Question about Garden
How to level the deck on a RZ 5426 - Garden
Supra rz
you can try with your local pollution control centre
Jun 26, 2008 | 1998 Toyota Supra
Deck is not level and mower blades are not the same height
Usually you can solve this problem by leveling the deck. Many mowers have adjustment nuts on the ends of the brackets that attach the mower deck to the frame of the mower. First park your mower on a flat surface like a sidewalk or driveway. Then place a small level on a flat area of the mower deck, then turn the adjustment nuts until the deck is level.
Jul 18, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Husky yth1542xp. I've changed the blades, leveled
When levelling the deck, rotate the blades so that the right blade has one of its cutting edges at or near the right side center of the deck. Do the opposite with the left. Measure to the blades from the level ground, not to the deck. Try leveling that way.
Gary
Jul 03, 2011 | Husqvarna Garden
How to adjust the mowing deck properly?
Find a level surface (concrete garage floor for example) ... adjust front to back ... use a tape meadure to mneasure floor to deck edge ... then adjust side to side.
Jul 29, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Uneven cut
1-----------tire pressure? 14 front 10 rear
start with a level mower on a level surface
2------------deck level side to side?
3------------deck level front to back? (front can be 3/8 lower than back)
4-----------deck hangers bent or hung up?
5------------blades even when pointing at each other? no more than 1/8 high or low
6------------blades dull or upside down? turned up ends go towards deck
7---------------incorrect blades for mower?
8------------deck lifting mechanism should pick up deck evenly and drop evenly?
9-----------under the deck need cleaning because it is packed with grass?
Jun 15, 2009 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
