Question about Watches
How do you turn off alarm on Roots ry2184 watch
How do I set time on roots r316
Have a jeweler do it. Or look for a manual on Google.
Dec 25, 2014 | ROOTS Watches
How do i set my digital watch,roots ry2129
Here is an actual 'live' web link (I just checked) - to Roots, "watches":
http://usa.roots.com/on/demandware.store/Sites-RootsUS-Site/default/Search-Show?q=watches&simplesearch=
If nothing else, if you scroll to the bottom their contact info appears which I am also pasting below. Good luck to you!
Contact Us:
• 1-800-208-0521
• Outside of Canada: 1-972-265-4120
• Email: onlineservice@roots.com
Nov 09, 2014 | Watches
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    How to set alarm on oots MAI TAI RY2142 Watch for Women?
    Start by holding in the mode button (bottom left) until the first number blinks, then let go. You are actually in the alarm mode right now. Now press and release the start/stop button (top right) and the minutes will flash, again for hours. When the parameter you want to adjust is flashing just press the adjust button (top left) to change the numbers. When your finished simply press the mode button to exit the setting menu. To turn the alarm and/or the hourly chime on or off, hold in the adjust button (top left) and press the start/stop (top right). Each time you press the start/stop (top right) the CH or AL or both symbols. When the symbol is showing, that function is on.
    Jun 02, 2014 | ROOTS MAI TAI Ry2142BLK Watch
    How to change time on roots watch ry2203
    Press and hold "MODE". Press MODE 2 times (after the first time, the alarm time flashes, after the 2nd time, the second flashes). Press ADJ to change seconds. Press ST/STP to switch from seconds to minute. Press ADJ to change minutes. Then press ADJ to change hours. Press MODE when done.
    Apr 06, 2013 | ROOTS Athletics Wrist WATCH Water...
    How do I set the date on my Roots MAI TAI RY2142 Watch for Women?
    Start by holding in the mode button (bottom left) until the first number blinks, then let go. You are actually in the alarm mode right now, now press and release the mode button and enter the time setting mode, the seconds will be flashing. Now press and release the start/stop button (top right) and the minutes will flash, again for hours, again for the month, and again for the date. When the parameter you want to adjust is flashing just press the adjust button (top left) to change the numbers. When your finished simply press the mode button to exit the setting menu. Worked for me, hope it does for you too. Most of the other setting changes are tricky as well, just ask for help again if you want to change the alarm or 12 or 24 hour clock etc....
    Jan 03, 2013 | ROOTS MAI TAI Ry2142BLK Watch
    How do you set the time on the Roots Womens's Mai
    Feb 05, 2010 | Watches
    Can't turn off alarm
    Here are the instructions to view, change alarm time and turn off alarm:
    From normal time display:
    Press MODE once to display stop watch.
    Press MODE again to change alarm time.
    Press MODE again to change time.
    Press RESET once to display current alarm time.
    Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
    Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
    Hope this helps.
    May 05, 2009 | Watches
    Unwanted alarm
    using the button at bottom left of watch, set to the alarm mode and press the button at bottom right to toggle between alarm settings. The bell and wave symbols will appear and disappear on top left of watch display.
    Jan 08, 2008 | Oregon Scientific SE233 Wrist Watch
    Watches Logo
    170 people viewed this question
    Top Watches Experts
    Jimmy Accardi
    Are you a Watch Expert? Answer questions, earn points and help others
