How can I determine if it is the regulator or the motor on the power window? Both are expensive to replace.
Remove the positive battery cable. From the front of the door, pull out the switch by sliding something flat in on one side and prying. Pull out enough wire to work with. Remove the round cap on the back of the switch and pry the switch and wire connector plate apart. With an ice pic or something similar, push the contact surfaces together to make a better conection with the switch pins when you reconnect it. replace the switch and this will fix your bad connection and your windows will work like they should.
Most shops will check your battery/electrical system free. When an alternator goes bad, one of the first signs is the power windows working much slower.
Also make sure your battery is large enough to handle all the electronics...not enough juice will slow down the already slow power windows
Factory window motors were all slow in the pre 90 years youll have to replace motors
http://technoanswers.blogspot.com/2012/01/power-windows-will-not-go-up-and-relay.html
Electric Window Motor REMOVAL and INSTALLATION on ford vehicles?
http://schematicsdiagram.blogspot.com/2011/06/electric-window-motor-removal-and.html
Driver side power window wont go up on ford expedition?
http://howtobyme.blogspot.com/2011/10/driver-side-power-window-wont-go-up-on.html
How to replace window motor and regulator on jaguar S-Type?
http://howtobyme.blogspot.com/2011/09/how-to-replace-window-motor-and.html
How to remove window motor and regulator on Volkswagen Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
power locks, power window and power mirror on the passenger side not working on
Ford Windstar
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working on 2003 Cadillac CTS?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
How to remove the door panel to install a new window regulator on Cadillac
Deville?
http://howtobyme.blogspot.com/2011/08/how-to-remove-door-panel-to-install-new.html
--------------How
to Remove Electric Window Motor on Acura Integra?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-electric-window-motor-on.html
How to replace power window motor in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-power-window-motor-in.html
HOW TO REPLACE A POWER WINDOW SWITCH
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-power-window-switch.html
How to Replace a Window Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-motor.html
HOW TO REPLACE A WINDOW REGULATOR WITH MOTOR
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-window-regulator-with.html
HOW TO REPLACE WINDOW RUN CHANNEL SEALS
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-run-channel-seals.html
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-regulator.html
How to replace power window regulator for 2006 Dodge Dakot
How to remove passenger side power window motor on Dodge Grand Caravan?
http://schematicsdiagram.blogspot.com/2011/09/how-to-remove-passenger-side-power.html
How to replace automatic window motor unit for the front passenger side on 2001
jeep grand cherokee Laredo ?
http://schematicsdiagram.blogspot.com/2011/09/how-to-replace-automatic-window-motor.html
how to replace passenger side power
window motor on 2001 Dodge van
All power windows not working on mercury sable?
http://technoanswers.blogspot.com/2011/09/all-power-windows-not-working-on.html
How to replace electric window regulator for mitsubishi 380 ?
http://technoanswers.blogspot.com/2011/09/how-to-replace-electric-window_05.html
how to remove window motor on driver side door panel on 1994 Oldsmobile Cutlass
Ciera
http://technoanswers.blogspot.com/2011/08/how-to-remove-window-motor-on-driver.html
driver side window problem on Mercury Sable
http://technoanswers.blogspot.com/2011/06/driver-side-window-problem-on-mercury.html
How to remove door panel, door window motor and regulator on 1991 cavalier?
http://technoanswers.blogspot.com/2011/05/how-to-remove-door-panel-door-window.html
how to replace the power window switch on 2005 BMW 325i?
http://technoanswers.blogspot.com/2011/03/how-to-replace-power-window-switch-on.html
How to replace window switch on bmw?
http://technoanswers.blogspot.com/2011/03/how-to-replace-window-switch-on-bmw.html
ford explorer window motor, regulator and door panel removal?
http://technoanswers.blogspot.com/2011/02/ford-explorer-window-motor-regulator.html
How to Replace a Window Switch on a 2002 Ford Explorer ?
http://technoanswers.blogspot.com/2011/02/how-to-replace-window-switch-on-2002.html
Ford F-150 Power Windows Not Working?
http://schematicsdiagram.blogspot.com/2011/12/ford-f-150-power-windows-not-working.html
Power windows works intermittently?
http://schematicsdiagram.blogspot.com/2011/12/power-windows-works-intermittently.html
Pontiac grand am power window not
working?
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
http://technoanswers.blogspot.com/2012/01/auto-open-close-feature-not-working-for.html
http://repairhelpcenter.blogspot.com/2012/01/lexus-es300-power-window-out-of-time.html
http://technoanswers.blogspot.com/2012/01/rear-power-windows-not-working-on-ford.html
http://technoanswers.blogspot.com/2012/01/all-power-windows-not-working-on-ford.html
http://technoanswers.blogspot.in/2012/02/2003-chevy-impala-power-windows-not.html
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
For all types of power window problem and power windows not working,i suggest you to go through the help links given below.Click the link to go through its procedure to troubleshoot the problem :------
driver side power window problem?
wont go up?
Power window problem
rear door or window will
not open ?
http://technoanswers.blogspot.com/2011/06/rear-door-or-window-will-not-open-on.html
How to remove door panel, door window motor and regulator ?
Power windows not working after car wash?
http://howtobyme.blogspot.com/2011/11/power-windows-not-working-after-car.html
---------power locks, power window and power mirror not working?
All power windows not working?
-------------Complete Diagnosis & Testing Power Windows?
motor in car?
-----------This will help.Thanks.
Driver side power window wont go up?
rear door or window will not open ?
How to remove window motor and regulator on Car?
