and stops. The fuel line is clear and there is no fuel filter that I can find.
The mixture settings on the carburetor may be off. Cleaning the carburetor and having the mixture settings adjusted may help. The fuel delivery is not an issue since choking increases the fuel/air ratio, i.e. adds more fuel for the same amount of air. Also worth checking the seals on the intake components, since excess air could be leaking in after the carburetor.
Oct 19, 2012 | Tecumseh Engine 5.5hp Horizontal OHV MTD...
My Tecumseh engine stopped running but was not out of gas. When I tried to start it would not and gas is coming out of the air filter. I took off the carb bowl and float seems to move ok
Your float might have a hole in it and is full of gas. You need to take it off and shake it to see if gas is in it, or float pin is faulty not closing correctly.
Aug 19, 2012 | Tecumseh Garden
Have a Troy-Bilt Chipper/Vac model # 47282 5hp sp, the Carburator needs to be replaced, I cannot find a part # for it, or where one can be purchased, please help
I believe the carburetor part number for your model is 632631. I have the same TroyBilt chipper/Vac. It has a Tecumseh H50-65582W engine. A good parts diagram can be found at
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-H50-65582W-PARTS-LIST.pdf
If this is the right part, you can buy it at Jacks Small Engine parts for $79
Good Luck!
Dec 12, 2010 | Troy-Bilt Chipper Shredder
I have a troybilt riding lawn mower that gas seems to be going into the oil..what could this mean
This is serious. Don't use the mower till it is fixed. Probably the carburetor has malfuntioned and may need to be removed, disassembled and possibly rebuilt. Major flooding is ocurring somehow either by the carb or a mechanical failure of the engine.
Aug 31, 2010 | Troy-BiltĀ® Briggs and Stratton Chipper
How do you rotate shredder blades on duerr m/n 678?
Interesting question --
I just picked up one of these over the weekend, and was able to get the flywheel off with minimal excitement. After removing the center bolt from the flywheel, I used a hammer to "encourage" the flywheel off the keyed shaft from the back-- through branch feed hole in the housing. It took quite some time, and I rotated the flywheel as I did it to keep it from binding up, but it eventually came off.
As an aside, would you let me know if you've found any source for parts or documentation? I'm going to attempt some repairs on the flywheel and chipper blades, but may end up wanting to replace them.
Apr 07, 2010 | Heavy Machinery
How do I clean the fuel line on troy bilt 5hp chipper vac?
unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
Jul 14, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
Troy-Bilt Chipper/Vac 5HP gas leaks out the carburetor
The float may have a hole in it causing it to sink and not seal the needle. Look at the float and check it for holes. You can shake it and listen for gas inside it. if so replace float.
May 01, 2009 | Troy Bilt Walk Behind...
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
