Question about Vehicle Parts & Accessories
Avital avistart 3100 remote car starter - Vehicle Parts & Accessories
5 Suggested Answers
jpk528
  • 95 Answers
SOURCE: I have a 1998 Chevy cavalier with Avital 3200
it sounds like its the bypass module. When it doesnt start the car goes into security mode and wont let it start for up to 15 minutes. I would check the bypass module to see if it still has power or has been reset, if its not something you can do, bring it to a local mobile electronics shop and they should be able to take care of it for ya.
Posted on Mar 03, 2009
SOURCE: my avital 4113 car remote
DEI sent out a recall on a batch of theit antennas for this sysetm that were remote starting the car by its self. If you call customer service they will send you a replacement antenna and this sould fix your problem.
Posted on Jan 26, 2011
logosc75
  • 625 Answers
SOURCE: i have a problem with
If this is the factory alarm going off when you remote start the vehicle, the factory disarm wire is not connected. If you would list the year/make/model of the vehicle, I could direct you to the wire.
Posted on Feb 25, 2011
  • 1833 Answers
SOURCE: After starting vehicle with remote
According to your problem you can first change your remote battery to if it is not malfunctioned for battery. Before start the vehicle press lock key for 1 second to lock the door from remote. If the door locks are connected then horn will honk and the parking light will flash once. If the system is armed then status Led will flash once per second. After check it you can start your vehicle. But don't remote start your vehicle when the key is in ignition. It may help you to solve your problem.
To know more you can follow the manual.
Posted on Mar 16, 2011
Remote starts the car but doesnt unlock/lock doors
You must first get a bypass module to sync the factory with the afterm
Aug 08, 2014 | AviStart 4400 2-Way Security / Remote...
Need to program additional fob to Avistart 4111
Turn ignition on, press and release valet switch then, press and hold valet switch. Press button on remote. Release valet switch, turn off ignition. Test
Feb 08, 2014 | 4111 4111L Remote Car Starter
Uninstalling a remote starter/ alarm system in a 1997 Yukon
Depends on the type of remote. Most common fix 1. Take off the lower drivers side kick panel. 2. Locate the black remote box. 3. You should see a thick yellow wire coming from the steering wheel area that has been cut and then spliced to go into the remote box. This is the feed to starter relay and will have voltage when key in in start position.4. reconnect the yellow wire back together bypassing the box. 5. Find the red wire( power source) that goes to box and disconnect it.
System should be bypassed
Oct 30, 2013 | AviStart 5303 2-Way Security / Remote...
Need wire diagram for avital 5103
You can download a copy of the installation manual from this link:
Avital 5103 installation manual
Sep 24, 2012 | Directed Electronics 5103L Avistart 5103...
Installing aftermarket remote start on a 2007 Dodge ram 1500
Oh yes. You will need an interface for the remote starter to work. You can purchase an FLCAN or an XK09 but, these components must be programmed to function properly. You can purchase an EVO-ALL; it does not need to be programmed. The installation instructions can be downloaded at ifar.ca. The three components mentioned above will work almost necessary components in the vehicle . Hardwire the system with 5303 and then wire the interface to the vehicle through the CAN data wires.
Jul 10, 2012 | AviStart 5303 2-Way Security / Remote...
Howto disable 24 hr timer in avital 4400
Remote start the vehicle; turn ignition on with the key. The parking lights will flash 4 times indicating that the timer mode has been exited.
Please note how the timer was activated by pressing the lock and unlock buttons.
When in the timer mode, the remote starter can time out or, you can shut down the remote starter with the remote and the timer mode will remain active. But, if the remote start sequence is terminated by any of the shutdowns ( ignition, brake, hood or neutral safety switch) while the remote starter is running, the timer mode will be terminated.
Feb 03, 2011 | AviStart 4400 2-Way Security / Remote...
How do i exit remote time start timer mode?
Hey hi u doing I c u need help but wish I could help but u might be able to help me out. I need to know wat colors go to wat in a car u know plz help me out
Apr 25, 2010 | AviStart 4400 2-Way Security / Remote...
Where to hook up the remote start activation wire?
There is no need to hook up the remote start activation wire. That wire is for testing the system after it has been installed.
Oct 04, 2009 | AviStart 5303 2-Way Security / Remote...
Vehicle Parts & Accessories Logo
26 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
