Question about Dehumidifiers
Fedders cue015a3 Removal of blowers motor
Fedders dehumidifier guage problem
call Chas&Son,s appliance repair at 570-379-0993 and they will come out the same day no less okay
Dec 26, 2011 | Fedders A7DH45B2A Dehumidifier
We have to change the fa.,How it cost and where i can by one in Quebec City. Model A6DH65B2A.Thanks
If it's just the fan blade # CRCFD5303-010, you're in luck. It's available from the following link.
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=281964&modelsID=114658
If it's the fan motor you're after. They are no longer available. As Fedders has been out of business for several years and many of the parts are no longer available.
I hope this helped you and thanks for choosing FixYa.
Jul 25, 2011 | Fedders A7DH45B2A Dehumidifier
I have a Fedders dehumidifier Model A7DH45B2A REV-A. The nipple on the float broke off. Where can I buy a float? Do you have one? How much is it?
Although Fedders, as you knew it is no longer in business, some parts are still available.
Here is a link, with an explodes view of your model's parts.Locate th epart you need and then enter the part number, to see if it's still available. FYI Maytag Dehumidifier parts are interchangeable with Fedders. Fedders made the units for Maytag.
http://www.appliancefactoryparts.com/dehumidifiers/fedders/a7dh45b2a.html
I hope this helps you find what you need.
Jun 19, 2011 | Fedders A7DH45B2A Dehumidifier
Coil is freezing up.rusted coil sensor bracket. i need a new freeze switch sensor for the front coil. i guess it turns the compressor on and off so the coil doesn't freeze solid. can't find the...
Buck, as you seem to be aware, Fedders no longer exist as the Fedders you may have been familiar with 8 years ago. Finding manuals and parts, is like looking for a needle in a hay stack. However, the new company Airwell-Fedders may be able to help you. There Customer Support Dept 866-829-2440, is who you need to contact.
There is one other possible source, as some parts are interchangeable. Appliance Factory Parts
http://www.appliancefactoryparts.com/airconditioners/fedders/ does carry some of the older Fedders Parts, as well as Maytag. So, that may be worth a try.
Hope this helps you find the parts you need. Good luck and please let me know how it worked out for you. Thanks.
Jun 11, 2011 | Fedders A7DH45B2A Dehumidifier
Fedders dehumidifier making high pitched noise
The fam motor bearings are dry and need oil..wd-40 with the long spray nozzle maybe the best way to get oil on the bearings... some motors are sealed and it is very dificult the get them quiet again...spray right where the shaft comes out of the motor and then lean the unit back so the oil runs into the motor and let it set for awhile..then try it...
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Apr 20, 2010 | Fedders A7DH65B2A Dehumidifier
Runs but does not remove water
If only the bottom part if your coil is geting cold or freezing, it's low on Freon.
Please rate solution
Sep 05, 2009 | Fedders R6DH45X Dehumidifier
Fedders 65 Pint Dehumidifier Fan Problem
I have the same problem. The fan motor bearings are bad on mine. You can get a new fan motor at Appliance Factory parts.com. Phone number 1-800-955-7075. $44.95 + shipping.
Gene
Feb 05, 2008 | Fedders A7DH65B2A Dehumidifier
Fedders Dehumidifier - Wont Turn On
Looks like a control board, Check the board for burn marks. What model do you have? Some parts are available on-line at appliance factory parts.. also check your Capacitor and fan motor before you install your new Board..Let me know if this helps? Krazytech
Aug 14, 2007 | Fedders A7DH45B2A Dehumidifier
Dehumidifiers Logo
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
